3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Feb 16, 2018 at 12:37 PM
    #4181
    zac2944
    zac2944 Well-Known Member
    Rochester NY
    2016 TRD OR DCLB
    Says right in the TSB "caused by rear differential vibration transferring through the chassis and body". So it is not "in" the springs as much as the springs are transmitting the noise from the diff and into the cab. At least that's the way I'm reading it. Makes sense to me. Given that, you then need to reduce the transmission of diff noise. They probably were able to get significant noise reduction in the LB cab with the frame dynamic damper only and without needed to replace the springs, but found that on the SB it wasn't enough and required new springs that were tuned to reduce transmission of the differential noise. Noise and harmonics are interesting in that small changes in mass or stiffness can drastically effect things. At lease that's been my experience as a manufacturing engineer working with large equipment.
  2. Feb 16, 2018 at 1:58 PM
    #4182
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Went to dealer today. They're going to call when the parts are in!!!:dancingbacon: They did bring up the fact that I'm past the 36K but agreed to fix it under "good will" o_O since they had diagnosed this like 35K ago.
  3. Feb 17, 2018 at 7:21 AM
    #4183
    Bryan502
    Bryan502 New Member
    Master mason
    2016 Toyota Tacoma TRD OR DC
    None
  4. Feb 17, 2018 at 7:25 AM
    #4184
    Bryan502
    Bryan502 New Member
    Master mason
    None
    Mine is doing the same thing. Sounds like we have the exact same truck....2016 Toyota Tacoma, TRD, Off Road, Short Bed, Double Cab. I get the truck to 55-65 mph...on and off the throttle...can hear a whining noise from the rear. Dealership drove the truck, confirmed the noise, but said they don't have a fix...and they told me a fix is coming. It's been a year now....still nothing from them. May have to sell....and take a loss.
  5. Feb 17, 2018 at 7:27 AM
    #4185
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Welcome to TW. There is a TSB for it:
    https://www.tacomaworld.com/threads/new-tsb-whine-noise-from-rear-of-vehicle.532809/#post-17089595
    I agree the noise is annoying.
  6. Feb 17, 2018 at 9:01 AM
    #4186
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    Tsb are good till 85k. Well at least they used to be.
  7. Feb 17, 2018 at 10:06 AM
    #4187
    WOTaco
    Maybe but this is from the bottom of this TSB;
    APPLICABLE WARRANTY
    •  This repair is covered under the Toyota Basic Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
    •  Warranty application is limited to occurrence of the specified condition described in this bulletin.
    shakerhood likes this.
  8. Feb 17, 2018 at 10:35 AM
    #4188
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the only things that were around 80k were emission equipment parts.
    Taco16LB likes this.
  9. Feb 17, 2018 at 12:10 PM
    #4189
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    If your issue as properly documented I think they would have a hard time defending NOT doing the TSB. Unless you waited another couple of years and 150k+ miles.
    EdgeCrusher and shakerhood like this.
  10. Feb 17, 2018 at 12:34 PM
    #4190
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    the brake pedal buzz is there as a warning to the driver not to ride the brakes and not overheat and prematurely wear out the brake pads by riding the brake pedal.
    Riding Dirty and hiPSI like this.
  11. Feb 17, 2018 at 1:56 PM
    #4191
    shakerhood
    Southern Ohio
    Is that something new for 2018 with TSS? Never heard of it before and not seen anything in the Owners Manual, thankfully my Brake Pedal does not Buzz nor did any of my previous 3 Tacomas.
    nDub likes this.
  12. Feb 17, 2018 at 2:01 PM
    #4192
    nDub
    Lead Free Gasoline
    Seriously
  13. Feb 17, 2018 at 2:26 PM
    #4193
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Be good...
  14. Feb 17, 2018 at 2:30 PM
    #4194
    BillsSR5
    bill
    2014 SR5
    the buzz becomes more pronounced after the pads wear to the indicators and will alarm(buzz) the owner to replace the front pads, this is caused by unnecessary riding of the brakes most of the time.
    shakerhood[QUOTED] likes this.
  15. Feb 17, 2018 at 6:41 PM
    #4195
    nDub
    Lead Free Gasoline
    I think the buzz on the taco has more to do with the electric assist brake booster.
    2nd gen has it too as far as I can tell.
    Which like anything else can be mild on some trucks and super bad on others.
    I only feel it (slightly) when I’m driving in stop and go city traffic.
    Have not ever experienced buzz from low brake pads. Mostly a squeal from that squeak pad that comes with them.
  16. Feb 17, 2018 at 8:07 PM
    #4196
    shakerhood
    Southern Ohio
    I am really glad that my truck makes no buzzing sounds from the brake pedal, if the TSB gets rid of the Howling Rear then I am gonna have a nice quiet truck!!!
  17. Feb 17, 2018 at 8:12 PM
    #4197
    nDub
    Lead Free Gasoline
    I feel it more than hear it.
    I agree though, my only gripe as been this rear end howl. Big fan otherwise!
  18. Feb 17, 2018 at 8:16 PM
    #4198
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    I test drove a 2017 TRD Off road a year or so ago. I didn’t even make it out of the dealer parking lot before I noticed the buzzy brake pedal. It wasn’t even on my mind as something to look for, but it was buzzy enough it stood out. It buzzed roughly every 3 out of 5 brake presses. It actually kind of annoyed me, but I heard most don’t buzz that much. I’d prefer that over the rear end howl I have now though haha
    shakerhood and nDub[QUOTED] like this.
  19. Feb 17, 2018 at 8:25 PM
    #4199
    tacoflavoredkisses1
    Lol
    jamonsote likes this.
  20. Feb 18, 2018 at 6:31 AM
    #4200
    BillsSR5
    bill
    2014 SR5
    sounds like more of a underlying health issue if your foot tingles and goes numb, usually associated with reduced/restricted blood flow like hardening of veins or arteries, i would see a Doctor if your foot tingles and goes numb and is uncomfortable just by applying your brakes.
