3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Nov 25, 2018 at 6:25 PM
    #4921
    taco7
    taco7 Member
    SLC, UT
    Tacoma, short bed TRD
    SAW front shocks, puck rear, CBI sliders, All Pro plate bumper, Mile Marker winch, Bud Built skid plate (1).
    I just purchased a used 2017, TRD offload with 18,000, after being without a Tacoma for 2 years or so (previous was a 2005, but went to a 4Runner). I didn't know about the issue during the test drive, but it is howling from 25mph-?? currently. I bought the truck with a bed rack/RTT, so I figured by removing it, it would be better...it wasn't. I'll be taking it to the dealer this week. It is obnoxious!
    Does anyone see any issues with this being taken care of for a second owner, even though the truck is still under warranty?
    Thanks for all of the great info here!
  2. Nov 25, 2018 at 6:36 PM
    #4922
    yjgfikl
    yjgfikl Active Member
    2017 Tacoma TRDOR DCSB 4X4
    Just saw this thread come back up. I had the TSB done and the howl is significantly less, but still present somewhere between 50-60mph under light throttle. The TSB didn't completely eliminate it for me either.
  3. Nov 25, 2018 at 6:53 PM
    #4923
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would think they will perform the TSB for you without any issue.
    The Real Moondog likes this.
  4. Nov 25, 2018 at 7:25 PM
    #4924
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Do you think that the speed he is experiencing the howl at could also be the LCA howl since this is a 17? If it’s an early 17 that could contribute to a howl at lower speeds if the LCAs are not plugged.
  5. Nov 25, 2018 at 8:02 PM
    #4925
    shakerhood
    Southern Ohio
    That is a possibility, after rereading his post it sounds as if he is having low speed noise versus the common 50 - 60 MPH Howling.
  6. Nov 25, 2018 at 8:04 PM
    #4926
    The Real Moondog
    Moondog
    That was my first thought. The lower speed howl would seem to indicate unplugged lower control arms. It may be worth him checking out and that’s an easy fix.
    shakerhood[QUOTED] likes this.
  7. Nov 26, 2018 at 6:50 AM
    #4927
    taco7
    taco7 Member
    SLC, UT
    All, thanks for the replies....what is an unplugged LCA? I tried searching for it. Many thanks.
  8. Nov 26, 2018 at 6:53 AM
    #4928
    The Real Moondog
    Moondog
  9. Nov 26, 2018 at 6:55 AM
    #4929
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
    I’m assuming there’s a TSB for this?
    Edit: didn’t see the above post
  10. Nov 26, 2018 at 6:55 AM
    #4930
    The Real Moondog
    Moondog
    Yes.
  11. Nov 26, 2018 at 6:57 AM
    #4931
    The Real Moondog
    Moondog
  12. Nov 26, 2018 at 6:59 AM
    #4932
    DeltaBravo
  13. Nov 26, 2018 at 7:25 AM
    #4933
    The Real Moondog
    Moondog
    Depending on when your truck was built they may be plugged from the factory. Just crawl up under it and check. Mine were plugged but even the build date theory is hit and miss as some are plugged and some are not. We had a thread on this somewhere but I can’t seem to find it. Best of luck to you.
  14. Nov 26, 2018 at 7:32 AM
    #4934
    btaco623
    btaco623 Well-Known Member
    Central Ohio
    '17 TRDOR
    Hood Blackout, 5100,LED Low's, SuperSprings
    If unplugged tape them shut with duct tape temporarily to test the theory. Mine is an early 2017 build, was not plugged. Also had the howl tsb done. Did not stop the howl. Somewhat quieter, but still there, can still hear it over the radio.
  15. Nov 26, 2018 at 9:39 AM
    #4935
    shakerhood
    Southern Ohio
    My truck was also plugged from the Factory.
  16. Nov 27, 2018 at 5:33 PM
    #4936
    Eric M
    Eric M New Member
    I have a 2017 long bed and have had the service bulletin done. I don't think it changed the whine much at all, maybe 10% less whine. Is there any fix out there yet? I am seriously considering getting rid of the truck because of this. Not that the noise is that horrible, but it is annoying, and things make noise when they aren't working righ. To me it seems this will be a point of failure at some point.
    Anyone tried the lemon law approach?
  17. Nov 27, 2018 at 5:50 PM
    #4937
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    A new rear differential may make your truck quiet. Some have had theirs replaced and it was worse though. I’d open a case with corporate and let them know the TSB did not help much.
    shakerhood likes this.
  18. Nov 27, 2018 at 5:52 PM
    #4938
    Eric M
    Eric M New Member
    How do you open a case with corporate?
  19. Nov 27, 2018 at 5:53 PM
    #4939
    trazerr
    Oregon
    Should be able to find the phone number on here via search. I would look but I’m on my cell. I’m in the same boat as you except I had to pay for the TSB since I have an SR5. Sucks lol
  20. Nov 27, 2018 at 6:30 PM
    #4940
    wearepsu
    wearepsu Member
    Jeff
    Here is the number to corporate: ‭
    (800) 331-4331‬.
    I have a current case open. Had the TSB done and it very slightly lessened the howl but clearly didn’t remove it. Corporate had me take the truck back to the dealer for them to verify the noise was still present. The service manager and master tech both rode in the truck and said everything was normal. They are either clueless or are in on a cover up. Everyone that rides in my truck clearly hears the abnormal howl noise. I am going talk to corporate again tomorrow and see what the next step is. The noise is not “normal” so I’m not giving up.
    Handoverfist likes this.
