3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Aug 7, 2017 at 6:28 PM
    #2581
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    My service rep manager was telling me when he was a Toyota master tech they used to rebuild them in house.
    I'd be down for that.
  2. Aug 7, 2017 at 6:29 PM
    #2582
    Mountainmike87
    Mountainmike87 Well-Known Member
    2017 silver TRDOR
    If it's back I'll have to go lemon law. It degrades the resale on the truck. I don't want something I will lose tons of money on. I don't plan on having it for more than 3 years because hopefully life will be where it needs to be and I have land and a Cummins Dodge by necessity.
  3. Aug 7, 2017 at 6:30 PM
    #2583
    jg16
    jg16 Well-Known Member
    Tennessee
    2016 White Off Road
    Normal for this diff!!!
  4. Aug 7, 2017 at 6:32 PM
    #2584
    Baja man
    Baja man Well-Known Member
    2017 TRD 4x4 SPT
    Mine not doing that yet but when it does I will be pissed too I would vote for the 4.30 as well I'm keeping my truck if it have to sooner or later replace the gears myself but I think with so many people having the issues Toyota should man up and take care of there customers!
    harrycary and jg16 like this.
  5. Aug 7, 2017 at 6:33 PM
    #2585
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Can you record the sound, and catch the exact speed as the recorded sound?
  6. Aug 7, 2017 at 6:34 PM
    #2586
    harrycary
    Harry
    That is a great question. There may be a disconnect between the engineers and an implemented fix in the supply chain.
    jg16[QUOTED] likes this.
  7. Aug 7, 2017 at 6:37 PM
    #2587
    harrycary
    Harry
    I did a lot of searching. An engineer would likely lose their job if they said what was wrong. They could get subpoenaed by a lawyer, and then the lawsuits would begin.
  8. Aug 7, 2017 at 6:39 PM
    #2588
    harrycary
    Harry
    I think your first sentence has some gravity.
  9. Aug 7, 2017 at 6:39 PM
    #2589
    harrycary
    Harry
    That could be in our futures.
    Mountainmike87 likes this.
  10. Aug 7, 2017 at 6:40 PM
    #2590
    Mountainmike87
    2017 silver TRDOR
    Seems reasonable that they explain what makes this diff so special it whines and is normal yet every other diff on the planet doesn't when functioning properly
    harrycary[QUOTED] likes this.
  11. Aug 7, 2017 at 6:42 PM
    #2591
    harrycary
    Harry
    Super. I am pretty sure the real issue is ring and pinion tooth mesh. I would like to get my hands on one of these noisy third members and use a caliper and some gear paint myself. I am thinking the backlash or pinion depth is changing under load, and it is resonating through the housing between 40-65 mph. My opinion.
  12. Aug 7, 2017 at 6:43 PM
    #2592
    harrycary
    Harry
    Imagine that.
    ICU1 likes this.
  13. Aug 7, 2017 at 6:44 PM
    #2593
    Mountainmike87
    2017 silver TRDOR
    Agreed or something with pinion preload
  14. Aug 7, 2017 at 6:46 PM
    #2594
    Baja man
    2017 TRD 4x4 SPT
    What it going to take I wonder someone getting hurt from a faulty rear end and lawsuits before Toyota gets serious about addressing this problem
  15. Aug 7, 2017 at 6:54 PM
    #2595
    harrycary
    Harry
    Could be.
  16. Aug 7, 2017 at 6:57 PM
    #2596
    jg16
    Tennessee
    2016 White Off Road
    If they keep using this diff, they're gonna run in to more problems when this comes to a head.
    EB Group likes this.
  17. Aug 7, 2017 at 6:59 PM
    #2597
    nDub
    Lead Free Gasoline
    o_O
    I don't get it.
    shakerhood and smitty99[OP] like this.
  18. Aug 7, 2017 at 6:59 PM
    #2598
    harrycary
    Harry
    I noticed a lot of people are noticing more noise, right off the bat, with their replacement 3rd members.
    Here's a thought. It is Toyota's policy to replace all failed, mechanical components with Supplier remaufactured parts. Not in all cases, but many.... if Toyota is taking the returned 3rd members, rebuilding them, but reusing the ring and pinion, this could leave you with more noise due to the now 2 or more wear patterns in the gears. You should always replace the gears, when reshimming an already broken in gear set.
  19. Aug 7, 2017 at 7:01 PM
    #2599
    harrycary
    Harry
    Correct. Especially if a lawyer finds negligence.
  20. Aug 7, 2017 at 7:04 PM
    #2600
    nDub
    Lead Free Gasoline
    This would not surprise me.
    That or it's like musical diffs. They take one out, check it out, say it's normal and ship it off to an unlucky sob like me.
