3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Aug 10, 2016 at 3:41 PM
    #301
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    I was saving that for our second date.
    smitty99[QUOTED][OP] likes this.
  2. Aug 10, 2016 at 3:42 PM
    #302
    txags92
    Seriously though, what I am actually hoping is that something more definitive will come out of the cases that are farther along than mine here and I can take that back to them if or when the noise gets louder.
  3. Aug 10, 2016 at 3:45 PM
    #303
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It appears it is on their radar. That's a sign of hope. I'd expect within the next 6 months we might even see a TSB on this issue. It certainly won't be a recall without catastrophic failure and safety issues but a TSB to address those who complain of the symptoms would be the right move IMO.
    RBOGLE likes this.
  4. Aug 10, 2016 at 4:41 PM
    #304
    jg16
    jg16 Well-Known Member
    Tennessee
    2016 White Off Road
    I think Toyota will hear a lot more of this as people take their trucks in for scheduled maintenance. I know that's when they'll hear from me.
    RBOGLE and Inferno500 like this.
  5. Aug 11, 2016 at 8:20 AM
    #305
    cschu
    cschu Member
    Boston, Massachusetts
    2016 TRD Off Road
    I have this "hum" issue on my '16 TRD. After pushing the service manager to open a case with Toyota he finally did. They had my truck for 2 weeks and Toyota sent engineers out from California and Michigan to investigate. They finally replaced my diff with a new one which they told me is version 2 (original was version 1). They said there may still be a hum - which there is - and that Toyota is working on version 3 of the rear diff. No idea when ver 3 is coming out, though.
    Inferno500, MannyS and transworldmoto like this.
  6. Aug 11, 2016 at 8:34 AM
    #306
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I had my diff replaced and the issue is no different. It sounds like it may be getting worse as of late, but I can't tell.
  7. Aug 11, 2016 at 9:25 AM
    #307
    txags92
    On another note, when I called back, I asked them to go ahead and do the 1st oil change before I picked it up since I had a little over 6000 miles on it. When I picked it up, there was a sheet from the oil change crew checking off all of their inspection items. One was tire pressure. A few weeks ago, I had dropped the pressure in all 4 tires down to 30-31 (door sticker says 30 in all 4 tires), down from the 34 I had been running them. When I looked at the sheet, they had marked in 35 psi for all four tires. Curious about that, I switched the display over to tire pressure...and all four were reading 42 psi. I let it sit overnight and checked them again cold (or as close to cold as they will get overnight in Houston in August) using a hand gauge. Still 41 psi.
    Why on earth would authorized technicians at a Toyota dealer be overinflating tires above Toyota's own recommendation by 10+psi? I plan to bring it up with the service manager, but am I missing something? Seems like a dangerous thing to do for them from a liability standpoint. And then why record that they filled them 7psi lower on the check sheet?
  8. Aug 11, 2016 at 9:37 AM
    #308
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    many years ago as a teenager I remember watching a gas station mechanic pour sawdust into a rear end to make it quiet. He just probably wound up making greasy mulch. Crazy home grown remedy that someone probably thought up in order to sell that used clunker off the used car lot.
  9. Aug 11, 2016 at 10:03 AM
    #309
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Improperly calibrated air pressure gauge?
  10. Aug 11, 2016 at 10:12 AM
    #310
    db1984
    db1984 Well-Known Member
    Derek
    Bend, OR
    2023 Tacoma DCLB Off-Road Premium 4X4 w/ Adv. Tech.
    Full front and rocker PPF, ceramic coating, driver/passenger window tint (20%)
    Toyota does the same with mine when it's serviced. I was keeping my tires at 31 psi and they are always 35-36 psi after services. The pressure gauge in my truck is off by about 1-2 psi; it will read 37-38 psi. I always check them manually when cold, and the gauge/tires have always been off.
    smitty99[OP] likes this.
  11. Aug 11, 2016 at 10:17 AM
    #311
    smitty99
    Scottsdale
    Mine are off like this too
  12. Aug 11, 2016 at 10:23 AM
    #312
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    Bull shit! Get the plugs!
    There is a TSB (plugs) for the lca. Slight squeak will get worse...caused by improperly installed front (passenger side) bushing. Mine got progressively worse. Dealer replaced front bushings at 7800 miles and all quiet now. As you posted "hoping my diff doesn't decide to take a dump"...ditto here.
  13. Aug 11, 2016 at 10:41 AM
    #313
    jg16
    Tennessee
    2016 White Off Road
    Version 1,2,and 3?:annoyed:
  14. Aug 11, 2016 at 11:27 AM
    #314
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I totally buy them selling that line of BS, but I wouldn't accept it as the truth unless the part numbers changed.
  15. Aug 11, 2016 at 11:42 AM
    #315
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    It's not typical practice to change part numbers. If the piece still fits on the truck, chances are it maintains the same part number, just a new revision.
    If you change part numbers, you have to go through every design drawing, document, etc etc that references that part number and change it. If you just change revision numbers it is a lot less work because usually revision letters/numbers don't end up on drawings, bill of materials, repair manuals etc.
    smitty99[OP] and MasterPenguins like this.
  16. Aug 11, 2016 at 12:31 PM
    #316
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    Dealer confirmed mine but called it normal. Opened case with Toyota moments ago.
    Inferno500 likes this.
  17. Aug 11, 2016 at 12:35 PM
    #317
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    I smell an engineer....haha
  18. Aug 11, 2016 at 12:46 PM
    #318
    bert8
    bert8 Well-Known Member
    Brett
    Ontario
    2016 TRD Sport DCLB + Tech - Inferno
    Tint, tonneau, bed mat, derped
    I work in a car factory and you can tell how many times a part has been updated by the number near the end of the part. For example 01 is the first version. 08 changed 8 times. assuming yota and Honda are fairly similar.
  19. Aug 11, 2016 at 1:13 PM
    #319
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Blue tape all over my truck...
    "Do not wash" on the steering wheel.
    "Do not fill" on the washer fluid.
    Tape on the radio controls...
    Bastards never touch the tires though.
  20. Aug 11, 2016 at 2:42 PM
    #320
    jg16
    Tennessee
    2016 White Off Road
    "No one knows your truck better than genuine Toyota service technicians." Quote from owners manual.
