3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Aug 15, 2020 at 10:47 AM
    #6181
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While i never got to check out the latest frontier trucks, so i can't comment there, but i did look over their previous models pretty well. Imo, they just seemed cheaply built when compared to the tacoma.
    On another note the tacoma appears cheap in many areas vs the tundra.
    jetfishn[QUOTED] likes this.
  2. Aug 20, 2020 at 7:06 PM
    #6182
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Anyone solve the howling problem without putting MT’s on? You would be a TW superhero.
    jetfishn likes this.
  3. Aug 20, 2020 at 7:36 PM
    #6183
    jetfishn
    jetfishn Well-Known Member
    How about this? Next guy that buys an Offroad model new, bring it straight home, drop the rear diff fluid, add Amsoil Severe Gear 75-140 oil from day one to the rear diff? See what happens in the next few thousand miles. Since most all Tacomas seem quiet from factory, something seems to be "wearing" for noise to start after a few thousand miles. If the Amsoil Severe Gear oil doesn't work, just drain it and replace with oem fluid before taking to dealer for any warranty work. I would say there is a decent possibility using Amsoil Severe Gear 75-140 gear oil from day one would solve the issue.
    jrshaw91450 likes this.
  4. Aug 20, 2020 at 9:41 PM
    #6184
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I’m officially selling mine. That oughta do it :thumbsup:
  5. Aug 20, 2020 at 9:47 PM
    #6185
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Did it. Didn't work. I swapped out Lucas 85w-140 immediately when they replaced my first differential. The second differential is louder than the first.
    AKGSD likes this.
  6. Aug 20, 2020 at 10:11 PM
    #6186
    jrshaw91450
    Maui
    Going second gen or different brand ?
  7. Aug 20, 2020 at 10:47 PM
    #6187
    AKGSD
    Joe
    Alaska
    For now going back to my old 2000 GMC sierra with 240k.... with a dent in every panel from the previous owner. Makes it the ideal truck, because i can abuse it with no qualms. Whats a few more scratches? And somehow it’s needed less work than the brand new taco, so... yeah i’m happy to be going back. Kinda sad. Bittersweet.
    Most importantly — no diff howl ;)
  8. Aug 21, 2020 at 7:34 AM
    #6188
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Unfortunately I reached that same conclusion. Best of luck to you.
    AKGSD[QUOTED] and jetfishn like this.
  9. Aug 21, 2020 at 9:18 AM
    #6189
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    amsoil is leagues above any lucas oil. he said to use amsoil. not lucas.
  10. Aug 21, 2020 at 9:25 AM
    #6190
    jetfishn
    You would think Toyota would know by now what is causing this rear diff whine and fix the problem. They sure don't seem to care. They keep spitting out defective trucks with bad rear diffs as fast as they can build them. Leaving behind them a trail of disgruntled owners.
    AKGSD likes this.
  11. Aug 21, 2020 at 11:06 AM
    #6191
    The Real Moondog
    Moondog
    I’m sure they know but I feel the issue is a design flaw (or supplier issue that thy cannot easily get fixed) that would cost them a bundle so they’re choosing, like many other manufacturers, to try to appease the squeaky wheels. I had hoped for a fix so I could get back in a Taco but honestly feel like this will go on until the 4th gen gets here. Bummer.
    jetfishn[QUOTED] and jrshaw91450 like this.
  12. Aug 21, 2020 at 11:33 AM
    #6192
    cryptolyme
    Virginia
    you may need to adjust the lash. maybe not done properly at the factory. or it could be tight tolerances that just some wearing in.
  13. Aug 26, 2020 at 11:25 AM
    #6193
    Apatchi
    Apatchi Member
    Tacoma sport 2018
    My Tacoma TRD- Sport 2018 had differential noise issue when it was on 22k miles and the dealership replaced it for me after several tests. Everything become normal and after about 10k miles I started to hear a woooo noise for about 2 seconds when the speed become 52 mph to 60 mph then the differential become silent. I left the truck for about 6 days to the dealership then they told me it is normal They compared it with other aromas and they do the same noise that means no issues. I got the phone call 15 minutes ago telling me to come and pick up my truck, he said I am still having the warranty and it is in the system, whenever become worse they will take care of it.
    I Really don’t know what to do
  14. Aug 26, 2020 at 12:34 PM
    #6194
    cryptolyme
    Virginia
    that sounds like the a/c condenser not the diff
  15. Aug 26, 2020 at 12:46 PM
    #6195
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Are u sure it’s the rear differential?? It might just be the drive shaft . I have a noise when accelerating .. let of the gas and it stops . Dealer diagnosed it as the drive shaft noise normal .
  16. Aug 27, 2020 at 10:11 PM
    #6196
    jrshaw91450
    Maui
    Not normal for a sport to have the dreaded whine.
    jetfishn and wmjchastain like this.
  17. Sep 1, 2020 at 9:21 PM
    #6197
    Mountainmike87
    Mountainmike87 Well-Known Member
    2017 silver TRDOR
    My truck is regeared and makes the exact same noise as it did before. It’s definitely not the diff
    ryan760 likes this.
  18. Sep 1, 2020 at 9:28 PM
    #6198
    jrshaw91450
    Maui
    Can anyone with carrier bearing spacers verify they still have the whine? Could the noise be transferring up through the driveline and the carrier bearing which is directly mounted to the frame? Maybe someone with a aftermarket driveline can verify if the noise is still present.
    Volt likes this.
  19. Sep 2, 2020 at 5:16 AM
    #6199
    Mountainmike87
    2017 silver TRDOR
    I have new gears, a lift, and a OME carrier bearing drop and it is still exactly the same as a stock truck. Pretty fucking kid tbh. I even sound deadened The whole rear interior and back wall and it did absolutely nothing.
  20. Sep 13, 2020 at 10:45 AM
    #6200
    EE-TACO
    EE-TACO Member
    Sam
    Northeast USA
    2020 TRD Sport Double Cab Short Bed Barcelona Red Metalic
    LED hood scoop light bar, LED Interior lights. Caliraised LED Raptor taillights, Roadmaster Active suspension so far...
    I have a 2020 TRD Sport that just turned over 15000 miles last week. I brought it in for service and brought up for the second time the rear end noise when coasting between 50 and 60 MPH. They did a test drive and heard the noise. Upon further inspection, they found meatal in the gear oil. They have ordered a replacement carrier assembly to install. Fingers crossed that this is a permanent fix.
    rmac010 and nDub like this.
