3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 20, 2023 at 1:39 PM
    #6341
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    I broke in my stock rear gears just like you would if you went aftermarket. Changed front, rear and transfer case oil @ 500miles. Absolutely no noise 7000 miles later.
    BTW it did look dirty with little metal flake look to it. Just cheap easy insurance? Or overkill?
    cryptolime likes this.
  2. Jan 20, 2023 at 2:31 PM
    #6342
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    That's my guy I run amsoil also good stuff
  3. Jan 20, 2023 at 5:31 PM
    #6343
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Oh yeah. I’ve been running severe gear amsoil since 500 miles. Front and rear diff.
    shotgunbilly420 likes this.
  4. Jan 20, 2023 at 6:24 PM
    #6344
    shotgunbilly420
    One of my service's transfer case 28k mi still looked nice. Had a gold color slightly but wasn't bad at all . Serviced my rear end one time at 50k miles , yeah not again too long
    nDub likes this.
  5. Jan 31, 2023 at 5:00 AM
    #6345
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    fwiw.
    '22 TRD Sport AC 4WD MT ~ 15K miles with chin strap on. i have a slight howling noise from what sounds like the rear diff around 50-60 MPH as i feather the gas pedal. seems to be more noticeable when i am going down a grade as opposed to on a flat. the noise has been there from new and the truck 'broken in' gently.
    i recently changed the factory fluid to amsoil 75W-90 severe gear and there is no change in the noise level. the original fluid was not terrible in appearance and there was only the normal metal flaking on the magnetic drain plug.
    unless the noise worsens, i have no plans to take it to the dealer as it sounds like this is normal tacoma stuff from what i read here and elsewhere.
    SilverBulletII likes this.
  6. Jan 31, 2023 at 6:48 AM
    #6346
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Pablo8 likes this.
  7. Jan 31, 2023 at 9:22 AM
    #6347
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    if you try the 110 let us know if it quiets it down at all
  8. Jan 31, 2023 at 12:09 PM
    #6348
    2019 TRD Off Road
    Will do, but I doubt I’m going to spend another $80 to redo it if I’m being honest. I’ll put up with a minor hum for the supposed better MPGs.
  9. Feb 21, 2023 at 4:10 PM
    #6349
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Just had my differential replaced under warranty. No whine on my way home except from the toddler in the back seat. Asked the tech if I should follow the 500 mile break in procedure like you would with after market gears. Long story short, he’d never heard of it and doesn’t recommend changing the oil for 50k miles… I’ll be following the 500 mile break in procedure and changing the oil to Amsoil severe….
  10. Jun 20, 2023 at 10:04 AM
    #6350
    weezykid
    weezykid Well-Known Member
    2023 TRD OR DCSB 4wd
    Well I am back and must be a gluten for punishment. Picked up a '23 offroad again in March and back in the howling game...... My local dealer said they couldn't hear it today so I have to go to one I know will fix it. But once replaced I will def go the Amsoil route after 500 mile break in like others are stating.
    Its odd.. I have had (2) 5th gen 4runners with no howl, this is my second 3rd gen Tacoma with a howl and my '21 Tundra howled as well. Seems to be the US/Mexico built trucks and I am wondering if they are sourced differently than the 3rds for the 4runners (compared to the Tacomas).
    But not swapping fluid until warranty replaces it.....
  11. Jun 20, 2023 at 11:16 AM
    #6351
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    That isn’t going to fix it by replacing diff. They replaced my diff on my 2023 made zero difference
  12. Jun 20, 2023 at 12:00 PM
    #6352
    onemorecast
    onemorecast Member
    I just had mine replaced on a 23 TRD Sport, and it is no different than the original one.
    Gfenza89 likes this.
  13. Jun 20, 2023 at 12:02 PM
    #6353
    weezykid
    So we're just wasting time going through a replace?
    Any update on your whine?
  14. Jun 20, 2023 at 12:57 PM
    #6354
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    - 1 month old 23 2wd Sport with 5k miles and no whine
    - 20 2wd Sport with over 100k miles and no whine
    - 18 4wd Sport with over 240k miles and no whine
    - 16 2wd Sport built during the first month of 3rd gen production and it whined when it was parked or driving. Two new complete rear ends and eight different flavors of rear end lubricants did nothing to resolve the problem.
  15. Jun 20, 2023 at 4:50 PM
    #6355
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    It’s whining again. Not as bad as the original but it’s there. Changed and replaced the OEM oil with Amsoil severe gear oil after 500 miles. After all that I learned that it’s not so much the diff that’s whinny it’s the whole rear end design that makes it whine, diff,leaf springs, shocks etc…Resonance is what they call it. There’s some pretty good threads on it on here that explain it better than I can.
    MannyS likes this.
  16. Jun 21, 2023 at 1:31 PM
    #6356
    onemorecast
    onemorecast Member
    It's just strange why some do whine and others do not. It looks like after building the same truck for eight years, Toyota could figure out what is different between the trucks that do and the trucks that do not whine. I had a 2022 before the 2023 and it did not whine. I had a 16 that did and 18 that did not. I understand it is a resonance noise, but I still feel like it caused by the set up of the rear diff. causing a vibration to resonate through the leaf springs.
    I am not sure going through a replacement is waste of time. However, I feel like the odds are against you getting one that does not whine. This is why so many dealers are reluctant to replace the diff. Most have had very little luck in stopping the noise. There best line of defense is to say it is normal. Once they make an attempt to repair, it now becomes a lemon law situation if the customer pushes the issue. I know first hand, they want to fix your truck, they just do not have way of doing so.
    FLAK-TAC likes this.
  17. Jun 27, 2023 at 3:36 PM
    #6357
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    What does one do, if the rear differential never whines?
  18. Jun 27, 2023 at 3:41 PM
    #6358
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
  19. Jun 27, 2023 at 3:59 PM
    #6359
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Buy a sound generator?
  20. Jun 28, 2023 at 4:02 AM
    #6360
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    simpler… a pinch of sand in the diff… First the truck will whine, and then you will…
    Pablo8[QUOTED] likes this.
