3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Mar 27, 2019 at 6:46 AM
    #5041
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Just let the dealership handle. It. I think the 2019 has the upgraded parts .
  2. Mar 27, 2019 at 9:46 PM
    #5042
    mikebur
    mikebur Member
    Just noticed the howl noise in my new 2019 DCSB OR.It has less than 3K on it. Speed 54-56MPH going downhill and feathering throttle. Should I open a case with toyota? Is there a final fix for the issue? Looks like this thing has been going on for a while.
    The Real Moondog likes this.
  3. Mar 27, 2019 at 10:02 PM
    #5043
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    First of all, welcome aboard. Second, there is no absolute fix. Third, yes, by all means please open a case. Maybe if enough people complain they'll finally get a real fix.
    mikebur[QUOTED] and shakerhood like this.
  4. Mar 27, 2019 at 11:26 PM
    #5044
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Definitely open a case with Toyota. I'm guessing your truck already has the TSB parts from the factory (they told me my August 2018 build did, so I assume 2019's do too). But take it in to a dealer to make sure. I traded my 2018 at a loss after 2 months because the noise drove me nuts. Pissed me off.
    Sorry, man. Totally sucks that they haven't figured this out yet. Not much you can do about it. Sometimes they're willing to throw a new rear diff in, sometimes they're not. Seems to be a crap-shoot.
    Can't believe there isn't a class action suit on this yet. Some of those that have had the diff removed have reported metal on the magnet and badly worn gears.
    Know you're not alone! There's a bunch of us that also dropped $39k and are feeling the same way you do right now.
    mikebur[QUOTED] likes this.
  5. Mar 28, 2019 at 5:06 AM
    #5045
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    When reading through the list of tsb's, I thought i saw the fix for this problem was them replacing the leaf springs and doing something inside the back of the cab?
  6. Mar 28, 2019 at 7:43 AM
    #5046
    The Real Moondog
    Moondog
    That’s a bandaid to mask the noise. I have that TSB as well and my last diff could be heard over my radio set on 35 with Kicker tweeter upgrade.
    fdbyrne and shakerhood like this.
  7. Mar 28, 2019 at 7:50 AM
    #5047
    ferntr33
    ferntr33 Well-Known Member
    I have been noticing the whine in my MT randomly throughout rpm band. Seems to only be on coasting and decelerations. Problem is I have 285’s. Think dealer will bitch at me?
  8. Mar 28, 2019 at 8:53 AM
    #5048
    T.T.T
    T.T.T Well-Known Member
    Ty
    2017 TRD Off-Road access cab [SOLD]
    I don’t know how bad it is but I say check the diff fluid and enjoy your truck. Don’t think about it.
  9. Mar 28, 2019 at 9:43 AM
    #5049
    The Real Moondog
    Moondog
    I wish it was this time easy, but it’s not for me. I can’t not hear it. Maybe the next TSB will be a complimentary set of ear muffs. Ha! I’m sure Toyota knows what it is but the fix must be far more difficult (or expensive) than we realize or they would have fixed it by now.
  10. Mar 28, 2019 at 10:21 AM
    #5050
    T.T.T
    Ty
    Do you think a lift will do anything to the noise?
  11. Mar 28, 2019 at 10:26 AM
    #5051
    The Real Moondog
    Moondog
    I’m not sure but I’d like to hear some thoughts on it.
    T.T.T[QUOTED] likes this.
  12. Mar 28, 2019 at 10:27 AM
    #5052
    T.T.T
    Ty
    Me too.
  13. Mar 28, 2019 at 10:51 AM
    #5053
    mikebur
    mikebur Member
    Thanks everybody for replies!
    It was not bad if I had 100k miles on it but I'm pissed off because I paid 38k for a brand new car and planned to keep it for many years.
    I am not an expert but with my limited knowledge I think this problem does not have to do anything with oil level or leaf spring. Like moondog said that TSB looks like a cover up to mask the real problem.
    To me, the howling noise sounds like my uncle's Fiat with 100k on it with a worn off diff. Really pissed off!
    The question is that is it going to become worse if I put more miles on?
  14. Mar 28, 2019 at 11:00 AM
    #5054
    T.T.T
    Ty
    I’m truly convinced it’s just harmonics.
    TD90S and shakerhood like this.
  15. Mar 28, 2019 at 11:13 AM
    #5055
    The Real Moondog
    Moondog
    Not to debate but my differential had excessive shavings and damaged gears......
  16. Mar 28, 2019 at 1:49 PM
    #5056
    T.T.T
    Ty
    How many miles were on the diff? Also did you have correct fluid level? Just curious. And it’s all good we’re just talking here
  17. Mar 28, 2019 at 2:22 PM
    #5057
    mikebur
    mikebur Member
    What exactly do you mean by harmonics?
  18. Mar 28, 2019 at 2:55 PM
    #5058
    T.T.T
    Ty
    Small vibrations causing a hum, whistle, whine etc... getting transferred through the undercarriage into the cab.
  19. Mar 28, 2019 at 3:32 PM
    #5059
    The Real Moondog
    Moondog
    My howl started around 1000 miles. They replaced the differential around 15,000 plus. The new rear differential was completely silent - not a sound. Around a few hundred miles ago it started back. Corporate did a fluid analysis, tore my truck apart from one end to the other. It had the proper amount of fluid but had excessive shavings in it.
    shakerhood likes this.
  20. Mar 28, 2019 at 5:15 PM
    #5060
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    So the second one is making noise?
    Was the third member replaced or the entire axle? Did you get to see the amount of metal?
    Mine has made noise from 1000 miles or so. Drained the fluid and found a small amount of fuzz on the magnet, that’s totally normal. The fluid was full and clear, slight greenish tint. Checked the level after a 11 mile trip prior to draining it. This was a 8000 miles.
