3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jun 21, 2021 at 5:14 AM
    #6241
    ericf
    ericf Well-Known Member
    Eric
    Texas Gulf Coast, Houston
    2020 TRD offroad 4x4 silver sky.
    lomax tonneau, amp bed extender , bed rug
    I have finally had enough Irritating issues with my 2020 TRD OR. From transmission gear hunting all the time, un-usable cruise control (related to transmission gear hunting), Incessant diff. whine Between 50-60 mph, And now I'm hearing the engine around 2100 rpm sounding like I have jingle bells attached under the hood. At 27K miles, Thats it. It has been traded in . I have removed the one saving grace that I added (shift sense module) and said adios to the POS. Right now trade in values are insane.
  2. Jul 9, 2021 at 10:42 PM
    #6242
    humboldt_taco
    humboldt_taco New Member
    will
    2019 Black DCSB SR5 4x4
    I just got a 2019 sr5 that only had 7500 miles on it, and I noticed it right away. Can only hear it if radio is completely off, happens around 50-60 mph and only when I take my foot off the gas. I've got an AT, it howls almost constantly when I'm in cruise control too. super annoying, pretty bummed when I found out that it was going on.
  3. Jul 28, 2021 at 7:10 AM
    #6243
    Pengowirr
    Pengowirr Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    It just started doing it at around 26000 miles. I have a manual OR and its annoying!
  4. Aug 10, 2021 at 6:43 AM
    #6244
    crocoperson
    crocoperson Member
    2021 Army Green Tacoma TRD OR
    Creating an account for anyone in the future.
    2021 TRD OR got a howl at around 300-500 miles. Howl is noticeable at 53-57mph with light to moderate use of the accelerator. It also is very loud when breaking down to that range and coming back onto the accelerator. Took it in this morning at 1k and had a tech drive it with me. He heard the howl and diagnosed it within a minute. Rear Diff. Opened a complaint ticket, and noted that the field rep would be in the area in two weeks. Truck is obviously fine to drive, but stated they will more than likely replace the rear differential. They may replace it sooner if the field rep doesn't want to come in to look at it.
    I also noticed that there is an open tech ticket for 2020/2021 rear diff howls with this exact procedure.
    T-TT-0651-21
    Update: Tech called back. Regional Rep said Toyota is aware of the issue and working on a solution. He recommended to continue to drive the vehicle until the rep would arrive two weeks from now. Currently there is no guarantee that replacing the rear diff will permanently get rid of the howl.
  5. Aug 10, 2021 at 7:27 AM
    #6245
    CLT_Rick
    CLT_Rick Well-Known Member
    Nevada
    2021 TRDOR / 2016 TRDOR
    My 16 whined...now 21 does as well, exactly 55mph...not worth taking into dealership, drives fine!
    shakerhood likes this.
  6. Aug 10, 2021 at 7:31 AM
    #6246
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Now just turning 11k miles with my 2020...still no howling.
  7. Aug 10, 2021 at 7:42 AM
    #6247
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine makes some noise, no doubt about it. But it's not very loud nor does it scream "I'm dying now, right now, I'm dying...stick a fork in me I'm done dying now".
    More of a slight noise here and there mostly when I let off the skinny pedal, long down hill. I can hear something. Maybe not even 100% rear diff.
  8. Aug 10, 2021 at 11:28 AM
    #6248
    Mrlooney2288
    Mrlooney2288 Active Member
    Southern Ohio
    2021 Lunar Rock TRD Pro MT
    Mine makes a whirring whistle sound. Didn’t start it till after my 5k service. Took it back to them a couple weeks later and they couldn’t reproduce the sound. I tried to take someone with me but I could only get the service advisor and he said he doesn’t hear the greatest. Lol!
    TacomaAddict23 and cryptolyme like this.
  9. Aug 11, 2021 at 5:05 AM
    #6249
    ericf
    Eric
    Be aware, The dealer changing out the rear diff usually doesn't guarantee a fix. I found a dealer that told me the whine wasn't normal and they changed it out after I informed them of the rear diff lub being 1.2 quarts low from toyota. They told me that the pinion bearing bearing was prob ruined because of low fluid. This dealer also was denied by toyota to change it because of the whine be "Normal" designation,,,, from toyota. The low fluid level got me the new diff. All was good for 900 miles. Then the whine returned. If you read all the posts on this topic you will find some unfortunate souls that went this route only to end up in a worse situation with the whine being much worse. YMMV. Best of luck and I hope you are happy with the "fix".
    The guaranteed fix, Take "real Moondog" advise as I did, when you have had enough, and can no longer tolerate it, get rid of it.
    Trd TacoMan and The Real Moondog like this.
  10. Aug 11, 2021 at 7:14 AM
    #6250
    flafos
    flafos Well-Known Member
    Gerald
    New Port Richey, FL
    2019 4x4 DCSB TRD Off Road cement
    MY 2019 TRD OR DCSB with 33,000 mi has the howl. Pretty much had it from the beginning if I remember correctly. Just gonna drive it until they find a real "fix" lol
  11. Aug 11, 2021 at 9:53 PM
    #6251
    Mrlooney2288
    Southern Ohio
    Gfenza89 likes this.
  12. Aug 17, 2021 at 8:16 AM
    #6252
    Roberto123
    Roberto123 Well-Known Member
    robert
    2018 Tarcoma SR 4X4 Dbl Cab
    Have my SR into the dealer for rear diff howl noise: Dealer to replace carrier assembly including rear diff. Quoted at $2,500 but Covered under the 5 year 60,000. I appreciate that the dealer and tech chose to replace the assembly, unlike some other dealers I heard about on this thread.
    2018 4X4 dbl cab, 33,000 miles. Howling at about 40mph and above while feathering. Sometimes howling with different pitches during highway driving. Howling started about two months ago. Nothing too loud. Stock truck. Other than a Curt front receiver & A/T tires on stock rims.
    Bought used back in January. Light/moderate use only, mostly highway. Some slow and steady off-roading. Occasional utility trailer towing.
    I am disappointed that the truck needs such a major repair early in its life. This just feels like something a Ford would do. I am hoping to have this truck for many years.
    It should be done no later than Friday. I will give an update if I find out exactly what the issue was.
    Any thoughts? Will the new diff come with a new 60,000-mile warranty?
    nDub likes this.
  13. Aug 17, 2021 at 5:31 PM
    #6253
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I got a new diff at like 6k miles and the new diff noise was worse, like double bad. At which point Toyota told me it’s “normal”.
    I also had the TSB which helped a little.
    I’m closing in on 70k miles now and no failure yet.
    It comes and goes now and no where near as loud. Still annoying but I have no worries about failure.
    It’s a bummer and I believe will definitely effect resale (if that’s a plan) but I wouldn’t worry about failure.
    Roberto123[QUOTED] likes this.
  14. Sep 1, 2021 at 6:18 AM
    #6254
    crocoperson
    crocoperson Member
    Had rear dif, carrier assembly etc replaced yesterday. Hit the highway and while the noise is not nearly as bad, it still exists when feathering/ letting off the throttle right at 55mph. Previously it was very loud from 52-57 when lightly on the throttle- so driving highways was terrible. So far, i can travel at 55 on cruise without hearing it so thats a big improvement. Sucks that its still there, but one bit at a time. Dealer said they would contact me today after speaking to the rep again and see where to go from here.
  15. Sep 2, 2021 at 7:07 AM
    #6255
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I wouldn't mess with it again , it's under the 60k warranty so see how it goes .
  16. Sep 2, 2021 at 7:11 AM
    #6256
    crocoperson
    crocoperson Member
    Yea Im going to put a lot more miles on it and see how she goes. At least i dont have to listen to it when cruising anymore.
  17. Sep 2, 2021 at 9:45 AM
    #6257
    RTD
    RTD Well-Known Member
    Taxachusetts
    Haven't read every single post here but Mopar makes an LS additive that I have added to LS gear oil when clutches in a LS differential were a little grabby.
    Don't know if this will quiet your howl.
    My 2008 TRD Sport had a bum rear end and the dealer replaced it at 30k miles.
    They tried to tell me it was something I i did(?). but after fighting with them they replaced it.
    Just my 2 cents
  18. Sep 4, 2021 at 9:59 PM
    #6258
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Solutions have been posted and people appear to be too lazy to search them out.
    It’s a resonance coming from the rear diff and traveling through your leaf springs to the frame and into the cab. Buy a different rear leaf spring setup and the resonance will no longer make its way into the cab. Think of it like the leaf springs being a tuning fork. Strapping more metal to it will stop or dampen the tone. Swapping diffs has a slim chance of fixing anything. It’s not a bearing failing.
    Anyone in here with Icon RXT, OME Dakar, Deaver or Alcan leaf springs notice the noise after spring install?
  19. Sep 5, 2021 at 4:34 AM
    #6259
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I have the original leaf springs. Once I coated them with Wool Wax, along with the rest of the undercarriage, the howl stopped.
    Marcmtb1[QUOTED] likes this.
  20. Sep 5, 2021 at 5:35 AM
    #6260
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Same here. Well I used Amsoil HDMP on the leafs. Pretty sure people called me nuts BUT I am also pretty sure it didn't work for everyone, well maybe some/most/many didn't try it.
