3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Sep 25, 2017 at 9:18 AM
    #3161
    Stuffs
    Stuffs Active Member
    I'm just trying to understand how a heat insulator is going to solve noise issue.
  2. Sep 25, 2017 at 9:22 AM
    #3162
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    It's not.
  3. Sep 25, 2017 at 10:23 AM
    #3163
    YungTacoBoi
    YungTacoBoi New Member
    James
    2017 Magnetic Gray TRDOR DCSB 6MT
    Warrior roof rack
    Has anyone replaced their diff or electronic locker or axels or all three with aftermarket? If so does he howling stop?
    Stuffs likes this.
  4. Sep 25, 2017 at 12:57 PM
    #3164
    Berto
    Berto Braaaptist
    Berto
    Michigan
    '17 Inferno TRD 4x4 OR
    So I decided to change the diff fluid, great weather in Michigan today...
    tons of space back there to work if you drop the spare... anyway, it was low... by about 1/2 quart... going through the motions... the Off Road uses 4 quarts and mine ate it all up and it needs a bit more... so get 5 if you are doing it
  5. Sep 25, 2017 at 1:00 PM
    #3165
    Stuffs
    Cool. Let us know if it did anything. What type of fluid did you use?
  6. Sep 25, 2017 at 2:31 PM
    #3166
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I have asked this before, to no avail. With all the people regearing, I can't believe not one of them has ever had the howl and confirmed it being gone afterwards. It would really narrow things down as far as what's causing it.
    YungTacoBoi[QUOTED] and Berto like this.
  7. Sep 25, 2017 at 2:59 PM
    #3167
    YungTacoBoi
    James
    Warrior roof rack
    sorry to repeat a question but thank you for getting me on the same page. I would regear my taco and dump the warranty if I didn't just drop 9.5k on suspension for my '03 is300 and 15k on an LS3 and swap kit for my '93 240.
  8. Sep 25, 2017 at 3:19 PM
    #3168
    96ti
    96ti Well-Known Member
    2017 ACOR
    Just started noticing a faint howl on my 2017 OR-AC w/ 1600 miles in the 50-60 range.
    Definitely will start monitoring if it changes as miles add up.
  9. Sep 25, 2017 at 3:37 PM
    #3169
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I got an Sr5 longbed as a loaner while I get my squeaky leafs fixed.
    It is brand new with only 1k miles on it. It's a nice truck.... That howls.
    It's quieter that mine, but it's definitely there.
    shakerhood likes this.
  10. Sep 25, 2017 at 3:41 PM
    #3170
    tacoflavoredkisses1
    I think the guys that regeared had theirs go away.
    It's shit backlash and bad pinion / gear set up. Toyota just doesn't want to spend the money to fix it.
    98tacoma27 likes this.
  11. Sep 25, 2017 at 6:33 PM
    #3171
    lsutiger1
    lsutiger1 Well-Known Member
    Wilmington, NC
    2017 BLACK TRD OFF ROAD DCSB
    3inch lift,285/75/16 on method 301's
    Took mine to the dealer today and they said it was the carrier bearing and they had to ordered it. Said that was probably due to my lift,but they Installed the lift,so it on them. But it's still hard to me believe that carrier bearing went out with only 5000 miles on it!
    nDub likes this.
  12. Sep 25, 2017 at 6:37 PM
    #3172
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    32K on my SR5 4X4 V6. Still quiet.
    G.
    Berto likes this.
  13. Sep 26, 2017 at 7:15 AM
    #3173
    Berto
    Berto Braaaptist
    Berto
    Michigan
    Howl still there after fluid change and top off... just FYI, will wait to see the TSB, it does only happen on 5th and 6th gear for me.
  14. Sep 26, 2017 at 8:07 AM
    #3174
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Is it because you're usually around 55-60 mph in 5th and 6th gear? The only time im in 4th gear at that speed is when I'm accelerating and you don't hear and howling anyways. Downshift to 4th gear and feather the throttle and you'll hear it slightly over the engine
  15. Sep 26, 2017 at 8:35 AM
    #3175
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Mine is definitely just as loud in 4th as it is in 5 or 6.
    Tacowin1013[QUOTED] likes this.
  16. Sep 26, 2017 at 9:25 AM
    #3176
    Berto
    Berto Braaaptist
    Berto
    Michigan
    I tried to make it howl in 4th and no go, will try on my way home today again. Today was rough, traffic was moving in that (62-65 mph) speed on the ride to work making it very noticeable.
  17. Sep 26, 2017 at 11:41 AM
    #3177
    YungTacoBoi
    James
    Warrior roof rack
    Where'd you hear that it was a backlash issue? I have been trying to read through this thread but uhhhh there's a lot.
    Edit: not discrediting your claim, backlash means room for vibration which means noise.
  18. Sep 26, 2017 at 6:13 PM
    #3178
    Berto
    Berto Braaaptist
    Berto
    Michigan
    Heard from an engineer from one of the big three that this may be considered "normal" like a tuner in many trucks, not "right" but not defective, other than the noise, and no catastrophic failure should be expected...
    basically, at certain speeds, the differential size, spin and shape causes the "whine" like a whistle, when you blow with pursed lips a certain way. Which is why it only happens when feathering, and not at all points in the range.
    Changing the design is the sure fire way of repairing... said these issues are not exclusive to Toyota, and are not super common, but happen still, as we are all experiencing.
    Makes sense actually, may not be a flaw other than it's causing hum due to slack it's designed to have. The fact that 6MTs have this happen more often reinforced his comment... maybe a size change in what has the slack is the only solution as it changes the "musical" aspect of the differential... Thursday have a follow up with tech to keep looking into solutions...
    just sharing...
  19. Sep 26, 2017 at 6:43 PM
    #3179
    Stuffs
    Its definitely logical. I had a DSM AWD long time ago and the transfer case would make a whine at certain speeds, was told it was "normal" so I lived with it. Owned it till 140k miles and never had issues. Sound never got louder either but was always there.
    Crossing fingers its the same case with our trucks.
  20. Sep 26, 2017 at 6:45 PM
    #3180
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't think it occurs more in the 6 speed manuals, I heard it in an automatic I test drove and it was much louder than mine.
    Berto[QUOTED] likes this.
