3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Aug 7, 2016 at 12:45 PM
    #221
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If axle wrap is bad enough, sure.
    Tacomas are notorious for axle wrap...combine that with low diff fluid from the factory...
    Maybe try replicating it going down a steep grade.:notsure:
    jg16[QUOTED] likes this.
  2. Aug 7, 2016 at 1:15 PM
    #222
    jg16
    jg16 Well-Known Member
    Tennessee
    2016 White Off Road
    That might give me a reason to drive to the mountains!!
  3. Aug 7, 2016 at 1:22 PM
    #223
    splitbolt
    NW Arkansas
    Not a roar per se.
    Mine is a high pitched bearing whistle type noise; comes on hard at 45 when accelerating.
  4. Aug 7, 2016 at 1:24 PM
    #224
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Mine must not be very bad yet. I only hear it on decel, and only from 55mph down to about 50mph. Or, maybe I'm hearing something completely different...
  5. Aug 7, 2016 at 1:28 PM
    #225
    2016_dbag
    2016 POSTURD
    :frusty:
  6. Aug 7, 2016 at 1:37 PM
    #226
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Get some real tires. You'll never know if the diff is making noise
  7. Aug 7, 2016 at 1:43 PM
    #227
    2016_dbag
    2016 POSTURD
    Maybe my noise really is just the tires. I'm running K02's.
    Aussiek2000[QUOTED] likes this.
  8. Aug 7, 2016 at 1:53 PM
    #228
    jg16
    Tennessee
    2016 White Off Road
    Mine is on decel or feathering the throttle slightly. Like if you take pressure off the rear end. More when feathering than hard decel, like when letting off the gas going up a hill.
  9. Aug 7, 2016 at 2:04 PM
    #229
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    Nope, that is pretty much exactly what you are describing except 60 down to 50. But is is only on deceleration.
  10. Aug 7, 2016 at 2:10 PM
    #230
    splitbolt
    NW Arkansas
    Howl during decel only, is usually loose pinion bearing preload.
    Aussiek2000 likes this.
  11. Aug 7, 2016 at 2:23 PM
    #231
    Aussiek2000
    2016 Offroad AC
    Yup.
  12. Aug 7, 2016 at 3:02 PM
    #232
    MasterPenguins
    Indiana
    Yeah, it took a couple hundred miles before I was sure that is was making the howling/whirring/woooooo noise again.
  13. Aug 7, 2016 at 3:05 PM
    #233
    ggnarl
    ggnarl Member
    nATHAN
    2016 TRD Offroad
    Stock
    My noise is pretty faint. I wrote it off as a harmonic resonance in the drivetrain. It might be due to a alignment issue. It could also be due to a bit of gear lash specific to this model.
    There is a big difference between a Howl and a hum. Anybody make a recording of the sound?
  14. Aug 7, 2016 at 5:36 PM
    #234
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    How about someone post a recording, so I know what to listen for?
    EDIT: Or just point me to it...
  15. Aug 7, 2016 at 5:44 PM
    #235
    MasterPenguins
    Indiana
    smitty99[OP] likes this.
  16. Aug 8, 2016 at 6:16 AM
    #236
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Mine is starting to whine now at 37 MPh as well.
  17. Aug 8, 2016 at 7:05 AM
    #237
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Yeah mine is doing it constant now 50-65 mph acceleration or deceleration makes no difference it is just howling. Me thinks Toyota needs to go back to solid pinion bearing spacers instead of crush sleaves. I have had the pinion bearing preload slack off on several Toyota third members over the years. All of them were crush sleave equipped. All but one of them I was able to save by tearing them down and swapping the crush sleave out for a solid spacer and a shim pack. The one that I didn't save was my '94 when it had 14k on it under warranty so I let it eat. It had a catastrophic failure that took out the third, drive shaft, fuel tank, shock, load sensing brake valve and a few other things when it came apart. Waiting on parts still for mine.
  18. Aug 8, 2016 at 7:15 AM
    #238
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    When are you planning on reporting it to the Dealer? I'm dropping mine off this AM.
  19. Aug 8, 2016 at 7:18 AM
    #239
    MasterPenguins
    Indiana
    God.....keeping up with this thead stresses me out....:annoyed:
    Really hope we get some good news soon.
  20. Aug 8, 2016 at 7:46 AM
    #240
    nevadabugle
    Elko, NV
    I'm not. I have given up on my Toyota Warranty. Unless something fails, the dealer will do the free maintenance and then I will handle everything else. It is not worth my time to deal with my worthless service department. It will cost me less to work on this truck myself than waste hours in the day when I could be making money, arguing that my tires are not the cause of the problem. And before all of you say take it to a different dealer, I live in the middle of Nevada. The next closest dealer is 3+ hours away.
