3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Sep 27, 2016 at 12:02 PM
    #1041
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    My 2nd gen has always done this.
  2. Sep 27, 2016 at 12:16 PM
    #1042
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Most likely the pinion bearing as notes a few posts back.
  3. Sep 27, 2016 at 3:58 PM
    #1043
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    how would toyota go about fixing the pinion bearing issue? if they got off their asses...
  4. Sep 27, 2016 at 5:03 PM
    #1044
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Ok final update:
    I posted two videos a few pages back, I will update this post with them later (or if someone wants to quote them). The first video was my first differential, the second was my new one one day after replacement.
    The final word from toyota is that the first video is an unacceptable noise level. The 2nd video is what they consider an acceptable noise level. They really would have preferred for the dealership to have an engineer come done and personally witness the first differential but it didn't happen that way with how quickly it got replaced.
    So that's where it stands. There will be no further action moving forward unless the sound gets worse over time or there is a failure of some sort.
    One theory from them (although I'm not sure I am going along with it because it happened with both my stock exhaust and aftermarket) is that the exhaust harmonic at light throttle is amplifying the differential harmonic when floating the gears. The other is sound damping used in the truck may not be enough to damp out "normal" sounds. The shop saw no issues with the gears or fluid when replacing my first diff. Of course toyota will be independently looking at returned differentials for damage.
    So this is quickly turning into a "deal with it" solution. I was advised to heavily consider keeping the truck based on the warranty I received and the loss I would take on trade in. Those two combined would be worth maybe $8k total?
    So I recommend you guys watch both videos I posted and come to your own conclusion.
    Oh, and the "special format" toyota needed was just filming the speedometer at the same time as the noise.
    Good luck everyone. Looks like I'm down for the count unless things get worse.
    Edit: also forgot to add that they were in a bit of a pickle anyways because toyota needs them to drive a new truck the exact same configuration for a complete diagnosis, which just isn't possible to find here where I'm at in SoCal. 4x4 M/T
    I will also say this is still the best service team ive worked with, especially with how knowledgeable the shop foreman is. If anyone in san diego needs a recommendation, let me know. Plus it will be better if multiple of us can start going through the same service departments
  5. Sep 27, 2016 at 5:35 PM
    #1045
    tacoflavoredkisses1
    you should ask them to wrap the diff in dynamat.
  6. Sep 27, 2016 at 5:59 PM
    #1046
    trdgentaco
    trdgentaco Well-Known Member
    Atlanta, Ga
    2016 tacoma DC OR MT, 89 sassed 4runner
    .... so hurry up and get them to replace mine and big them for an extended warranty before the standard response is its normal? Will do.
  7. Sep 27, 2016 at 6:01 PM
    #1047
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Good luck, they are already coming back saying this is normal.
  8. Sep 27, 2016 at 6:06 PM
    #1048
    tacoflavoredkisses1
    Haha do it! Let him join in on the fun!
    When it was first happening I had to point it out to my GF. Who promptly got annoyed that I brought it up.
    Now that its getting worse, she brings it up or hums at the same frequency.
    The howl is so fucking annoying.
    ZachMX likes this.
  9. Sep 27, 2016 at 6:07 PM
    #1049
    ZachMX
    I tried to explain it to my GF as well and point it out, she was like "oh okay, whatever you say babe", she also thinks that the oil change sticker on her corolla meant how much her car was worth, its a good thing she's pretty...
  10. Sep 27, 2016 at 6:10 PM
    #1050
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
  11. Sep 27, 2016 at 6:12 PM
    #1051
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    I think I'll spare him the suffering for now. If it gets really bad he'll notice haha
  12. Sep 27, 2016 at 6:13 PM
    #1052
    aero90
    Yeah I'm pretty much at the point where my hands are tied and so is the dealerships. It's all corporate now and if they believe the second video is normal then it's game over.
    Will I keep the tacoma for a bit? Probably. Will I consider a toyota for my next vehicle? Probably not if this is left as "normal". But I really am afraid to see where the auto industry is headed. Hybrid trucks are next with the ridiculous EPA regulations. This may be the last generation I even buy a new vehicle. The 3rd gen tacoma may very well be last generation before the 4th generation hybrid.
    I even saw build quality issues in the BRAND NEW corolla they gave me. 2200 miles and it already had dash rattles and the steering wheel rubbed like a mofo when I turned it. Is this a toyota thing now or what is going on with the quality??
    Joe23 likes this.
  13. Sep 27, 2016 at 6:15 PM
    #1053
    trdgentaco
    Atlanta, Ga
    I found your videos. I'm not sure what the difference between the two other than one is a little more consistent. It's the same noise if you ask me, actually if you said it was the same diff I would have believed you
  14. Sep 27, 2016 at 6:15 PM
    #1054
    ZachMX
    Lol, I made them give me another Tacoma loaner, 2017 with the same howl but faint.
  15. Sep 27, 2016 at 6:17 PM
    #1055
    aero90
    It was only more consistent due to traffic conditions and me trying not to get someone riding my ass in the second video. I had to speed up and slow down a lot more. But corporate listened to them both, did what they needed to do, and the 2nd video is what they now consider a normal sound level inside the cab.
  16. Sep 27, 2016 at 6:19 PM
    #1056
    tacoflavoredkisses1
    I'm not sure whats going on. I heard so many great things about tacomas and that they lasted for 300K miles. I've wanted one since highschool and I finally decided to get one back in 2015. Then I decided to wait because the new ones actually had modern tech in them. Enter the 2016.
    I love the truck, but I also hate this pos. It would be the most perfect vehicle I've ever owned if it didn't have these completely unacceptable and preventable issues (rumble strip stopping and diff howling). The tranny TSB fix that for the most part. I'm also getting a shitty pulsating feeling in my brake pedal from the accumulator which isn't normal at all not matter what anyone tells me.
    I want to love it and like driving it. I just get reminded on a daily basis, at almost every speed, of the serious powertrain and driveline issues it has. Toyota gets one more shot at it for me before I start a twitter campaign to call them out on this BS.
    barney7 likes this.
  17. Sep 27, 2016 at 6:22 PM
    #1057
    Hicap239
    Hicap239 Member
    2017 TRD OR
    Hello Everyone,
    I just stumbled across this site while looking for accessories for my new 2017 Tacoma TRD OR. I have not taken delivery of it yet, that happens on Thursday. I am a bit unsettled to hear about the rear diff noise that so many people are having. Are there any owners of 2017 Toyota Tacoma's having this problem too? At this point I don't even want to pick it up! I am seriously contemplating backing out of the deal now. I purchased Toyota because of their reliability. What do you guys think, should I just get my money back and buy a model that is used and a few years older or take the chance of a new purchase? 35K is a lot to invest then have frustrating issues with one of the major components in a new vehicle. I have read here that some members have had the rear diff's replaced and it is still an issue. I have worked on these in fords before and if they are not set up correctly they will fail, the problem is if they are only out a little the problem can become major after the warranty has expired. I am sorry, Toyota should be able to replace these then inspect them and easily determine where the problems are these are not overly complicated. From what I am hearing it gets worse with time, that makes me wonder if something is not spaced correctly and to much contact is being made between the ring gear and the pinion gear and with time the excessive wear causes the noise or if something is coming out of adjustment which should not happen. I don't know this just makes me sick and I have not even picked up the truck! Let me know what you guys think.
    Thanks in advance,
    wish I would have found this forum sooner!
    Ted
    trdgentaco likes this.
  18. Sep 27, 2016 at 6:24 PM
    #1058
    trdgentaco
    Atlanta, Ga
    Me personally would buy a used second gen if going to do over. Others would disagree. I love the truck and the way it looks. Just the many issues are worrisome
  19. Sep 27, 2016 at 6:25 PM
    #1059
    ZachMX
    Welcome, and in a nutshell, my 2017 loaner has it, and a few others with 17s here have reported it. No word on a fix from toyota as replaced diffs still make the sound. Like you theorized, its likely a design/manufacturing issue. Besides this issue, though Ive had a few small ones, I love my 16 and I've owned 5 of the these trucks, just a bit concerned on long term reliability.
  20. Sep 27, 2016 at 6:25 PM
    #1060
    ZachMX
    I kick myself everyday for trading my 2015.
