3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Apr 28, 2017 at 3:49 PM
    #2221
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Mine started at 54 mph but it has been creeping up to your range but thankfully it has not gotten louder so far.
  2. Apr 28, 2017 at 11:13 PM
    #2222
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I don't know if Toyota built the diff themselves. It gets a little complicated if they contracted out the diff. The diff could be showing no excessive signs of wear, yet the diff supplier comes back and says "well, 'x' amount of noise was never a design requirement, it will take $$$ to figure out the root cause and change the design." Then a lot of back and forth happens before either 1. The design is changed or 2. Toyota determines a fix to "mask" the issue.
  3. Apr 28, 2017 at 11:14 PM
    #2223
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    I fear 2 will be the so called fix...
    shakerhood likes this.
  4. Apr 29, 2017 at 11:02 AM
    #2224
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Everything is normal as far as Toyota and their stupid tech's are concerned,even your engine falling out the truck onto the road.
    Riding Dirty likes this.
  5. May 2, 2017 at 10:58 AM
    #2225
    Harley08
    Harley08 Active Member
    Southern MD
    2017 Inferno Tacoma TRD OR
    20% Tint, 5" Oval Tube Step, Tri Fold Bed Cover
    Update on Taco: Picked the truck up after toyota had for 5 days. New diff installed. No noise currently with the new one. I will have to keep an ear out, while I put some more miles on the truck.
  6. May 2, 2017 at 2:20 PM
    #2226
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Same thing happened to me with a new diff thousands of miles ago. It came back :(
    I hope they've fixed it for sure.
    Harley08[QUOTED] and shakerhood like this.
  7. May 11, 2017 at 5:57 PM
    #2227
    Art42
    Art42 New Member
    2014 4x4
    I have a 2014 4x4 I just purchased in September. Within 2 weeks I noticed the howl. First was told it was exhaust noise, after disagreeing with that, I was told it was gear lash and a normal noise. Finally after 8months and basically refusing to leave without acknowledgment that something is wrong, they ordered a new differential today. Will update after install. This is my first and soon to be last Toyota.
  8. May 11, 2017 at 6:07 PM
    #2228
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    https://www.youtube.com/watch?v=a3MnEdMSS-I
    https://www.youtube.com/watch?v=7Iopg8IFVgw
    I can't hear anything over my tires lol.
  9. May 11, 2017 at 6:14 PM
    #2229
    tacoflavoredkisses1
    Did you open a case with corporate!?
    Don't just bitch here. Let them know. The lady I spoke to last night said they are well aware of it. They need those complaint numbers to hit their threshold.
    My guess is that they've been watching for issues because of the howling complaints and that's how they noticed the recall leak.
  10. May 11, 2017 at 11:28 PM
    #2230
    podonne2
    podonne2 Member
    2016 blazing blue TRD OR DCSB
    I've had the 55mph howl since I first bought the truck. Already had the diff replaced and didn't seem to help at all. But I noticed that if I drive with the rear passenger side window down at 27mph, there's also a faint howl. Makes me think the issue is a harmonic/fundamental frequency of the vehicle. This isn't the LCA howl either. I already had the holes plugged. The 27 mph howl seems to be coming from the same location as the 55 mph howl. Any takers?
    maxa likes this.
  11. May 12, 2017 at 6:59 AM
    #2231
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Window cracked---or all the way down?
  12. May 12, 2017 at 8:50 AM
    #2232
    podonne2
    podonne2 Member
    all the way down
  13. May 16, 2017 at 9:28 AM
    #2233
    shakerhood
    Southern Ohio
    I do not think it can be a driveline angle issue. If it were it would do it from day 1 and it would not increase in volume and range.
  14. May 16, 2017 at 9:29 AM
    #2234
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Unless it has to do with suspension settling?
  15. May 16, 2017 at 9:35 AM
    #2235
    shakerhood
    Southern Ohio
    Yeah, l guess that is possible too, but if you have a load in the bed would it not get louder? Something is definitely going on out back in some of these truck though.
  16. May 16, 2017 at 12:26 PM
    #2236
    mbtex
    mbtex Well-Known Member
    Pearland Texas
    94 4X4 Exc Cab, 2017 DCSB TRD OR, 2023 DCSB TRD OR 4x4
    I have only heard it once and it occurred when I had 4 adult passengers. Have not been able to duplicate yet.
  17. May 16, 2017 at 12:27 PM
    #2237
    Tacowin1013
    This may sound strange but I had a family member in my truck who could NOT hear the noise at all while it was 100% noticeable to me while in the 52-56mph band. I wonder how many here are unable to pick up the 400hz pitch that its giving out?
  18. May 16, 2017 at 12:47 PM
    #2238
    DontPanic
    DontPanic Well-Known Member
    VA
    Try sitting where they were sitting and see if it goes away. they may have been in a cancellation node (less common at higher frequencies), that or their hearing just isn't as acute as yours.
  19. May 16, 2017 at 12:47 PM
    #2239
    mbtex
    Pearland Texas
    Everyone in the car heard the sound at the time but it would come and go. But it only has occurred once in the 4 months that I have had the Truck.
  20. May 16, 2017 at 1:48 PM
    #2240
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I don't know if my noise is getting louder or I'm getting more sensitive to it.
    I can hear it from 40-60 now. Most distinctly at 54ish mph.
    I'm trying to see if anyone else will notice it. I haven't had anyone comment on it yet.
