3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Aug 29, 2018 at 4:20 PM
    #4601
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I just got the tsb in my 2018. It did NOT fix the problem. The two loudest spots pre-tsb are slightly quieter but still present. And now there are additional spots with the problem. All in all, I'd say it was better pre-tsb, but that's subjective. Either way, it's still howling.
  2. Aug 29, 2018 at 4:23 PM
    #4602
    NMTrailRider
    New Mexico
    Any luck?
  3. Aug 29, 2018 at 4:30 PM
    #4603
    NMTrailRider
    New Mexico
    Has anyone here pursued the lemon law for this issue yet?
  4. Aug 29, 2018 at 4:36 PM
    #4604
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Just so you guys have an idea I got the tsb done last week and my howling which used to be between 50 to 70mph and I could hear it with music volume around 20 to 25. Now I can only hear it around 60 to 62 MPH and only if music is off.so significantly improved
    shakerhood likes this.
  5. Aug 29, 2018 at 5:04 PM
    #4605
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Yes. A guy recently got a buy back.
  6. Aug 29, 2018 at 8:58 PM
    #4606
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Low range off road makes one
    http://www.lowrangeoffroad.com/toyo...d-pinion-spacer-8-clamshell-tdi-ss-8clam.html
  7. Aug 29, 2018 at 9:16 PM
    #4607
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  8. Aug 29, 2018 at 9:17 PM
    #4608
    Grossomotto
    2017 4WDV6LB6MT
    Ok I thought it was for the 8” rear.
  9. Aug 30, 2018 at 8:53 AM
    #4609
    weezykid
    weezykid Well-Known Member
    2023 TRD OR DCSB 4wd
    Interesting. When I get back from my trip, Toyota will be getting a call to see what is or can be done about this as it is not normal.
  10. Aug 30, 2018 at 8:14 PM
    #4610
    NMTrailRider
    New Mexico
    FYI-- If you have a very recent build date, the sound deadener is already installed on the C-pillars from the factory. This info came from my dealer, who got the info from some kind of regional service director (can't remember the exact title).
  11. Aug 30, 2018 at 9:39 PM
    #4611
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Wonder if they changed out the rear springs too
  12. Aug 30, 2018 at 10:12 PM
    #4612
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    This is def outside my area of expertise, but could it be just a matter of adjustment or using different shims or even a counterweight to eliminate the harmonic sound? It looks like the leaf springs help radiate the sound which is why they get replaced in the TSB.
  13. Aug 30, 2018 at 11:07 PM
    #4613
    NMTrailRider
    New Mexico
    My guess would be yes, as they didn't change my springs and told me it didn't require them, as per the TSB/VIN #'s. Build date 7/18.
    The only thing on the TSB for my truck was the new cab mounts. And as mentioned, it didn't fix the problem.
  14. Aug 31, 2018 at 3:18 AM
    #4614
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    I complained and called Corp every time I took my 17 TRD OR to the dealer.. Corp offered to extend my power train warranty to 6years 200k to being my confidence up can't beat a deal like that
    NMTrailRider likes this.
  15. Sep 3, 2018 at 11:34 AM
    #4615
    NMTrailRider
    New Mexico
    So after multiple attempts at a fix, yours is still making the noise?
    Does anyone know if there's been any class-action chatter about this issue? Seems to be fairly widespread.
  16. Sep 3, 2018 at 11:39 AM
    #4616
    ARCOVT16
    ARCOVT16 Well-Known Member
    VT
    2016 DCLB SR5
    Icon ext Travel Coilovers, SPC UCA, SCS 16x8 Wheels, 285/75r16 G003, Toytec 3leaf AAL, Icon 2.0 Remote Reservior, Toytec Axle shims, Toytec Front Diff drop, Timbren U-Bolt flip kit, Clazzio Black Seat covers.
    have your rear wheel bearings been checked?
  17. Sep 3, 2018 at 11:39 AM
    #4617
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    I have only heard of buy-backs from Toy.
    NMTrailRider[QUOTED] likes this.
  18. Sep 3, 2018 at 11:40 AM
    #4618
    NMTrailRider
    New Mexico
    Anyone had a fix attempted by the dealer three or more times and still have the noise?
  19. Sep 3, 2018 at 11:42 AM
    #4619
    Patrick1046
    One guy got two new diffs and they both had the howl. Toy said it must be normal and denied the third. He traded out.
  20. Sep 3, 2018 at 4:32 PM
    #4620
    Patrick1046
    Seems to be a lot of OR models with the howl over at car complaints.com.
