3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. May 20, 2017 at 10:32 AM
    #2261
    tedburgundy
    tedburgundy Well-Known Member
    Interesting indeed.
    Ted
  2. May 20, 2017 at 10:40 AM
    #2262
    trdude10
    trdude10 Well-Known Member
    Nick
    17 DCSB Trd OR 6sp
    I'd be down to try this but don't want to be the first :anonymous:
  3. May 20, 2017 at 11:20 AM
    #2263
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I'm not sure I'd give them that much credit. It sounds like the squeaky rear-leaf situation could be solved with some cheap rubber inserts. It's not completely out of the realm of possibility that this fix could be equally as simple. They just don't seem motivated to do what it takes.
    AKGSD likes this.
  4. May 20, 2017 at 2:14 PM
    #2264
    tedburgundy
    Corporations are like government.
    Ted
  5. May 22, 2017 at 1:18 PM
    #2265
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
  6. May 22, 2017 at 3:03 PM
    #2266
    Ed Crankshaft
    Ed Crankshaft Well-Known Member
    2016 Black Tacoma TRD 4X4 DCSB
    I passed 11,000 miles on the odometer. The rear end makes the same faint sound, not any louder.
  7. May 22, 2017 at 5:49 PM
    #2267
    tacoflavoredkisses1
    Do those of you with bigger, heavier tires have the howl?
    @smitty99 did you add tires when you lifted?
    I would like to test a hypothesis (and justify buying new tires)that the heavier tires put enough of a constant load on the diff that the howl is reduced.
  8. May 22, 2017 at 5:49 PM
    #2268
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Nope all stock
  9. May 22, 2017 at 5:50 PM
    #2269
    tacoflavoredkisses1
    DAMMIT LIE TO ME
  10. May 22, 2017 at 6:07 PM
    #2270
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    I'm personally not even thinking about another tire so Toyota wont try to pin the howling on the tire. As soon as I put another tire on it Toyota will blame the tire. Not happening for me and I really want a "one up" tire size and a more aggressive tire.
  11. May 22, 2017 at 6:07 PM
    #2271
    smitty99
    Scottsdale
    Correct they will blame the tire.
  12. May 22, 2017 at 6:46 PM
    #2272
    tacoflavoredkisses1
    That's actually the only reason I haven't so far. That and I didn't mind the stock Wrangler too much, but it's wearing poorly and I'm getting road noise.
  13. May 22, 2017 at 6:52 PM
    #2273
    The Real Moondog
    Moondog
    Until I get stuck or until they fix this rear diff, I'm staying stock on the tires. I want something like a Duratrac or equivalent but I'm not giving Toyota any reason whatsoever to wiggle out of the rear diff issue.
    nDub and smitty99[OP] like this.
  14. May 22, 2017 at 7:10 PM
    #2274
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I read that link and it sounds like that was under Acceleration which is not the same as they said the problem goes away when they let of the throttle.
  15. May 23, 2017 at 4:36 AM
    #2275
    trickmonkey
    trickmonkey Member
    2017 TRD Offroad Dbl Cab LB
    I don't hear a howl from mine, but when slowly accelerating from 30ish-55ish, i feel shaking in the rear, like I'm driving on a rough road, even when I am not. I have taken it to the dealer twice, and they check the tire balance, checked to make sure they were completely circular, checked the bearings and drive shaft angle, the transmission fluid, and so forth. This is on a 2017 TRD OR DCLB.
    They tried opening a case with Toyota, but since they were able to reproduce it in other similar trucks, Toyota wouldn't do anything about it, said it was a design issue.
    For what it's worth, one of the times I had it in the shop, they gave me an SR5 2 wheel drive, and I did not feel that vibration at all.
  16. May 23, 2017 at 5:00 AM
    #2276
    Critical05
    2017 DCLB TRD OR
    Have they checked the leaf spring U-bolts, they have been known to be not tight? Just thinking of anything loose that could contribute.
    shakerhood likes this.
  17. May 23, 2017 at 5:07 AM
    #2277
    trickmonkey
    trickmonkey Member
    Yes, I had them check those as well. Although I am planning on changing the gear oil either this weekend or next, I will likely check those as well while I am under there.
  18. May 23, 2017 at 6:52 AM
    #2278
    DontPanic
    DontPanic Well-Known Member
    VA
    Won't work, you can't wish the noise away with fluids etc. (unless you are Toyota in which case you can pretend it doesn't exist). Its the rear diff - bad setup or inherently noisy combination of parts. Some apparently have luck with changes in pinion angle putting a load on the set-up and making it quieter...
  19. May 23, 2017 at 7:36 AM
    #2279
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    my 17 TRD OR is nearing 10,000 miles... The rear end howl is louder than it was 8,000 miles ago. It howls on light / zero throttle application from 70-50mph.
    My 2011 did nearly the exact same thing, and it took 2 years bitching with toyota to get it fixed. then it was written off 2 months after the fix... though it howled on zero throttle deceleration where the 3rd gen howl's on light throttle deceleration.
  20. May 23, 2017 at 7:39 AM
    #2280
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Have you brought it up at your 5k service? I would schedule a test drive with the SM or lead advisor. This is one of the first in hearing of with that broad of a range.
