3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. May 23, 2020 at 2:52 PM
    #5961
    jetfishn
    jetfishn Well-Known Member
    They know what the problem is at Toyota by now, they just don't want to have to replace entire axle assemblies on a ton of trucks to make them quiet, with better thicker materials, we never had this problem with older gen tacomas, at least I never did if I did I would have been at the dealership hounding them or lemon lawed them. Probably nothing short of a class action lawsuit will cure this problem. Its Hino of Thailand causing the issue with substandard parts.
    This issue is keeping me from buying a new 2020 OR right now. I don't want to go thru the hassle of lemon law and or a lawyer. I can wait. Eventually they will have to address the issue and man up.
  2. May 23, 2020 at 4:38 PM
    #5962
    ryan760
    ryan760 Well-Known Member
    Honestly, had I known the diff was going to make this much noise I would have gone with a Frontier.
    I still love my Taco, and plan to keep it, but this noise is just crazy town.
    mainjet likes this.
  3. May 23, 2020 at 10:02 PM
    #5963
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Ford, GM and Nissan seem to have no problem with a technology that’s been around for centuries. Our dealership here wouldn’t allow highway driving so on a test run you will never hear it until its to late. Same here, love the truck but sometimes the noise just ruins it for you. I think KIA has better QC.
  4. May 23, 2020 at 11:56 PM
    #5964
    whatjones911
    whatjones911 Well-Known Member
    2018 DCSB OR 4x4 MT
    I thought I was the only one haha. The engine in the tacoma is LOUD. I have this hill heading home which I would stay in 2nd gear @ 3.5 - 4K rpm and the thing roars.
  5. May 24, 2020 at 5:11 AM
    #5965
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    Unfortunately I highly doubt it as this has been a problem since 2016. If they were going to fix it, it would’ve been fixed within the first two years. Toyota sells enough Tacoma’s as it is so why fix the issue if only a small percentage complains about it.
  6. May 24, 2020 at 5:34 AM
    #5966
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Same here. I have a long steep asphalt highway grade just before the turn off to a dirt road to my home. Engine sounds like the chipmunks are starting to work hard around 3k rpm. My tundra would downshift a gear to run around 2400 rpm to maintain 50 mph
  7. May 26, 2020 at 10:38 AM
    #5967
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    I have an access cab and the howl is there but its not that loud though. So it doesn't bother me too much. You might be one of the lucky ones that don't have it.
    SilverBulletII likes this.
  8. May 26, 2020 at 11:15 AM
    #5968
    zoo truck
    None
    I just did a 50 mile round trip errand in my access cab, it still has the factory tonneau cover on it...wondering if that helps dampen any howling. At any rate the trucks as quiet as a church mouse. More mileage i pile up on it, the truck just runs better. Except for not having 4' between the wheel wells, and a very stiff ride, i really like the truck now. It rides surprisingly better on rougher dirt roads than on the asphalt ones.
  9. May 26, 2020 at 7:26 PM
    #5969
    Blackbeard83
    Sam
    Massachusetts
    currently stock
    It possible the tonneau cover helps. Is it the factory tonneau?
  10. May 26, 2020 at 7:48 PM
    #5970
    jrshaw91450
    Maui
    You have the Sport with the 8 inch differential. If you were to make Toyota replace your differential you would probably have better luck getting it fixed permanently. those of us with off roads and pro’s seem to be screwed
    Blackbeard83 and ryan760 like this.
  11. May 26, 2020 at 9:23 PM
    #5971
    Blackbeard83
    Sam
    Massachusetts
    currently stock
    Yeah at this point it hasn't really bothered me enough to bother the dealership to fix it. I'm kind of afraid it will be worse if I try after seeing some of the replies here.
  12. May 26, 2020 at 9:30 PM
    #5972
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Here ya go, can hear it at 00:04 (its faint on here, but if you were in the cabin you'd be like, dahfaq?).
    https://vimeo.com/178979705
    shakerhood, ryan760 and Blackbeard83 like this.
  13. May 26, 2020 at 9:36 PM
    #5973
    ryan760
  14. May 26, 2020 at 9:39 PM
    #5974
    TacoBuffet
    AL
    That was back in 2016, couldn't tell ya, if I remember correctly it was on decel or constant/maintained speed though, don't ever remember hearing it on accel.
  15. May 26, 2020 at 9:46 PM
    #5975
    ryan760
    I still think it's weird that some have it on acceleration and others on deceleration. That's kind of a big clue that this may be a gear setup/bearing preload problem, and not just harmonics.
    Mine happens on light-moderate acceleration and deceleration (although with the AT, the decel noise only happens when engine braking).
  16. May 26, 2020 at 9:51 PM
    #5976
    TacoBuffet
    AL
    Just as weird that I've had it on some trucks and some not, all different configs, some same. Good luck!
    shakerhood likes this.
  17. May 27, 2020 at 6:49 AM
    #5977
    ericf
    ericf Well-Known Member
    Eric
    Texas Gulf Coast, Houston
    2020 TRD offroad 4x4 silver sky.
    lomax tonneau, amp bed extender , bed rug
    Well, I just left my 2020 ORDC at dealership this morning for them to determine whats up with my howling. I asked him to "NOT TELL ME IT"S NORMAL". My last tacoma did not have this issue, and I've been in other Offroads that didnt exhibit this noise. So it may be a common issue/complaint , but it can't be considered normal. He stated that have now been seeing Tundras owners that have this complaint too. Fingers crossed!
    Blackbeard83 likes this.
  18. May 27, 2020 at 6:55 AM
    #5978
    ericf
    Eric
    If I'm not happy with the "repairs" or outcome of the "repairs", I'll be talking to a dedicated Diff. repair shop.
    My 2020 now starts singing around 50mph and goes into the "tree tenors at the colosseum" at 58-59. And it's mainly on slight decel.
    Hard decel and When maintaining speed it's still singing however it's not at annoying levels. I have to listen for it.
    Jeff Dartfrog likes this.
  19. May 27, 2020 at 7:00 AM
    #5979
    zoo truck
    None
    Yup, factory cover...its pretty heavy. Just kind of surprised the truck rides like an ox cart of the asphalt roads. A friend has a 2019 trd that riders noticeably better. I have to put about 400 lbs in the bed to get a similar ride compliance. Even my 0ld 93 toyota 4x4 extra cab had a better ride.
  20. May 27, 2020 at 7:48 AM
    #5980
    SpeySquatch
    2016 TRD OR DCSB
    A heavier oil will definitely kill the noise. When I put 4.88’s in and 85w-140 there was no howl for 1,000’s of miles. Switched to 75w-90 and there is a faint howl now. Going to go to 75w-110
