3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Apr 27, 2018 at 9:23 AM
    #4481
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Awesome, thanks! Mine is present from 53-61 and loudest at 57. Hoping for the same or similar results! I already had my rear exterior completely out as well as the rear cab mounts. Once I have the TSB parts in hand this should be cake for me ha ha
  2. Apr 27, 2018 at 12:31 PM
    #4482
    trazerr
    Oregon
    Well, purchasing dealer will not help with the parts. They said they can’t because another dealer is involved with my Tacoma and the rear diff howl. He said this causes their hands to be tied. I feel that’s not really how that works? But oh well. I’ll order the parts Monday and go from there.
  3. Apr 27, 2018 at 1:22 PM
    #4483
    RBOGLE
    RBOGLE Well-Known Member
    Huntingtown, Maryland
    2016 Silver DCLB TRD Sport
    The parts are MUCH cheaper online than through dealer. I think the retail price for each Damper is 125 or so, I paid 81 each....similar discount for the other pieces if you choose to get them. Also, seeing people waiting weeks to get them, which I thought I would too, but they arrived in 4 days.
    trazerr[QUOTED] likes this.
  4. Apr 27, 2018 at 1:53 PM
    #4484
    trazerr
    Oregon
    Yeah, the parts have been in my camelback cart for a few weeks now ha little over $225 there. Now that I know my dealer won’t help I’ll be pulling the trigger. Hopefully howl free (or close to it) by next weekend!
  5. Apr 29, 2018 at 9:52 AM
    #4485
    trazerr
    Oregon
    After shipping parts were about $237 for me. However, I used paypal and Chase which will give me 6% back. The parts will end up costing me about $222.
    Can't wait to get them installed! Hoping for some good results ha
    RBOGLE[QUOTED] and shakerhood like this.
  6. Apr 30, 2018 at 4:58 AM
    #4486
    RBOGLE
    Just did a 300 mile trip and not even a hint of a whine the whole way!
  7. May 1, 2018 at 9:39 AM
    #4487
    guitars&tacos
    guitars&tacos Well-Known Member
    North Metro Atlanta
    2018 White TRD 4x4 Off Road 6 MT
    So guys, forgive me for not scrolling all 225 pages of the thread. My 2018 4X4 OR makes a faint, but mind-losingly (is that a word?!) noise that sounds like: "wooooooooooohhhhhhhhhhhh."
    Is this what you guys are refering to? Drives me insane!
  8. May 1, 2018 at 9:41 AM
    #4488
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If it occurs between 50 and 60 MPH then most likely yes, mine is loudest at 54.
  9. May 1, 2018 at 9:42 AM
    #4489
    Rotekk
    Rotekk Well-Known Member
    17 TRD 4x4 OR
    Yeh that sounds like it. 50-65mph range. They will patch it with dampeners and foam. No TSB for 2018s AFAIK or ACs for 16/17s.
  10. May 1, 2018 at 9:49 AM
    #4490
    guitars&tacos
    North Metro Atlanta
    Yep it's definitely within this range of speed that mine makes that noise. Thanks everyone.
  11. May 1, 2018 at 10:08 AM
    #4491
    trazerr
    Oregon
    I’ve had two dealers turn down fixing my 2018. Yours is an Off-road though so maybe you will have better luck. Wouldn’t hurt to ask them.
  12. May 1, 2018 at 10:13 AM
    #4492
    Shellshock
    Iowa
    I've already got dynamat in the rear of my cab so that takes care of half what the dealer does (and probably more effectively.
    Changed my rear diff fluid about a week ago and the howling is almost completely gone in my truck. I've heard it a couple times but its much more faint and occurs in a smaller range than before. I think I'll be content unless the rear diff blows up.
  13. May 1, 2018 at 10:13 AM
    #4493
    Rotekk
    17 TRD 4x4 OR
    You should still definately get it documented. I think it's pretty sad myself when you have people buying their own parts and putting them on because Toyota will not address the issue that has been identified.
    The TSB still doesn't sit well with me but I guess its better than nothing . The rear end is just cheaply made. Get it documented and bitch. Hopefully the numbers dont lie and they will fix the root cause with an engineering fix at the factory and not an easy out fix.
  14. May 1, 2018 at 10:22 AM
    #4494
    trazerr
    Oregon
    How loud was your howl before and after the dynamat and at what mph range? I was going to install sound deadener at the same time I do the TSB, but heard the sound deadener doesn’t help much with the howl.
  15. May 1, 2018 at 10:27 AM
    #4495
    Shellshock
    Iowa
    Definitely loud enough to be annoying in the 50-60 mph range. I've noticed a difference from the dynamat, but I do an extensive amount of driving so I was looking to cut down on some of the road noise since I run the rear seats folded down almost 100% of the time.
    I've got a single layer of dynamat from the storage bins back and up the rear of the cab.
  16. May 1, 2018 at 10:59 AM
    #4496
    trazerr
    Oregon
    I will probably do the same if the TSB doesn’t help a ton. Mine is pretty loud so I bet it will be needed ha
  17. May 1, 2018 at 11:05 AM
    #4497
    Thomas15
    Thomas15 Member
    2017 Tacoma trd Sport 4x4
    I just dropped of my 2017 trd spoert 4x4 at the dealer for howling noise between 40-50mph. test drove with tech and he said he heard it but thinks it may be wind noise or normal. I said no way it just started at 9,327 miles. its also there for another noise. they have been very helpful so Im hoping for a good outcome foreman and advisor are good dudes
  18. May 1, 2018 at 11:10 AM
    #4498
    Rockytaco970
    Rockytaco970 Well-Known Member
    2018 TRD Sport
    my 2018 sport access cab M/T is getting worse, only has 4k on it. starts at 55, gets real loud at 60 and quiets down above 65 again. I think I need to take it in and get it on the dealerships radar. I would change the fluid but it don't want them saying its my fault for doing so.
    shellshock-what oil did you use?
    anybody try a heavier weight oil? 75-140?
    TIA
  19. May 1, 2018 at 11:17 AM
    #4499
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Several throughout this thread have with no change. I would say this guy's dynamat is what helped him.
    shakerhood likes this.
  20. May 1, 2018 at 11:26 AM
    #4500
    Shellshock
    Iowa
    I wouldn't worry about getting blamed by the dealer for changing the fluid. It's routine maintenance just like oil changes.
    Amsoil 75w-90
    https://www.amsoil.com/shop/by-product/gear-lube/severe-gear-75w-90/?code=SVGQT-EA
    Used this thread
    https://www.tacomaworld.com/threads...-manual-transmission-6mt-fluid-change.481719/
