3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Dec 15, 2019 at 9:58 AM
    #5421
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    about 1200kms...700 miles
  2. Dec 15, 2019 at 10:01 AM
    #5422
    dansflhti
    Nova Scotia
    Yeah..on some vehicles the wind whistles at lower speeds across some holes that are in the lower control arms.The dealer diagnoses it by taping over the holes...if the tape cures it,they install body plugs.
  3. Dec 15, 2019 at 10:38 AM
    #5423
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Holes in lower control arms.... Really shouldn't affect sound in the cab, given that your lowers are way down by your front tires and shocks etc.
  4. Dec 15, 2019 at 10:50 AM
    #5424
    dansflhti
    Nova Scotia
    tsb 0053-16
  5. Dec 16, 2019 at 3:47 PM
    #5425
    DrTaco716
    DrTaco716 Active Member
    2019 Tacoma TRD Off Road Cement
    Bed Mat
    "Normal Characteristic of the vehicle" canned response but its documented with the dealer. Time to turn the music up and deal with it
    CygnusX191 likes this.
  6. Dec 16, 2019 at 4:38 PM
    #5426
    ryan760
    ryan760 Well-Known Member
    I think that's the best outcome actually.
    I'd rather not have dealer techs messing around with my truck for days, driving it around, waiting for parts to come in, only to have the noise still be there or come back later.
    I plan to voice my complaint to Toyota at my 5k, but unless they have an official fix by then, I'm not letting them replace anything.
  7. Dec 16, 2019 at 5:04 PM
    #5427
    DrTaco716
    Bed Mat
    I also think that's probably the best outcome haha. As long as you get it documented just enjoy the truck.
  8. Dec 16, 2019 at 6:21 PM
    #5428
    longspur
    longspur Well-Known Member
    Tim
    Western Ky.
    2025 Off Road
    Little update since rear diff replacement on the 14th. All was good for 10 miles or so then whine showed it’s ugly face. Only difference is it went from 50-60mph to 55-60mph. Wasn’t really concerned before and and not really concerned now. It’s documented so if it gets worse I’ll cross that bridge then. This spring I might put some sound deadening material behind the rear seat and call it good
    CygnusX191, DrTaco716 and ryan760 like this.
  9. Dec 16, 2019 at 7:07 PM
    #5429
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    If you want to fix the noise just get some mud tires. :). Had I had it to do over that is what I would have done - head on noise vs. noise. I have heard the sound deadening doesn’t work either. Best of luck.
  10. Dec 18, 2019 at 1:38 PM
    #5430
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Update: The new oil somewhat worked. I can only hear the noise between 45-55 mph on deceleration. Used to have the noise at higher speeds upon deceleration but not anymore.
    Another strange observation. I took it for a 10 minute drive before changing the oil to so it would flow better. When I took the fill plug off, (about 10 minutes later) a bit of pressure escaped for about 3 seconds. This thing has a relief valve on it just like my 4Runner. I would have thought that the pressure would have released as there's nothing to the ball check valves. I didn't take it off and shake it but I will. Oh and don't use a 24mm 12 point socket on the plugs or be super careful if you do. I started to strip mine, I then used a 15/16 12 point which got it off.
    Pablo8 likes this.
  11. Dec 18, 2019 at 2:01 PM
    #5431
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Ditch the factory one way valve and put a two way breather in, tuck it up nice and high.
    Won't help the whine, but it'll give you a functional diff breather so you're not sucking in water when going through crossings or backing the boat in etc
  12. Dec 19, 2019 at 8:41 AM
    #5432
    ryan760
    I think a mechanic's word or differential shop's opinion on this issue should be taken with a grain of salt considering the potential conflict of interest. If you look at all the literature out there on differential noise diagnosis, it basically says that *any* noise, no matter what, is not normal and needs to be addressed ASAP. The problem with this extreme, black and white line of thinking is that it completely ignores other sources or contributors to the noises, such as harmonics, amplification of small amounts of noise via springs, driveshaft and surrounding structure. Toyota has even official stated that this particular noise is caused by normal differential vibrations being transmitted and amplified via the springs, frame, and cab mounts. Their theory seems to make sense when you consider the sheer number of people who have received multiple replacement differentials and the noise always comes back.
    There have been cases where these diffs have been taken apart and examined and no issues were found with gear meshing, pinion depth, or abnormal wear.
    https://pdfs.semanticscholar.org/1404/a12c9dc2faa75c183d8a7be5f9f8e911110d.pdf
  13. Dec 19, 2019 at 11:48 AM
    #5433
    ryan760
    The vibrations/rumble strip feeling has actually gotten less noticeable with mileage for me. It was very noticeable the first 1000 or so miles, and now I can barely feel it. The howl on the other hand became an issue at or around the 600 mile mark, got progressively worse until about 1500 miles where it seems to have stabilized. So on my truck, the relationship between howl and vibration has been inversely proportional.
    Let me ask you something, do you believe that *all* differentials, across the spectrum -- all makes and models of vehicles -- are silent? If the answer is no, then technically we are saying that the possibility is there for certain diffs, due to design, will make some noise regardless of how they are setup.
    I believe that some gears simply make more noise than others due to the way they are designed... the way they are cut, the hardening, the way the axle housing is designed may amplify vibrations. Some diffs are just not designed well from an NVH perspective, but will last just as long, and perform just as well as any silent diff. I don't believe in the absolutist theory that all diffs, regardless of make and model, will be completely silent with proper setup. That's a theory that differential shops and specialists like because they need diffs to work on in order to survive!
  14. Dec 19, 2019 at 11:59 AM
    #5434
    ryan760
    I just noticed you have an SR, and I think those have different diffs. I agree it's a little weird that yours started at 8000 miles, but perhaps the diffs on some trucks wear-in differently than others.. most people I know who have the TRD OR with the BD22 diff seem to notice the howl anywhere from a few hundred to 1000 miles.
    I wish you luck on yours though. If you ever manage to find a solution, please let us know!
    shakerhood and CygnusX191 like this.
  15. Dec 20, 2019 at 7:48 AM
    #5435
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    About two weeks ago I opened up a case with Toyota about my 2020 off-road whining after the service manager at my local dealership wrote it off as typical Tacoma noise. I just finished up a like model ride along with the same service manager which was scheduled by my Toyota case manager.
    They are ordering a new diff for my truck.
    ryan760 and CygnusX191 like this.
  16. Dec 20, 2019 at 9:19 AM
    #5436
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Good. The more diffs they're forced to replace, the more likely it is they'll actually fix the problem.
  17. Dec 20, 2019 at 9:27 AM
    #5437
    ryan760
    Keep in mind that the noise usually takes time/miles to set in, so new trucks on the lot likely won't have it yet. I guess in your case their not knowing that worked out well for you lol :D
    WZ00R2[QUOTED] likes this.
  18. Dec 20, 2019 at 10:46 AM
    #5438
    The Real Moondog
    Moondog
    Does anyone know if the Pros howl?
    ryan760 likes this.
  19. Dec 20, 2019 at 11:36 AM
    #5439
    WZ00R2
    TN
    2020 Cement OR
    Yep! All the 2020s on the lot were brand new. It took about 2000 miles for mine to start whining.
    My 2018 was silent for the 30k miles I had it. I only did this to add pressure to Toyota in finding a fix. Once they pull the 3rd member, they are going to allow me to examine, take pictures and compare it to the new unit prior to installation.
  20. Dec 20, 2019 at 12:35 PM
    #5440
    Trey82
    Trey82 Member
    2020 trd off road
    I’ve got a 2020 trd off road with under 200 miles that makes a slight howling noise going down the road. I will keep an ear on it and if things get worse I’ll take her in. Mine was manufactured in Mexico, not that it matters. Coming from an 18 Colorado z71 it’s light years better in every way!
