3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Sep 27, 2017 at 5:55 PM
    #3201
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I get that very often. I have no idea why. Some days it's pretty evident. Other days, I can't hear it at all (Windows up and radio off). I take the same back roads to and from work so it's not elevation, incline, or decline. Who knows.
  2. Sep 28, 2017 at 8:57 AM
    #3202
    Berto
    Berto Braaaptist
    Berto
    Michigan
    '17 Inferno TRD 4x4 OR
    No dice, still there but more faint. Almost not noticeable unless you are listening for it. Scheduling a follow up as tech was pretty helpful.
  3. Sep 28, 2017 at 9:55 AM
    #3203
    timkins42
    timkins42 Well-Known Member
    Tim
    Fishers, NY
    2021 Black Tacoma 4X4 TRD Sport Access cab
    None so far
    Thank you to all the previous posters. Mine just started howling at 3000 miles and I took it in for appraisal and it goes in for a new rear end next Tuesday.
    Berto likes this.
  4. Sep 28, 2017 at 10:13 AM
    #3204
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Keep us updated! Hope it's a final solution for you.
  5. Sep 28, 2017 at 11:13 AM
    #3205
    Berto
    Berto Braaaptist
    Berto
    Michigan
    New rear after first visit? Was it loud? Also, MT or AT?
  6. Sep 28, 2017 at 12:23 PM
    #3206
    EMT760-
    EMT760- Well-Known Member
    17 Tacoma TRD Offroad 4x4 DCLB
    I stopped by the independent driveline shop today. Went for a test drive with the service manager, oncue at 54 miles an hour he was able to hear the whining or humming sound.
    He believes it's the gear setup and would like to take it apart to see how the pattern is set up by Toyota to further diagnosis it.
    He told me he has at least five or six second generation Tacomas, that he does a month with bad carrier bearings on the second gen to come in for service.
    He suggested that I keep driving more of them at the dealership on test drives to determine if all them make the sound.
    He seemed very interested
    shakerhood, Berto and nDub like this.
  7. Sep 28, 2017 at 1:54 PM
    #3207
    tnt
    tnt Member
    2017 DCLB TRD
    I spoke with Professor Kelly from the:
    Department of Automotive Technology
    Weber State University
    here's a video that he did, while doing the Diff setup on a tundra.
    https://www.youtube.com/watch?v=dAqAqODmcj4&t=345s
    here's what he sent:
    I do know that Toyota Training came out with a new class on how to setup differentials a few years ago. I suspect it was in response to customer complaints for their Tundras, Tacomas, etc.
    Once the differential is removed from the truck, proper setup of a differential can take 2-5 hours depending upon the individual machining differences in each axle housing, differential case, gear, bearing, and shim. (Anyone who tells you that it does not take that long does not know what they are talking about and you should not have them work on your truck)
    I just helped one of my students setup the rear axle in his 2010 Chevrolet Camaro this week. It took 5 hours for us to get everything adjusted and setup properly with the correct contact pattern in the end. (And I know what I am doing, have all the proper tools, parts, and shims)
    I tell you this because most Toyota service technicians will not put that much effort into setting up an axle because the pay to perform that task under warranty is very low (~1.5 hours). Additionally, most service technicians do not know how to setup an axle properly (even after attending the class).
    Proper setup of a differential also requires that the dealership parts department has the proper shims in stock for the technician to use (This is rarely the case). I had to order shims from my local Toyota dealership to shoot that video you watched. It took more than a week to get the shims.
    There are almost 30 different shims that could be used in your differential, but only three of them will actually end up being used when the setup is complete.
    Proper axle/differential setup is becoming a lost art.
    What do I recommend that you do? Ask Toyota service department manager or Toyota customer support (Phone number in your owners manual) to send Toyota Field Technical Specialist (FTS) to investigate and repair your axle. They will have a much better chance of getting it done correctly.
    The basic steps for proper setup are as follows:
    1. Set the proper pinion bearing preload to specifications
    2. Set the ring gear backlash to specifications
    3. Set the proper side bearing preload to specifications
    4. Run a contact pattern check
    5. Make any pinion depth or backlash adjustments necessary to correct the contact pattern
    It does not sound that difficult, but it is.
    Feel free to share my contact information with any Toyota FTS if they need help/advice
    Best wishes!
    John D. Kelly | Professor
    1465 Edvalson St., Dept. 2404
    Ogden, UT 84408-2404
    Office: 801-626-7183 | Cell: 801-791-5807
    jkelly1@weber.edu | www.weber.edu/automotive
    zac2944, splitbolt, nartmot and 2 others like this.
  8. Sep 28, 2017 at 2:00 PM
    #3208
    EMT760-
    Tnt,
    Thanks for the PM and response. Very informative response from Professor Kelly there. That really outlines all the conditions and requirements to have a proper gear setup. Not only that but he shows that they had failed to do in the past correctly therefore the required training class.
  9. Sep 28, 2017 at 2:31 PM
    #3209
    nDub
    Lead Free Gasoline
    Having done multiple diffs I can attest this can take all day. Get to step 4 and if it doesn't look good.. start back at step one.
    It's a little easier with a third member, like Toyota has, so you can do it all on the bench.
  10. Sep 28, 2017 at 3:09 PM
    #3210
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Mr. Kelly's the man.
    Assuming it's a bad set up, I'd say it's more like the 5 hour estimate. If it was set up properly from the get go, they'd have a good starting reference point; they might/could nail it the first time. As is, they wouldn't, and would need at least 1 teardown to adjust things.
    nDub likes this.
  11. Sep 28, 2017 at 3:28 PM
    #3211
    Axxra
    Axxra Well-Known Member
    NC
    2017 DCSB TRD OR 4x4 6MT
    I watched that entire video. Neat info for sure.
  12. Sep 28, 2017 at 3:37 PM
    #3212
    Berto
    Berto Braaaptist
    Berto
    Michigan
    So are we under the impression this is the issue? I'll watch the video... but what's the cost to have someone do this vs doing it yourself, I'm a DYI if it will fix the issue and I can go on with my working car. Have rebuilt motorcycles and engines, so I am fairly handy with tools.
    nDub likes this.
  13. Sep 28, 2017 at 3:49 PM
    #3213
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    Don't these rear diffs come as a preassembled unit. There's not that much adjusting the mechanic can do to the gears on installation.
  14. Sep 28, 2017 at 3:49 PM
    #3214
    Stuffs
    Stuffs Active Member
    It strange to me that Toyota is willing to spend money replacing diffs rather than trying figure the cause. But them willing to fill their lot to wait on the recall parts shows they're not willing to take chances on a lawsuit.
    Could this howling just be the result of shitty work but not enough to create issues or premature wear down the line (where safety isn't impacted as well) and Toyota is too daft to tell us "sorry, we fucked up but you're gonna have to live with the noise..don't worry, it won't break on you"?
    EMT760- likes this.
  15. Sep 28, 2017 at 4:14 PM
    #3215
    EMT760-
    Like I said the driveline shop already knows from prior 2nd Gen's the drivelines, the carrier bearings in particular go bad. They do quite a few of them a month. TSB-0057-13 acknowledges the rear differential noise, as suggests checking fluid levels and replacing it.
    They seemed more shock that the newer trucks the 3rd gen are still having this issue.
    https://www.carmd.com/Tsb/Download/98089/T-SB-0057-13
  16. Sep 28, 2017 at 5:02 PM
    #3216
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I watched that whole thing. No wonder Toyota is flaking on fixing it. None of their techs are qualified to do that. They might have one or two but that's all they'd be doing for years if they recalled/tsb'd the truck.
  17. Sep 28, 2017 at 5:09 PM
    #3217
    EMT760-
    Toyota's logic.
    Let's just outsource to Mexico. We have a cheap " skilled labor force". We'll save a few bucks, and offer American consumers " award winning quality control". American consumers can't tell the difference anyways..
  18. Sep 28, 2017 at 5:15 PM
    #3218
    tacoflavoredkisses1
    They are assembled elsewhere and then bolted on. I think Toyota doesn't want techs opening them up to screw with them because it's complicated and time consuming.
    So they just replace them and hope the second one is better. Their bean counters get involved and probably figure changing it out once is worth it to reduce the chance that it's dangerously broken and increase the chance that the diff supplier got the second one right.
    Who knows? Maybe it's more complicated and we are all wrong , but Toyota hasn't proven overly competent in basic mechanical 101 stuff lately. I wish I had a quality gear/driveline shop near me.
  19. Sep 28, 2017 at 5:17 PM
    #3219
    tacoflavoredkisses1
    The diffs are sourced from elsewhere and my pos was built in San Antonio.
  20. Sep 28, 2017 at 5:29 PM
    #3220
    EMT760-
    Dude. This shop near me these guys are great. No bs attitude. I said Toyota Tacoma and their eyes rolled. They already know. They had a few 2nd gen's in their parking lot ha. No joke.
    They checked out my truck and remarked how they changed the differential design to give more support ?? Not sure. But when I said I was having issues at 1,300 miles. They were shocked. They figured Toyota would have gotten their shit together. Then he took me back and showed me a 2nd gen differential on a table as reference. He thinks their almost the same design, just the 3rd gen is beefed up.
    He wanted to take it apart to see how it was setup. But both of them were curious..
