3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jun 25, 2020 at 4:29 PM
    #6121
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Well Dana is responsible for our rust bucket frames so I'm not sure that's a great idea.
    turbosnail, shakerhood and Lt. Dangle like this.
  2. Jun 28, 2020 at 6:23 AM
    #6122
    ericf
    ericf Well-Known Member
    Eric
    Texas Gulf Coast, Houston
    2020 TRD offroad 4x4 silver sky.
    lomax tonneau, amp bed extender , bed rug
    Update, I visited a second dealer and took the service manager for a ride. He definitely listened to the whine from the back of the truck. He stated that it "wasn't Normal". He said it could be wind noise or harmonics as also possibly the diff. They would look into it Monday. I informed him of the low gear lube levels that the previous incompetent dealer Checked (1.25qts under filled) . He stated that at that low levels, because the diff angle changes at acceleration and cruise, and decel, that the pinion bearing could be toast from lack of lube. He didnt know.
    Maybe, maybe!....
    Regarding a previous post about the carrier bearing (drive shaft support) , Has there been an attempt to place a rubber bushing or grommet at the carrier mounting bolts for vibration isolation from the bed? Im grasping at straws.
  3. Jun 28, 2020 at 7:49 AM
    #6123
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My own experience with the oil levels in differentials is it'd have to be way lower a 1 1/4 qts. to cook the bearings. The gear oil gets splashed around pretty good giving those gears, and bearings a good bath. From what i've read these taco rear ends hold at least 4 qts.
  4. Jun 29, 2020 at 10:14 AM
    #6124
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I coated the undercarriage with Fluid Film and the drone has been greatly reduced. Conversely, I have made this same statement in the past and other posters reported that their drone increased after applying Fluid Film. So, who knows ?
  5. Jun 29, 2020 at 11:33 AM
    #6125
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Not sure if this is any help but I am getting a slight version of this issue on my 2015. I know its a 2nd gen but I have a build date of 6/15. TRD sport.
    55-65 I notice a slight higher pitched howling if I feather the throttle. If I accelerate it goes away, If I fully let of the gas it goes away. I can get it to do it if I slightly feather the throttle around these speeds. Its not nearly as loud as some on here. It sounds spot on to this you tube clip. https://www.youtube.com/watch?v=_1Q20DbH4qU
    I bough the truck as a CPO a few months ago(58k miles). I just recently started noticing it. Most likely has been there but I just now am picking up on it. I know it doesn't make sense but I seemed to notice it right after I removed the cheap tonneau cover the truck came with.
  6. Jun 29, 2020 at 12:57 PM
    #6126
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    That's because this whine TSB was also issued for the second gens.
    The Real Moondog and shakerhood like this.
  7. Jun 29, 2020 at 1:08 PM
    #6127
    fourfourone
    Correct but only to 2013 for the 2nd gens I believe. Just sharing some knowledge.
  8. Jun 29, 2020 at 2:44 PM
    #6128
    Lt. Dangle
    Ohio
  9. Jun 29, 2020 at 2:46 PM
    #6129
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    The off road tire drown that howl out quite nicely.
  10. Jun 29, 2020 at 3:34 PM
    #6130
    fourfourone
    Lt. Dangle[QUOTED] likes this.
  11. Jun 29, 2020 at 3:46 PM
    #6131
    JNG
    I honestly could hear nothing but road noise in that clip.
    BillsSR5 likes this.
  12. Jun 29, 2020 at 3:56 PM
    #6132
    fourfourone
    Not the best example. Mine would be hard to capture too. If you turn it up and listen closely you'll hear it. I'm half deaf from fire arm training and I can still hear it haha.
  13. Jun 29, 2020 at 4:00 PM
    #6133
    JNG
    I have the howl from 45ish to 60ish mph. I just ignore it. I've had it from roughly 1000 miles onward. I drained and replaced the rear diff gear oil at 5000 miles and still have it at 16,600 miles. At 5000 miles the fluid was perfectly clear with no discernable metal 'glitter'. Looked brand new. I think it's an annoyance more than a durability issue.
    ryan760 likes this.
  14. Jun 29, 2020 at 6:53 PM
    #6134
    Lt. Dangle
    Ohio
    Ugh, my fault, sorry mate.
  15. Jun 30, 2020 at 9:50 AM
    #6135
    pconnor1992
    pconnor1992 Member
    Just had my 2019 looked at for rear diff noise. Dealership contacted their field rep and the next day they called and said they're approved to replace the rear differential. The field rep also said this may not fix the issue and they are aware of this and are in the works for a solid fix to this issue for all 3rd gen Tacomas that experience it.
    Well see how this goes. Fingers crossed
  16. Jun 30, 2020 at 10:45 AM
    #6136
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Boy wouldn't that be nice... Us SR5 guys have been left out of this entire thing. I had to pay for the TSB parts myself. If they did actually make a fix I bet I would be excluded again..
  17. Jun 30, 2020 at 10:53 AM
    #6137
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    halle-f***-lujah!!!!! So many upset people would calm down if they would just inform us of their plans. I was right on the verge of lifting and doing mud terrain to drowned the sound out. How pissed off I would’ve been if I proceeded and disqualified myself from a fix.
  18. Jun 30, 2020 at 11:02 AM
    #6138
    cyked
    cyked Well-Known Member
    '17 TRD OR, 29k miles and no noise. There is a bit of weeping around the 3rd member though.
  19. Jun 30, 2020 at 11:13 AM
    #6139
    fourfourone
    how loud was yours?
    I don't want piss in your cheerios but I had similar issues with a Silverado. I had the chevy shake issue like thousands did. Sometimes GM would admit there was an issue and would tell people they were working on a fix. Come to find out that it had to do with the harmonics of the chassis and it really wasn't fixable. Gm kept stringing it along until people were out of warranty and just tried to sweep it under the rug. Same is happening here. You cant tell me that after 4 years they don't have a solid fix for this. They know whats going on.
    Hot Taco sauce and AKGSD like this.
  20. Jun 30, 2020 at 11:48 AM
    #6140
    ericf
    Eric
    Well, Update this afternoon, Dealer's service dept Rep called me And gave me a summarized report. He stated that they had contacted Toyo tech assistance, (Field rep?) and have ordered a new rear diff for my truck. The diff should be in tomorrow morning and they may be finished as soon as tomorrow evening. I hope this is a solution. I know through others postings here that I may regret this action basically making things worse as for volume and noise freq. I hope not. It seems to be a coin toss, Heads you lose, tails you may still lose. If it is the same or worse , Ill prob. be trading the truck in on something else.
    AKGSD and The Real Moondog like this.
