3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 22, 2018 at 4:28 PM
    #4041
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Speaks the truth...
  2. Jan 22, 2018 at 4:36 PM
    #4042
    RBOGLE
    RBOGLE Well-Known Member
    Huntingtown, Maryland
    2016 Silver DCLB TRD Sport
    Hehe....well, my rearend is full. Just trying to understand the numbers from the manual but certainly agree that there’s no way I’m going to squeeze in more fluid that it will take :)
  3. Jan 25, 2018 at 4:11 PM
    #4043
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Built 01/17 I have 33k miles and it started around 500. Progressively it' gotten louder and louder. Just dropped it off at the dealer for the 2nd time.. 2017 Highlander in the meantime
  4. Jan 25, 2018 at 4:33 PM
    #4044
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    I just dropped mine off for the second time due to the howl, too. Case manager called me up last week and had already told my dealer it was coming back in ha She had me talk directly to the shop manager this time.
    Shop manager told me he had expected a fix from Toyota in December of 2017. He almost sounded frustrated that it didn’t happen. He didn’t specify what the fix in the works is/was though.
    This time they are actually checking the diff fluid level and are opening a case with the engineers. I don’t expect anything, but am glad the fluid will be checked. I wouldn’t have brought it back so soon, but the case manager already had it lined up.
    Mine started at mile 20 and I’m now at 950 ish.
    I’m jealous you got a loaner! I get the shuttle haha Hopefully we both will get some updates soon.
    Riding Dirty likes this.
  5. Feb 3, 2018 at 8:59 AM
    #4045
    Dirtridercrf250
    Dude you need to tell your dealer you need a rental to get home, and too work. That is below standards if they are not offering yuou a car.. this is all covered under the 36,000 mile factory warranty. Speak up man, I told them I needed a truck and the highander wasn't going to cut it. They gave me a 2017 sr5 base model, it' diff did not howl. I brought this up that mine has to be broken and they gave me the run around that the trd has a different axle in which it does and could be the underlying problem. Who knows
  6. Feb 3, 2018 at 9:01 AM
    #4046
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Agreed, they may not always give you a truck as a replacement but they have to give a loaner if its extended repair. Some dealerships try to take advantage of people by skimming on what they are supposed to do. If you ask, they'll give a loaner.
  7. Feb 3, 2018 at 11:52 AM
    #4047
    trazerr
    Oregon
    The thing is I drop my rig off the night before the appointment by choice. Plus, I have a 1st I still enjoy driving. I’m sure if I spoke up I’d get a loaner, but I need the dealer on my side. When/If Toyota comes out with a fix for the howl I want to be on good terms with this place. It’s just a few minutes down from my place, too. Quick lil shuttle ride.
    This second time they said they replaced the rear diff fluid just to make sure there wasn’t in pieces of metal or anything. They said it looked good. They again stated the howl is normal per Toyota, but a fix is in the works. Makes me laugh, but it is what it is. I’m just trying to enjoy my ride and avoid the 61-53 range.
  8. Feb 3, 2018 at 1:01 PM
    #4048
    Rotekk
    Rotekk Well-Known Member
    17 TRD 4x4 OR
    That's great they did that. My service department refused everything did not check fluid did not put ears on it or anything of the like. They confirmed it turned it over to Toyota field rep he confirmed it then quarantined it from any additional work and sent me packing. Corporate just said it's being labeled as normal and threw a platinum warranty on it which is worth nothing in my opinion seeing as I could barely get them to put the LCA plugs in. That took 5 trips and a master tech... I told the tech that I just wanted to buy the plugs outright before they put them in for me. I am really jealous of the people who have had some form of support.
  9. Feb 3, 2018 at 4:31 PM
    #4049
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    Before I bought my 16 I test drove a new 17 & 18. Both new trucks had the rear end whine from 50-60 mph. Especially on de-accel. My 16 does it from 50 to 65 when cruising & de-accel. I'm going to wait it out until a definitive fix is out.
  10. Feb 5, 2018 at 4:36 PM
    #4050
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    So after looking...
    Does anyone know of after market stock gear ratio ring and pinions for sale?
    Seems like the only support is for 4.88s.
    I mean if I am going to try and fix this howl I’m definitely not putting more Toyota gears in there.
  11. Feb 6, 2018 at 10:01 PM
    #4051
    BEETHMODE84
    BEETHMODE84 Well-Known Member
    Brian
    2018 TRD PRO CAVALRY BLUE
    trazerr, nDub, Taco16LB and 2 others like this.
  12. Feb 6, 2018 at 10:03 PM
    #4052
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Only for the double cab?! Access cab howls too! I guess one thing at a time.
    MOC221_ and shakerhood like this.
  13. Feb 6, 2018 at 10:12 PM
    #4053
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Good work! Sounds like a possible resonance fix.
  14. Feb 6, 2018 at 10:34 PM
    #4054
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Wonder which rear is the BD22, crazy that the rear springs are the culprit.
    hiPSI likes this.
  15. Feb 6, 2018 at 10:50 PM
    #4055
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It is. That's why Saturday afternoon driveway mechanics should maybe listen to the guys who design this stuff.
  16. Feb 7, 2018 at 7:23 AM
    #4056
    nDub
    Lead Free Gasoline
    Nice. I’ll have to contact my dealer for an appt!
    The Toyota master mechanics at my dealer diagnosed the sound as a bad pinion bearing before replacing the diff.
    Weird that they can put the truck up on a lift and cause spring resonance.
    I think this fix is just masking a bigger issue but if it quiets the sound I don’t really care as long as nothing fails.
    shakerhood and trazerr like this.
  17. Feb 7, 2018 at 7:32 AM
    #4057
    trazerr
    Oregon
    Not for the 2018’s?? I guess it would be a bad idea to recall every model all at once ha Baby steps, but at least they have acknowledge it!
  18. Feb 7, 2018 at 9:38 AM
    #4058
    SeniorSpan
    SeniorSpan Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    This TSB, T-SB-0013-18 Whine Noise From Rear of Vehicle, dated Feb 2018 makes me wonder just how much Toyota actually test vehicles before production.
    As a one waiting for a 2018 build date, I'm happy to see progress and I'm hoping this is the final be all get all fix.
    Cheers
  19. Feb 7, 2018 at 10:02 AM
    #4059
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    This only affects a very small percentage of vehicles. Sure, the problem seems enormous on this forum but there is a big difference between this forum and real life. My truck was the only one sold by my local dealership with this problem. They sell around 400 a year. Lucky me lol.
    trazerr and nDub like this.
  20. Feb 7, 2018 at 10:36 AM
    #4060
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    So they didn't tell you it was normal?
