3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Dec 26, 2019 at 4:56 PM
    #5481
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    I really hope this one works out for you. Until this issue is truly fixed I’m going to stay away. Like so many others, I’ve driven Tacos for a long time but my 17 almost drove me nuts. Best of luck and hope this one fixes the issue for you.
    Patrick1046, NMTrailRider and ryan760 like this.
  2. Dec 26, 2019 at 5:07 PM
    #5482
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    New fluid didn't help. Not even thicker gear oil. No change at all.
  3. Dec 26, 2019 at 5:11 PM
    #5483
    ryan760
    ryan760 Well-Known Member
    If you can, we would be interested in pics or description of what they say about your old diff. I've heard a lot of stories on here about people taking their diffs in to get examined, but never see any pics or evidence.
    Also, I'm curious about your 2018... what model was it? any mods? stock tires?
    CygnusX191 and The Real Moondog like this.
  4. Dec 26, 2019 at 7:08 PM
    #5484
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    The diff is not torn down and analyzed at the dealer. They package it up as it comes out of the truck to return to Toyota who then sends it to their supplier for the warranty.
    I’ll be sure to get lots of pictures comparing both. I’ve also requested to see the drain plug magnet before it is cleaned off. I’m curious as to how much metal will be there after 6000 miles.
    My 2018 and 2020 are optioned exactly the same except for the color. They are both TRD off-road double cab trucks. The 2018 had 2”/1” spacer/block lift and 255s for the last 5k miles I had it. That truck was silent before and after the lift. I’m installing 6112/5160s, Icon AAL and 255s to the 2020 on Saturday.
    Patrick1046 and ryan760[QUOTED] like this.
  5. Dec 27, 2019 at 2:23 PM
    #5485
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    I hope it helps, but not likely. Had my diff replaced and was silent for about 1000 miles then started howling again. However, it does not howl as bad as the original...for now. I will just live with this little annoyance as there is no evidence I have seen that the differential will fail due to the howl.
    The Real Moondog likes this.
  6. Dec 27, 2019 at 2:38 PM
    #5486
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Anyone here regeared with aftermarket gears and solved the howl as a side effect?
  7. Dec 28, 2019 at 3:04 PM
    #5487
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Just got done riding in my uncles 2019 TRD Off-road DCSB. His howls on both deceleration and acceleration between 53-59. I didn’t know they could howl on acceleration, but it was clear as day. He also has a bed mat and a bed cover on it, too. It’s not as loud as mine (volume 30+), but it does it through that range no matter what. He is pretty deaf from machine work and doesn’t notice it ha I imagine most trucks have the howl and some people just aren’t able to hear it like him. Lucky them!
    DrTaco716 and The Real Moondog like this.
  8. Dec 28, 2019 at 4:43 PM
    #5488
    TacoTim85
    Mine howls loudest around 57-58 mph on light acceleration to maintain your speed. It howls between 50-65 mph altogether, but loudest at the first speed range I listed. It's noticeably louder with rear seats folded flat which is unfortunately how I like to ride around. I use the back seat for cargo, not people.
  9. Dec 28, 2019 at 5:10 PM
    #5489
    ryan760
    Mine howls on acceleration too, exact same speed range as your Uncle's. Quiet as a mouse on decel though.
    CygnusX191 likes this.
  10. Dec 28, 2019 at 5:35 PM
    #5490
    TacoTim85
    Has anyone installed dynomat insulation or the like?
    I find that just folding my seats back into the normal position makes a noticeable improvement for now.
    ryan760 likes this.
  11. Dec 28, 2019 at 5:54 PM
    #5491
    ryan760
    I'm curious too. If others have noticed an improvement particularly with reducing the howl, even if only 20%, that might be enough to make me consider doing it.
  12. Dec 28, 2019 at 6:05 PM
    #5492
    TacoTim85
    I might end up doing this just to lessen some road noise as well. It's on my list of ideas for the truck.
    ryan760[QUOTED] likes this.
  13. Dec 28, 2019 at 6:13 PM
    #5493
    The Real Moondog
    Moondog
    It is my understanding that it has not helped much, which surprises me. You would think any additional insulation would help but it doesn’t seem thin this case. I wonder if @nDub recalls? Either way, I’m pretty sure most everything has been tried.
  14. Dec 28, 2019 at 6:18 PM
    #5494
    TacoTim85
    Hard to believe dynomat wouldn't help when just flipping my seats to the normal position makes a noticeable difference, not nearly as loud and then only noticeable at a narrower speed range.
  15. Dec 28, 2019 at 6:21 PM
    #5495
    The Real Moondog
    Moondog
    I have been on this thread since Smitty started it and unfortunately it does not seem to. Now, can it help some? I’m sure it would help a little, but many have tried. Looking back I wish I had just stuck on mud tires and not worried with it.
    CygnusX191, shakerhood and nDub like this.
  16. Dec 28, 2019 at 6:28 PM
    #5496
    TacoTim85
    Also on "the list" so I'm not too mad about the howl... yet. Lol
  17. Dec 28, 2019 at 6:56 PM
    #5497
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I think @trazerr did, maybe.
  18. Dec 28, 2019 at 7:01 PM
    #5498
    trazerr
    Oregon
    You are correct. I put Noico 80mil under the storage compartments, rear seats, and halfway up the back wall. At the same time I crammed egg foam and other thick foam into the C pillars. Also put foam into the body mount bolt access under the rear seats. It didn’t really help too much.. the TSB body mounts helped the most.
  19. Dec 28, 2019 at 7:04 PM
    #5499
    The Real Moondog
    Moondog
    Thanks, I knew it was one of you but couldn’t recall which one! :)
    nDub, shakerhood and trazerr[QUOTED] like this.
  20. Dec 28, 2019 at 7:53 PM
    #5500
    TacoTim85
    I'm gonna assume my 2020 doesn't need new TSB body mounts? Or maybe it does and not enough people have complained yet lol
