3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Sep 13, 2020 at 4:27 PM
    #6201
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    :fingerscrossed:
    shakerhood and The Real Moondog like this.
  2. Sep 17, 2020 at 8:01 PM
    #6202
    imjohn
    imjohn Well-Known Member
    I know there’s no solution to this but what have you guys done to reduce the noise? I feel like mine is unbearingly loud even when the volume is up to 35.
    wmjchastain likes this.
  3. Sep 17, 2020 at 10:02 PM
    #6203
    rmac010
    rmac010 Well-Known Member
    2017 DCSB TRD Sport
    I had the same scenario a couple of weeks ago. Truck has just over 20k miles. I drove it until the noise got too loud. All is good right now. It is very quiet.
  4. Sep 18, 2020 at 5:02 AM
    #6204
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd gladly trade some noise in my taco for a better, more compliant ride.
  5. Sep 27, 2020 at 9:05 AM
    #6205
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Any updates on Toyota silencing the whine? Does anyone know how to check if newer models were added to the existing TSB?
  6. Sep 27, 2020 at 10:13 AM
    #6206
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You should have went with the Off Road as it has a smoother more compliant ride.
    The Real Moondog likes this.
  7. Nov 19, 2020 at 5:15 AM
    #6207
    Howie D
    Howie D New Member
    2017 TRD Off Road
    removed mudflaps and put 3m clear protective film over nose and down sides by curved body lines to protect paint
    Canufixit likes this.
  8. Nov 19, 2020 at 6:29 AM
    #6208
    ericf
    ericf Well-Known Member
    Eric
    Texas Gulf Coast, Houston
    2020 TRD offroad 4x4 silver sky.
    lomax tonneau, amp bed extender , bed rug
    I had to verbally spar with toyo u.s.a. rep. regarding the whine. She constantly informed me that the rear diff whine was/is a normal attribute in the Off road model. Dealer informed me of the same after affirming the whine. The dealer even went as far as to tell me the Tundras are having this "Normal" issue. I went to a different dealer who advised that's it not normal. Second dealer did change the rear diff assembly. All was good for about 900 miles. Then the whine returned. Although It's not as loud (volume) , it's still present. It is loud enough that it's embarrassing when passengers are in the rear seat. The main problem for me is that you cannot "un-hear" it. I can only attempt to ignore it. I was hesitant to let second dealer change the parts out. Others on this forum have ended up with regrets because it resulted in it being worse .
    I've considered ways to isolate the the rear axle and drive line from the frame. HDPE shims, teflon, other materials placed between axle and springs. But cost of experimenting is prohibitive for me. The diff whine and autotrans shifting logic is my largest (only) complaints. Personally, I'd trade it in if the loss wasn't going to be so huge.
    If toyo ever offers a diesel in the tundra, I may reconsider my losses.
    I do hope the dealer and new diff install solves your issues.
    best to ya.
  9. Nov 19, 2020 at 7:20 AM
    #6209
    jrshaw91450
    Maui
    I’m not sure about other dealerships, but mine just tried to charge me $260 to diagnose the whine during my 15000 mile service. My truck is well under warranty being a 2019, so I believe this is a new tactic Toyota is pulling to hinder people from getting acknowledgment of an issue and do something about it. What good is a F#&$ing warranty if their now going to gouge you to address poor QC?
    Anyway, Ive grown to not care anymore if I don’t obsess about it. Getting ready to do a 5100 lift and some other stuff. I think 15000 miles is the magic number of acceptance/tolerance for me.
  10. Nov 19, 2020 at 7:22 AM
    #6210
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    That "diagnose" fee isn't a Toyota thing, it's a slimy service department thing.
    jetfishn and shakerhood like this.
  11. Nov 19, 2020 at 7:56 AM
    #6211
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
    selling mine....no more howl for me...POS
    jetfishn likes this.
  12. Nov 19, 2020 at 8:23 AM
    #6212
    nDub
    Lead Free Gasoline
    Update for me.
    I’m not sure what has changed but my howl comes and goes. I can go weeks before it pops up and when it does pop up it’s not that bad (comparatively to how awful it used to be).
    I have 58k miles and the last couple of years I’ve done a few loads of fire wood in the truck and the rear springs have settled quite a bit. About level with the front of the truck. Not sure if it’s related or not.
  13. Nov 19, 2020 at 10:56 AM
    #6213
    jetfishn
    jetfishn Well-Known Member
    Has anyone with deep pockets thought about going to a Dana 60 new rear axle assembly? Could be the cure. Toyota is using a third world cheap mfgr in Thailand to build their front and rear axle assemblies.
  14. Nov 19, 2020 at 12:53 PM
    #6214
    mikebur
    mikebur Member
    I have had the issue for two years now and I only have 12k miles on truck. First time they replaced the rear differential and noise reduced a lot for about 1k miles and then started again. Two more times complaining to 2 different dealerships and they said it is normal. Even one of dealership's technicians admitted it is not normal but he can not do anything about it since according to Toyota headquarters thats a normal noise. I wish the truck had the noise when I did a test drive.
    Anyways if Toyota is right then all tacoma offroad third gens must have the same issue. I wonder if anybody with similar experience like me had a chance to check another truck with at least 10k on it and notice that there are actually trucks that don't make noise. If anybody knows please let me know.
    If there are trucks out there that don't make noise I will go to dealership and trade in this crap. This time though I know exactly how to check the new truck for any sign of noise
  15. Nov 22, 2020 at 6:26 AM
    #6215
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    nDub[QUOTED] likes this.
  16. Nov 22, 2020 at 7:19 AM
    #6216
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    One year later and 16000kms(10000miles) my rearend whine is just barely noticable,not an issue,hasnt got any better or worse.
  17. Dec 15, 2020 at 2:06 PM
    #6217
    wmjchastain
    wmjchastain Member
    chazini
    2019 TRD Sport 4x4
    None
    My 2019 Sport TRD 4x4 AT 3.5 liter crew Cab Long Bed with 13K.
    It has a loud harmonic whine at 1500 rpm between 50-60 mph. It’s loud & very annoying! Carrier bearing?? Sounds like it’s right behind the drivers seat. Two dealerships & corporate have said, “Sorry, they all do that”. Zero attempt to even try to repair.
    I’ve hired an attorney & attempting to Lemon Law the truck. I would not feel right selling it to someone else.
    I owned a 2006 Sport TRD for 13 yrs & currently own a 2016 Highlander. Very disappointed with Toyota!!!
  18. Dec 15, 2020 at 2:08 PM
    #6218
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    19 off road and very minimal howling, honestly on 34inch mud terrain tires there’s a lot more noise so it drowns out and I could care less, the dif is fine just switched out the dif oil 2k miles ago and the oil looked perfectly fine and the magnet was pretty much empty
  19. Dec 15, 2020 at 2:53 PM
    #6219
    wmjchastain
    wmjchastain Member
    chazini
    2019 TRD Sport 4x4
    None
    Not certain it’s the rear diff that’s causing the problem. It would be nice if Toyota at least attempted to reconcile the problem.
    Besides...a $40K vehicle should not have this issue.
    jetfishn and ryan760 like this.
  20. Dec 17, 2020 at 1:21 PM
    #6220
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Not normal. Mine does not do this.
