3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Nov 27, 2017 at 3:47 PM
    #3621
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I concur just as loud in 4hi. Nuts
  2. Nov 27, 2017 at 6:12 PM
    #3622
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    I tried the same thing. No difference. Bummer.
    nDub[QUOTED] likes this.
  3. Nov 27, 2017 at 8:08 PM
    #3623
    FalconDriver
    FalconDriver Member
    AR
    ‘17 TRD OR DCSB
    Yes, that was my complaint and in all fairness to the dealership, they stepped up and agreed to fix it. We shall see if it actually helps....
    nDub and shakerhood[QUOTED] like this.
  4. Nov 28, 2017 at 9:23 AM
    #3624
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    I have noticed when it's below 40 degrees my replaced rear diff noise is quieter. At 30 degrees I can't hear it. Today it's 59°and it's back, very annoying.
  5. Nov 28, 2017 at 10:14 AM
    #3625
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That is so strange as since the weather has gotten colder my truck has got louder, go figure.
  6. Nov 29, 2017 at 6:50 AM
    #3626
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Exactly my thoughts too! I could barely hear it in the summer, if at all some days. Now that its gotten colder---I'm hearing it again. Maybe its viscosity of the diff fluid being thicker when cold? I have no idea...
    shakerhood[QUOTED] likes this.
  7. Nov 29, 2017 at 6:58 AM
    #3627
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Mine too...plus at lower speeds I hear a cyclical whirring. Most notable when I am coasting to a stop. Sounds like the R&P have some run-out or something and the mesh changes throughout the axle rotation. Not sure if it is at the pinion speed or axle speed.
    Omar RVA and shakerhood[QUOTED] like this.
  8. Nov 29, 2017 at 7:27 AM
    #3628
    nDub
    Lead Free Gasoline
    Mine is quieter now that we are getting into freezing temps at night.
    Not sure why.
    I think after a few miles the fluids in the diff would be up to temp and it wouldn’t matter what the outside temps are.
    I wonder if it’s a problem with these non greasable rear driveline u-joints. Anyone with these greasable u-joints have this problem?
    Mine definitely don’t have zerk fittings.
  9. Nov 29, 2017 at 7:43 AM
    #3629
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    probably cause the oil thickened up due to the cold weather. Toyota specs out a very thin 75w85 gl5 gear oil to get more MPGs my 2nd GEN also was specs at using it and when I did my 30k maintainence I noticed the 75w85 was very thin/watery as compared to a 75w90 mobil1 that I had on hand. the next 60k interval I will be using a 75w90 gl5 the other seems too thin, this could be why your howling noise is coming from.
  10. Nov 29, 2017 at 7:57 AM
    #3630
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Just spitballing here...
    Temp inversions causing sound to 'bend' upward or downward, propegating further or less, depending on the inversion.
  11. Nov 29, 2017 at 8:17 AM
    #3631
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Same boat. Not enough research done on the whirring noise - does it seem to mirror wheel speed to you? It seems barely audible outside the truck but super obvious inside.
    OA
  12. Nov 29, 2017 at 8:57 AM
    #3632
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I guarantee they will be inspected for abnormal wear. A growing heap of "scrapped differentials" throws big alarms in Toyota's lean manufacturing world. They most definitely will be looking at whether it is a legitimate problem or not. My concern has always been diff howls, goes back, gets inspected, no abnormal wear, ok diff now becomes a warranty replacement item for the next person who needs a diff replacement.
    Now, whether they decide it is a big enough issue to address depends on a lot more than the fact that it is annoying to the "select few" of us in this thread.
    I'm not even 100% convinced it was the diff itself, i always wondered if it had to do with the pinion angle. I swore up and down the noise went in and out as the angle changed when I was going over rolling bumps on the highway.
  13. Nov 29, 2017 at 9:06 AM
    #3633
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I wonder if some of the howling diffs taken out of one truck find their way into another truck as a replacement....just a thought.
  14. Nov 29, 2017 at 9:29 AM
    #3634
    pjensen641
    Boone, IA
    Seems more like wheel speed than pinion speed to me. Pinion spins essentially 4x faster than wheels....would expect higher frequency than I am hearing if it was pinion speed.
    Omar RVA[QUOTED] likes this.
  15. Nov 29, 2017 at 9:46 AM
    #3635
    Omar RVA
    Omar
    OR
    Agreed. My guess was something after the CV shaft. Hopefully other folks come forward with this one too.
    OA
  16. Nov 30, 2017 at 5:07 PM
    #3636
    nDub
    Lead Free Gasoline
    Just got my monthly email from corporate Toyota.
    Still no TSB for the rear end howling.
    Bummer.
    To be fair my person said they’d keep me in the loop at least monthly and they have been true to their word. So there’s that.
    shakerhood likes this.
  17. Dec 5, 2017 at 12:38 PM
    #3637
    SoloSpaceMonkey
    SoloSpaceMonkey Active Member
    2017 Tacoma Sport DCLB
    Hello TW! Long time lurker, first time poster.
    I just had my '17 DCLB in for it's 5k service and made sure to mention the issue. Mine has been doing it since day 1 and seems to make the noise between 50-55 when you are decelerating. The first time I was in, they replaced my door seals which clearly didn't help. I went back and had a service manager go with me and he knew right away what it was. He said his lead tech had told him to keep an eye out for this because Toyota had narrowed it down to the tempering of the bearings(best of my recollection) in the rear diff. Currently, I'm waiting for my new differential to come in and we'll go from there. Love the truck so far, hopefully Toyota can get it's 3rd gen growing pains worked out. I'll keep y'all posted.
    shakerhood, Riding Dirty and nDub like this.
  18. Dec 5, 2017 at 12:49 PM
    #3638
    bluenv
    bluenv Well-Known Member
    I'm happy to hear that Toyota is working on it, and that you get a new diff. For most here, they seem to deny it's a problem. I doubt they will ever admit it, but hopefully the will make changes to eliminate it in the future.
  19. Dec 6, 2017 at 12:30 PM
    #3639
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    This is what I was told today. A panel to hush the actual problem.
  20. Dec 6, 2017 at 12:35 PM
    #3640
    aero90
    Sorry. That's only for the manual trans, and I can confirm it does nothing to affect the noise everyone is talking about in this thread.
    Chris1261, shakerhood and hiPSI like this.
