3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Mar 3, 2018 at 8:10 AM
    #4361
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I honestly don't know. I'm 100% sure though that the new springs are a revision of the existing spring, meaning, something was changed like material spec, slight geometry change or some other small thing that, when tested, was found to alleviate or at least greatly reduce the resonance. The ones that have this noise that would not get a new spring means that this revision did not work on those units. The isolator and the foam did work though.
    Toyota would not take a spring destined for another vehicle and use it on the Tacoma. Easier to just modify, or revise, the existing springs.
    shakerhood likes this.
  2. Mar 3, 2018 at 3:09 PM
    #4362
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Also could have tweaked the leaf spring bushing's polymer, lower the durometer (hardness) so it isolates more. Kinda like if you upgrade to poly bushings, you get more feel and vibration.
    If Toyota works like our business, they could manufacture a batch (feeder supply) for the initial replacements. Those springs get sent back, checked to see if they fall in line to new specs, install new bushing and repainted to keep the TSB's going to minimize cost.
    hiPSI[QUOTED] likes this.
  3. Mar 3, 2018 at 3:36 PM
    #4363
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    The "upgraded" leaf packs better not squeak when you get them dirty... ppl will be screaming at Toyota for replacements.
    That is not a fictional scenario. I was chastised for suggesting peeps use a pressure washer and then maybe some sort of lube spray to quiet them suckers down. Worked every time BTW.
  4. Mar 6, 2018 at 8:52 AM
    #4364
    Critical05
    2017 DCLB TRD OR
    With the whine gone and the ECT on all the time mod, I'm finding don't have much to complain about these days.
    Just waiting for the next thread to key me into something else I can find annoying. Slightly got into the swish noise when depressing the brake pedal but I keep forgetting about it.
    tacotech72, slamson00 and Lt. Dangle like this.
  5. Mar 6, 2018 at 10:04 AM
    #4365
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    After a week and 400 miles or so I stand by my initial assessment of the TSB. Better but definitely not gone.
  6. Mar 6, 2018 at 10:13 AM
    #4366
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    A set of MTs should fix the rest... ;). I’m not getting mine done until next week. I drove my Yukon yesterday and it has a similar howl/whine at the same speeds, but it’s not as noticeable because the vehicle is church pew quiet.
    hiPSI and nDub[QUOTED] like this.
  7. Mar 6, 2018 at 10:17 AM
    #4367
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    I really hope they extend this TSB to my model sooner than later. I did a trip over the mountains and back this past weekend. Every downhill section I was at 50-60mph due to corners, traffic, etc. That howl gets annoying real quick when you have to listen to it for 15 to 20 secs at a time ha Drove me bonkers and even annoyed the lady. Come on Toyota! Haha
    zac2944, Rotekk, nDub and 1 other person like this.
  8. Mar 7, 2018 at 5:10 AM
    #4368
    BatmanOK
    BatmanOK Member
    Brian
    2017 Tacoma TRD Off Road
    Took my truck in Monday to have the TSB fix done, they took my truck apart and then called me and said the kit they received didn't have all the right parts and they would have to order them. So they put my truck back together and hopefully in the next week or so I will take it back and get this fixed.
  9. Mar 7, 2018 at 6:38 AM
    #4369
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I had the TSB done yesterday. Overall about a 75% reduction of the whine but it also greatly narrowed the MPH "window" in which I hear it. I never had anything done to address this since I first brought this to Toyota's attention, I've just been living with the annoyance for many thousands of miles. Overall I'm pretty happy, if the whine was where it is now when I bought the truck I probably would have noticed it but not been concerned. Also, If I ever want to sell the truck a prospective buyer will not be like "WTF is that noise?". The service writer made a point to tell me that the sum of the parts was about $2000, I think he was just surprised at the extent to which Toyota went dampen a noise. I have severe "dealerphobia" but theses guys have been pretty straight up through and through. They got Toyota corporate/engineers involved way back when and since my case was so well documented, they did the TSB even though I was past the 36k period.
    nDub, shakerhood, hiPSI and 2 others like this.
  10. Mar 13, 2018 at 9:40 AM
    #4370
    Mountainmike87
    Mountainmike87 Well-Known Member
    2017 silver TRDOR
    No issues with the 4runner. There were other things I didn't like about the Tacoma. Like the weird jumpy throttle and lack of torque. The stalling and hesitation pulling out into traffic. Etc etc haha. But yes the 4runner is great in every aspect.
  11. Mar 15, 2018 at 6:11 PM
    #4371
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    Update: I dropped the truck off first thing this morning to have the TSB done. They called at about 4:00pm to let me know it was ready so I picked it up after work. It was a short drive home, but I think the noise is about 90% gone. I had the radio and AC off and had to really, really listen to hear anything. It was loudest at about 57mph before and now that's about the only speed I hear it and it's VERY faint. It didn't seem like mine was as loud as some of the others to begin with, so for me, I think it will be fine. Hopefully others will have good results as well.
    shakerhood and trazerr like this.
  12. Mar 15, 2018 at 6:19 PM
    #4372
    trazerr
    Oregon
    Good to hear! At what mph range did it howl before the TSB?
  13. Mar 15, 2018 at 6:32 PM
    #4373
    Taco1701
    William
    GA
    It would start around 60-61mph and was loudest at about 57mph and would quit at about 53mph as the truck slowed. It only did it if I let off the gas and let the truck coast. Now I can only hear it right around 57mph and it's really faint. If I wasn't actively trying to find it after the TSB, I probably wouldn't have noticed it. With the air on or radio on, I can't hear it.
    trazerr[QUOTED] likes this.
  14. Mar 15, 2018 at 6:36 PM
    #4374
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Replace the rear diff fluid with full synthetic
  15. Mar 15, 2018 at 6:40 PM
    #4375
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe the Factory 75w-85 is already Synthetic and changing it out won't get rid of the Howling as many guys tried.
    hiPSI and The Real Moondog like this.
  16. Mar 15, 2018 at 6:59 PM
    #4376
    trazerr
    Oregon
    That is the exact range that my truck howls at. 61 all the way down to 53. I think peak for me may be around 57, but its loudest between 55-58 for sure. It used to be just on decel, but it now does it a tiny bit when feathering the throttle. Not nearly as loud as when the truck coasts down though.
    Now I just have to hope they extend to 2018 non-TRDs! Or drop $250 or so and do it myself ha
  17. Mar 15, 2018 at 7:09 PM
    #4377
    Grossomotto
    2017 4WDV6LB6MT
    Nobody knows if the OE 75W85 is full synthetic, but you would think it is for the price. The weight is only for CAFE standards, you can use 75W90 which will become lighter with use anyway.
    So will the 85W, which could be a theory that it lightens up with use and creates a whine like many are experiencing.
    Toyota would never say the 85W is the problem, it would be a disaster. I’ve only seen 80W and 85W gear oil for motorcycles, rarely ever in a 4X4 truck.
    I changed out fdiff, rdiff, mtrans to Redline full synthetic 75W90 and MT90 at 500 miles. Will soon change the tcase with the required weight full synthetic. Everything is quiet as can be.
  18. Mar 15, 2018 at 7:19 PM
    #4378
    shakerhood
    Southern Ohio
    Was it Howling badly before you changed everything out? Toyota's TSB solution is swapping Rear Springs and adding Sound Deadening Material.
  19. Mar 15, 2018 at 7:29 PM
    #4379
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Naw man, got M1 full syn in mine. Still does it from 54-60 mph. It's not a gear wear issue. It's a resonance issue.
    The Real Moondog and shakerhood like this.
  20. Mar 15, 2018 at 7:37 PM
    #4380
    Grossomotto
    2017 4WDV6LB6MT
    No howling, looks like resonance like edgecrusher says below.
    I’m just a synthetic fluids fanatic, that’s all.
    shakerhood[QUOTED] likes this.
