3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. May 31, 2017 at 2:58 PM
    #2341
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    And? Update?
    shakerhood likes this.
  2. May 31, 2017 at 4:19 PM
    #2342
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    Yes -- they did that too--waste of $ and time--spent 3 hours with chassis ears [removed transfer case and drove ] before Toy authorized the new diff. Used a devise to measure the sound before and after. A diff howl is easy to diagnose...:burnrubber:.
  3. May 31, 2017 at 4:54 PM
    #2343
    Bomo
    Bomo Well-Known Member
    Vermont
    2017 TRD offroad DCSB Manual
    ^^^ my dealer has 18 tacomas on the lot, but nothing to copair my truck to there's.
  4. May 31, 2017 at 6:29 PM
    #2344
    nDub
    Lead Free Gasoline
    Bad pinion bearing is the diagnosis.
    Replace diff is the "cure"
    Should have all the parts in a week or so and then they'll need my truck for a couple of days for repair.
    All in all I am impressed with Modesto Toyota they have been great so far and I hope for my and their sake this fix will be the Midas touch.
    I got them to manually check the tranny and Check for the TSBs. Both were good.
    Also all new diff fluid which is ok with me.
    Patrick1046 likes this.
  5. May 31, 2017 at 6:44 PM
    #2345
    Patrick1046
    Yep -- they told me they don't know why they are failing and they will probably need to replace it again.:yes:
  6. May 31, 2017 at 6:58 PM
    #2346
    nDub
    Lead Free Gasoline
    Bummer.
    At least I'm back in my truck!
    Although I topped the Prius off after driving about 140 or so miles and dropping it off.
    2.1 gallons...
  7. May 31, 2017 at 7:05 PM
    #2347
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I hope yours is a permanent fix. I doubt it though. My replacement started up again fairly quickly iirc.
    My guess is driveline angles, because people with lifts are reporting improvement after the lift.
  8. May 31, 2017 at 7:47 PM
    #2348
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Isn't it lovely? My wife's prius gets 55mpg average and is great on road trips. Too bad it's not the best looking car...
  9. May 31, 2017 at 8:14 PM
    #2349
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Jumping in on this..
    Started noticing this a couple hundred miles ago (at 3500+ now).
    2017 Double cab short bed TRD/Off Road manual trans.
    Just started hearing it so haven't been to the dealer yet. Any tips on what to say to them to get it addressed?
  10. May 31, 2017 at 8:16 PM
    #2350
    nDub
    Lead Free Gasoline
    Yeah my wife wants one for her next car and I think I'm onboard now.
    I agree, looks are not so great.
  11. Jun 1, 2017 at 10:39 PM
    #2351
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Just curious what speed you notice it at? When mine started it was right at 54 MPH but now the range is a little wider and goes up to about 60.
  12. Jun 1, 2017 at 10:58 PM
    #2352
    Reluctanse
    Sam
    Newberg, Oregon
    Probably 57-58
    shakerhood[QUOTED] likes this.
  13. Jun 2, 2017 at 8:28 AM
    #2353
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Noticed that if i crack the window or have them down, the wind noise is loud enough so I don't hear the howl.
    Also noted, using the AC puts just enough draw on the engine that the howl can be heard without feathering the throttle when decelerating through the 60-54 mph range.
    Joe23 likes this.
  14. Jun 2, 2017 at 9:27 AM
    #2354
    Harley08
    Harley08 Active Member
    Southern MD
    2017 Inferno Tacoma TRD OR
    20% Tint, 5" Oval Tube Step, Tri Fold Bed Cover
    What was the determination on your diff howl? replace diff or not.
  15. Jun 2, 2017 at 9:42 AM
    #2355
    nDub
    Lead Free Gasoline
    Bad pinion bearing. They're going to replace it once they can source all the parts. Apparently the diff gasket is hard to get right now :laugh:
  16. Jun 2, 2017 at 2:13 PM
    #2356
    Ed Crankshaft
    Ed Crankshaft Well-Known Member
    2016 Black Tacoma TRD 4X4 DCSB
    This is what I posted July of last year. If the new pinion bearing resolves the howling issue, please let us know.
    nDub likes this.
  17. Jun 2, 2017 at 2:36 PM
    #2357
    nDub
    Lead Free Gasoline
    They're just going to replace the whole diff. So it will have a new pinion bearing but who knows if it'll be any better set up than the one I have now.
    I hope so.
    smitty99[OP] likes this.
  18. Jun 2, 2017 at 5:48 PM
    #2358
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    New 4.88 gears are smooth and quiet, but I only have like 450 miles on them. I had the install shop run a pattern check on the factory setup, and he said he couldn't exactly remember the pattern, but said it was acceptable.
    Bomo and nDub[QUOTED] like this.
  19. Jun 2, 2017 at 6:39 PM
    #2359
    nDub
    Lead Free Gasoline
    Right on.
    Might be a bad batch of bearings.
    Thanks
    Diablo169[QUOTED] likes this.
  20. Jun 9, 2017 at 7:43 AM
    #2360
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Yup I've got it 2017 TRD OR DCSB slight howl at 60-62. Noticed it at 13 miles and have 1200 now. Will schedule my 5k service and tell them about the noise.
