3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 14, 2020 at 7:39 AM
    #5601
    ryan760
    ryan760 Well-Known Member
    Very likely.
    Such a frustrating issue though.. I wish there was more consistency. I have a hard time believing that there would be such an enormous failure rate of differentials (~50%+ alone just based on the TW poll), across all production years for the 3rd gen Tacoma (including even some in the 2nd gen). Something like that would be extremely unlikely... especially if it was something as simple as impromper shimming, preload, etc, all of which could be corrected easily and at little to not cost. It would make zero sense for Toyota/HINO to drag the problem out over years.
    :annoyed:
    CygnusX191 and AKGSD like this.
  2. Jan 20, 2020 at 8:03 AM
    #5602
    ryan760
    So I reached out to someone at East Coast Gear Supply to ask about these differentials. I don't want to mention his name for privacy reasons, but this is what he came back with:
    I thought it was very nice of him to go out of his way to write this. He did mention he might reply to this thread at some point and provide pictures of what he's talking about.
    To any extent, it sounds as though there is nothing particularly wrong with the diff just that the gear design lends itself to being noisy. There's also a tech note on their webpage regarding the differential, saying that it's known to be noisy.
    https://eastcoastgearsupply.com/i-23993416-8-75-tacoma-elocker-third.html
    VB25, AKGSD, nDub and 4 others like this.
  3. Jan 20, 2020 at 2:15 PM
    #5603
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Wow man, this is top notch stuff. Good to know that he's of the opinion that these diffs are designed and built with longevity and robustness (its a word now) in mind.
  4. Jan 20, 2020 at 6:17 PM
    #5604
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Right on. Thanks for sharing.
    CygnusX191 and ryan760[QUOTED] like this.
  5. Jan 21, 2020 at 7:52 AM
    #5605
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Great detail! Would he happen to have any suggestions on toning the noise down? i.e., thicker or different oil, ect...
    I said i would never lift another truck, but this noise is waring on my nerves. Aggressive tires and blocks seem to be the only thing killing it.
    Hot Taco sauce likes this.
  6. Jan 21, 2020 at 10:53 AM
    #5606
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Blocks didn’t change mine. From what I’ve read, it’s leaf springs that do it. I’m still on stock tires
    TacoTim85 likes this.
  7. Jan 29, 2020 at 10:30 AM
    #5607
    ryan760
    Thinking about trying this on the axle tubes (minus the pumpkin) and perhaps even on the leaf springs:
    https://www.amazon.com/Design-Engineering-050220-Deadening-Vibration/dp/B001URKV0G
    It's supposed to be made for automobile applications, and is black. My only concern would be preventing proper cooling of the differential and oil. I think the pumpkin needs to be kept bare metal to allow the oil to cool, so I wouldn't cover that.
    I figure spraying the axle tubes would be reasonably safe, as well as the leaf springs.
    The theory behind this idea is from a research paper on axle whine (https://journals.sagepub.com/doi/abs/10.1177/0954407011401302), as well as Toyotas TSB which implies that the noise is transmitted through the axle tubes through the leaf springs and frame, and into cab.
    What do you guys think?
    Pablo8 likes this.
  8. Jan 29, 2020 at 10:49 AM
    #5608
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I cannot imagine this working
    ..b..but worth a shot just to prove me wrong. Do it.
  9. Jan 30, 2020 at 7:24 AM
    #5609
    dung
    dung Well-Known Member
    2018 TRD OFFOAD
    It won't hold in enough heat to matter in the long run. I doubt it will work either, but it isn't going to hurt.
    ryan760 and Pablo8 like this.
  10. Jan 30, 2020 at 7:32 AM
    #5610
    ryan760
    My other idea (I may try it first) is to get some weighted magnets off Amazon and place them in various areas on the axle, springs, and frame to see if the added mass changes anything.
    Need to figure out if the bulk of the noise is radiated straight from the pumpkin, or if its amplified through the springs, frame, and body. That's the first step to finding a solution I think.
    TacoTim85 and Pablo8 like this.
  11. Jan 30, 2020 at 2:52 PM
    #5611
    AKGSD
    Joe
    Alaska
    Aren’t these things the engineers would have (theoretically) tried before telling all of us it’s “normal”?
    ryan760[QUOTED] likes this.
  12. Jan 30, 2020 at 3:22 PM
    #5612
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    I did the following to attempt to reduce the rear end noise on a new ‘16 auto Sport 2WD during the first year of ownership and none of the actions remediated the problem.
    - dealer replaced entire rear end assembly. Same noise problem after 100 miles
    - dealer replaced driveshaft assembly, but no improvement
    - lube replaced multiple times with different synthetic brands (Mobil1/Amsoil/Valvoline/Toyota/Pennzoil/BG additive), but the noise would return within 100 miles
    Good news is that the ‘20 manual Pro and ‘20 auto Sport 2wd that I purchased have zero rear end noises after 4K miles of usage. Fingers crossed.
    nDub, CygnusX191 and AKGSD like this.
  13. Jan 30, 2020 at 3:59 PM
    #5613
    ryan760
    Man I swear, I'm convinced the engineering department ran out of budget half way through the NVH process for the 3G taco. IMO, the noise is so blatant and in your face that its like they didn't even try, hence why I think they just didn't get around to addressing it, and pushed the truck to market as-is.
    Or they missed it during product testing, but I don't know how the hell you'd miss something like this.
    AKGSD[QUOTED] likes this.
  14. Jan 30, 2020 at 4:45 PM
    #5614
    dung
    2018 TRD OFFOAD
    Well clearly the noise isn’t there. That is why they didn’t miss it :)
    BillsSR5 and CygnusX191 like this.
  15. Jan 30, 2020 at 6:56 PM
    #5615
    jrshaw91450
    Maui
    I just spent 2000+ miles behind the wheel of a 2020 GMC Canyon diesel (I was transporting it for a friend before anyone gets crazy) and I will say I didn’t realize the noise that gets through the back of the cab on my Tacoma until spending a substantial amount of time behind the wheel of that truck. Thing was so quiet inside and now being back in my 2019 Tacoma Im amazed on the noise coming through the back of the cab. I don’t understand why, it’s not like I noticed thicker seats or more insulation back there.
    I just stuffed some pipe insolation between a cab and bed to see if it dampens the noise at all. I imagine Toyota would have experimented with this already before issuing a much more expensive TSB to replace leaf springs, which did nothing on my 2017. Finger crossed, but almost certain it will change nothing.
    ryan760 likes this.
  16. Jan 30, 2020 at 7:11 PM
    #5616
    ryan760
    I'm pretty satisfied with how quiet the cab is inside, except for the damn howl. It's like being stuck in a 1st world torture chamber at 55 mph.
    Interesting idea with the pipe insulation though. :thumbsup:
    AKGSD, dung and shakerhood like this.
  17. Jan 30, 2020 at 8:02 PM
    #5617
    jrshaw91450
    Maui
    It is very quiet compared to the 2nd gens. The pipe insulation is something someone said worked pretty good a while back in this thread or another, I don’t remember, but its a cheap easy test. Sometimes Im exhausted from the issue but at the same time I cant believe Toyota would accept it, especially since the Tacoma legacy is built on quality and longevity. You would think after the first year they would have told Hino to redesign the DB22 differential or their going elsewhere.
    AKGSD and ryan760 like this.
  18. Jan 30, 2020 at 8:15 PM
    #5618
    ryan760
    If that pipe insulation idea works, that would be amazing. I'd be thrilled with even a 20% reduction... anything to take the edge off.
  19. Jan 31, 2020 at 7:44 PM
    #5619
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I'm so confused why you would buy TWO more new Tacomas after what sounds like a real headache, no pun intended (ok a little pun intended). Lol
    Wish I was lucky enough to buy a '20 without the howling! Although, mine isn't that bad compared to what some have described. :thumbsup:
    AKGSD likes this.
  20. Jan 31, 2020 at 8:53 PM
    #5620
    MannyS
    Republic of Texas
    Good question. Buyback done for the ‘16. I am a Toyota guy, so Last month I bought me a 2WD Sport, bought my daughter a Pro manual and got my wife a Land Cruiser Heritage. All good.
