3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Feb 7, 2018 at 10:39 AM
    #4061
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    This tsb, if correct, makes a lot of posts and certain posters look very bad.
    shakerhood and hiPSI like this.
  2. Feb 7, 2018 at 10:44 AM
    #4062
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have a tiny rural dealership that moves a fraction of what your Dealer does. The automatic OR they gave me for a 3 day extended test drive started howling at about 50 miles, my truck howls, and the salesman showed me a QS OR up on the rack swapping the rear out because they wanted to be up front about the trucks. Probably hard to get any real hard data from either your dealership or mine.
    nDub and hiPSI[QUOTED] like this.
  3. Feb 7, 2018 at 10:51 AM
    #4063
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Exactly. I posted many times in this thread about this not being only the gear set. Here's a few from Sept 2017:
    "Yeah same. It could be tooth profile at certain rpm, harmonic developed through case, backlash maybe but that usually gives you noise in many conditions, not just a narrow band of speed. It could be a lot of things but is it a problem is the issue. A constant howl is one thing. A slight whine for a second when letting off throttle is something else."
    Another:
    "I think their opinion is "I shouldn't have to fix it myself, it's Toyota's problem." Personally I think it's a gray area because, while it's an annoying noise, it probably is not detrimental to the reliability or durability of the truck. Truthfully, judging from that recording above, I don't know if resetting gear set properly is the real problem. Could be many things, like work hardening, harmonics, shim compression, qc or any myriad of things. From what I've read, some 2nd gens have this issue as well. I do know it only effects a small percentage of owners so apparently it is not a widespread problem."
    Casinater and shakerhood like this.
  4. Feb 7, 2018 at 10:56 AM
    #4064
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Somebody somewhere in Toyota has the stats. Personally I can only use the data I can get, and that is from my local dealer. Your dealer has a bunch, relatively speaking.
    shakerhood[QUOTED] likes this.
  5. Feb 7, 2018 at 11:01 AM
    #4065
    shakerhood
    Southern Ohio
    It's a strange issue for sure as you have listed several possible causes. Some guys had the rears swapped only to have the problem be the same, get worse, or be fixed altogether. You are correct that Toyota has to have that data on hand somewhere but we can only guess at the number, it had to be a percentage high enough to trigger a TSB.
  6. Feb 7, 2018 at 11:04 AM
    #4066
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Curious.....if this isn't for the 2018 MY, it would be interesting to have a 2018 owner look at their rear leaf springs to see if this harmonic damper is there from the factory.
    And WTF Toyota, Access Cabs need it too!
    Riding Dirty likes this.
  7. Feb 7, 2018 at 11:04 AM
    #4067
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    The TSB states its vibrations from the rear differential transferring through the chassis/body that's causing the noise. So isn't replacing the leaf springs not really fixing the ultimate cause of the noise? I'm not complaining I am happy that this should stop the damn howl haha The TSB just makes it sound like its a fix to cover up the real cause.
    I just hope they move on to 2018 DC's soon as thats what I have :burnrubber:
    nDub and hiPSI like this.
  8. Feb 7, 2018 at 11:06 AM
    #4068
    trazerr
    Oregon
    I have a 2018 with a howl from 61-53 on decel. I really hope I don't have the damper and new leafs underneath as this would mean the TSB won't fix the issue ha
    I was also under the truck last week and did not notice a damper. Then again I'm not really sure what one would look like for this fix.
    shakerhood likes this.
  9. Feb 7, 2018 at 11:23 AM
    #4069
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Every single gear box, transmission, differential or anything else that has gears and spins will cause a vibration. That cannot and will not be fixed. The key is to keep it small and damped. It sounds like the diff was setting up a harmonic through the leaf springs in certain situations on certain vehicles.
    shakerhood and trazerr[QUOTED] like this.
  10. Feb 7, 2018 at 11:28 AM
    #4070
    trazerr
    Oregon
    I understand that any mechanical rotating mass will have some type of vibes. I just don’t like that I got the one with more vibes than the rest ha
    I don’t have my manual with me, but I wonder what diff is BD22 is? My luck probably not the one under my SR5 haha Not that it matters much right now. I’m sure a TSB for the 2018’s will come after all of the 2017’s are taken care of. I guess I just got to be patient. Not something I am good at :rofl:
    hiPSI[QUOTED] likes this.
  11. Feb 7, 2018 at 11:54 AM
    #4071
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    hiPSI likes this.
  12. Feb 7, 2018 at 12:11 PM
    #4072
    shakerhood
    Southern Ohio
    I started looking around last night to figure out what rears are BD22, looks like it is the new 8.75s.
    pjensen641 and hiPSI like this.
  13. Feb 7, 2018 at 12:14 PM
    #4073
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    This makes me happy. Even though I replaced the truck that was making the noise with the exact same truck (different color) that doesn't make the noise, If it ever does I know there is a TSB for that.
  14. Feb 7, 2018 at 1:06 PM
    #4074
    EMT760-
    EMT760- Well-Known Member
    17 Tacoma TRD Offroad 4x4 DCLB
    All the trips I went to the dealership and was told " its normal" now Toyota has officially contradicted themselves. I wonder how many of these TSB fixes will be applied with the " dampening" fix will result in reduced or absent rear differential whine. If it does come back after a fix, it's apparent this is a band aid/ mickey mouse solution concealing a greater issue.
    "You can fool all the people some of the time, and some of the people all the time, but you cannot fool all the people all the time."
    Abraham Lincoln
  15. Feb 7, 2018 at 1:18 PM
    #4075
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Good job Toyota..I'm due for my 10k soon I'll make an appointment for it all
  16. Feb 7, 2018 at 1:22 PM
    #4076
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    That tsb link above shows the tsb is only for TRD pro/offroads doesn't it. I have a SR5, I need to know if this really works sooner rather than later
  17. Feb 7, 2018 at 1:26 PM
    #4077
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    I was thinking the same thing. I’ve been waiting, sometimes more patiently than other times, for a fix. As long as this is the fix, I’m happy.
    hiPSI likes this.
  18. Feb 7, 2018 at 1:31 PM
    #4078
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No, it's for:
    All model doublecabs with manual transmissions
    All TRD Off Road and TRD Pros auto or manual.
    It has to do with the larger differential size 8.75's, not the smaller 8.4's.
    shakerhood and trazerr like this.
  19. Feb 7, 2018 at 1:34 PM
    #4079
    trazerr
    Oregon
    So SR5's are not part of this TSB...?
    Edit: Never mind, did not see the new posts ha
  20. Feb 7, 2018 at 1:37 PM
    #4080
    trazerr
    Oregon
    At least not yet I hope! ha
