3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 10, 2023 at 7:08 PM
    #6321
    Jhor82
    Jhor82 Member
    What is the TSB?
  2. Jan 10, 2023 at 7:10 PM
    #6322
    Jhor82
    Jhor82 Member
    Forget it. I looked it up. I will mention this to Toyota when I go. Thanks.
    nDub[QUOTED] likes this.
  3. Jan 10, 2023 at 7:11 PM
    #6323
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    It was for the first few years of the 3rd gen. I figure they just included it with the later years.
    Jhor82[QUOTED] likes this.
  4. Jan 11, 2023 at 5:14 AM
    #6324
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    My 2021 has done in since about 7,000 miles or at least that's when I noticed it. New fluid seems to work for a week or so before it comes back. I bought the harmonic dampeners and put them on, those completely stopped it for for about 2 weeks before returning. I'm at about 35,000 miles, if this is a problem is it covered under the 60k powertrain?
    Jhor82 likes this.
  5. Jan 11, 2023 at 5:58 AM
    #6325
    Jhor82
    Jhor82 Member
    Yea. Was shocked to see all these posts from over the years and shocked Toyota never took care of it. Like a dope I sold my 20 trd off road and bought this 21 sr5 cause they were paying so much for used cars during Covid and it came back to get me. Truck seems to run fine just drives me nuts. Hoping this service fixes the problem but no confident it will after all I read. Had an 87 Toyota pick up. 2001 S runner. 2004 Tacoma , 20 trd off road. And now this 21 SR5. This is the first truck I ever had an issue with.
  6. Jan 11, 2023 at 8:40 AM
    #6326
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    No howling yet in my 2020 sr5.
  7. Jan 18, 2023 at 9:36 PM
    #6327
    always-entropy
    always-entropy 2022 DCSB OR
    Collin
    Puyallup WA
    2022 DCLB OR Army Green
    RSI Smart Cap, Baja SAE fogs, KDMAX PRO tune
    Wow! How have I not found this thread yet! I kept searching for whine or whirr but not not howl.
    Checked out some youtube videos and could hear similar sounds. Is it a whirring sound for others?
    I have about 19k on my truck and noticed it early on but seems to be getting worse, almost unbearable as it's all I can hear!
    Glad to know it's not just me but super frustrating for a new truck this late in production...
  8. Jan 19, 2023 at 6:42 AM
    #6328
    fred 1954
    fred 1954 Member
    jason
    2016 tacoma 4x4 trd 4 door long bed
    ovtune
    after talking to a person from toyota,, the manufacturer that builds/assembles the rear differentials are not always setting the pinion depth correctly.. it is suggested that the gear pattern be check before install into rear axle housing !!
  9. Jan 19, 2023 at 6:52 AM
    #6329
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm at I'm 180k + miles still whines and I'm still fine . Just change fluids every 30k miles
  10. Jan 19, 2023 at 12:06 PM
    #6330
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Known to be false.
  11. Jan 19, 2023 at 8:42 PM
    #6331
    nDub
    Lead Free Gasoline
    Known? I mean I don’t believe they don’t check it but I don’t absolutely “know” they don’t check it.
    I’ve also set up my fair share of third members to know there’s plenty tolerance either way.
  12. Jan 19, 2023 at 9:12 PM
    #6332
    ShimStack
    Ben
    NC
    Given the number that whine and never blow up points to not a setup issue. Given that perfect setups of new/used, oem/aftermarket gears have been performed countless times by the most respected gear shops and still will whine points to not a setup issue. Given that these top gear shops that have the most experience with these gear sets include a disclaimer that they won't chase "gear whine" points to not a setup issue. Given the total number in use that are not failing or blowing up period points to not a setup issue.
    I've said it before, gears make noise and have inherent vibrations. In the wrong system there can be resonance and harmonics that are audible and annoying to humans. It's not a gear issue, it's a system level NVH issue and that is why it's not gears that are a solution to this problem. You have to change the characteristics of the system being excited with something like different tires, leaf springs, cab mounts, topper, etc.
  13. Jan 20, 2023 at 3:53 AM
    #6333
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    That’s an interesting statement and I never thought about it. Yes, I understood it was harmonics. I had a high howl only when soft petaling/deceleration about 50-70. Just ignored it as part of the truck. Your mention reminded me, It’s gone. Haven’t heard it in quite a while. I did add a leaf to the pack and relube the friction points. Never questioned the gears based on past comments and clean drains and chip magnet drain plug.
  14. Jan 20, 2023 at 4:59 AM
    #6334
    nDub
    Lead Free Gasoline
    I dunno, Toyota told me it was my rear diff. Replaced it even.
    Then changed my cab mount, leaf springs. I put a topper on my truck and different sized tire etc. Still have the noise. And for the record it’s not “gear whine” like a poorly set up gear set. It’s more of a resonance like a tuning fork. I also hear it in other cars now. I’m finely tuned into it.
    My opinion is whoever is making these third members is using poor metal quality (probably too hard).
    All that said I have 85k miles on my current diff and I don’t think it’ll fail on me. It’s just annoying and if I ever try and sell it it’ll be an uphill battle to convince anyone that it’s normal.
    NoOne and shotgunbilly420 like this.
  15. Jan 20, 2023 at 9:04 AM
    #6335
    slapntz
    slapntz Well-Known Member
    The noise reminds me of a school bus as a kid. I hardly notice it in mine - its faint, decel with narrow mph window, downhill. I have 4.88's built by ECGS and the truck did it before even worse with the stock diff. Also have a hellwig rear sway bar. Break-in and fluid change def quieted it down. Ordered the dampers as my 2021 didn't come with them - interested to see if they help. Plan on removing the interior during the summer to sound deaden it anyhow.
    Darkice likes this.
  16. Jan 20, 2023 at 12:55 PM
    #6336
    Jhor82
    Jhor82 Member
    Got my rear differential replaced yesterday on 21 sr5 with 5,000 miles. As soon as I drove off the lot the howl was still there on deceleration. Went right back in to dealership. They made a case with Tacoma. got a call tonight that said Toyota will not be repairing any more on your truck. That the howl is normal. I said it's not. I had a 19 and a 20. None made noise. They said I'm sorry. Nothing further we can do at this point. I said so it will just howl. They said it's normal. I said it wasn't normal when you said I needed a new rear differential?! They said I'm sorry. Nothing more we can do. It's normal.
    TacomaAddict23 likes this.
  17. Jan 20, 2023 at 1:00 PM
    #6337
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    fwiw, i put in amsoil severe gear (75w-90) in at 500 miles and i haven't heard any howling/whining yet at 17,000 miles. the break-in process is extremely important with rear differentials. this may explain why some new units will make noise.
    Pablo8 likes this.
  18. Jan 20, 2023 at 1:06 PM
    #6338
    Jhor82
    Jhor82 Member
    Had several Tacomas over the years. This is a weird problem that I think only happens to a few.
  19. Jan 20, 2023 at 1:17 PM
    #6339
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Interesting!
    While my rear end is not the quietest it sure never howls. When I regeared to 4.88 I dumped the break-in fluid after 500 and went 75W-110 Severe Gear.
    cryptolime[QUOTED] likes this.
  20. Jan 20, 2023 at 1:26 PM
    #6340
    slapntz
