3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Oct 21, 2016 at 2:17 PM
    #1361
    Haany4x4
    Haany4x4 Well-Known Member
    Calgary, Canada
    2016 Blue TRD Sport 4x4
    Im talking km and they said engone oil. It was weird to me cause the manual says 8000 and i tries explaining the diff noise first that was the main issue i have and oil was no where im my worry books. But to her i really dont need to worry about the oil and get my tires rotates and check alignment and top up fluids is all.
  2. Oct 23, 2016 at 9:05 PM
    #1362
    Haany4x4
    Calgary, Canada
    I got my rear diff replaced and no noise...so far
    16tacoma1972, ZachMX and Joe23 like this.
  3. Oct 24, 2016 at 5:36 AM
    #1363
    trdgentaco
    trdgentaco Well-Known Member
    Atlanta, Ga
    2016 tacoma DC OR MT, 89 sassed 4runner
    Notice while driving my dads 2011 Tundra i was using to move into a new house this weekend that it makes the same howl right at 50-55mph too. Its a little louder on his truck but that may be from having 40k instead of the 2500 miles that my truck has. But it also does make me wonder if this has been a thing with toyota trucks for a while and no one really noticed or complained much online. That or my dads tundra needs a new diff at 40k
    2016Tacoman and Mace587 like this.
  4. Oct 24, 2016 at 5:44 AM
    #1364
    Mace587
    Mace587 Well-Known Member
    North Carolina
    2016 DCSB TRD OR 4x4
    I think it's a pretty common thing, especially with these trucks. With all of the modding that folks do it would be easy to cover up the noise and never really notice it. I put one size bigger and slightly more aggressive tires on my truck, everything else stock, and the howl is much less noticeable than it was before.
    trdgentaco[QUOTED] likes this.
  5. Oct 24, 2016 at 4:49 PM
    #1365
    TacoMA36
    TacoMA36 Member
    2016 TRD OR 4x4 AT DCLB
    I mentioned the howl at my first service. They drove it and immediately said it was a bad rear diff so they replaced it the next day! And.....it's still there, and maybe a slight howl at 30mpg now (yes LCAs are already plugged). So they took the truck back and tried to isolate the noise to the transmission or transfer case and even brought a regional engineer out. And then they said it was normal. For now. My service advisor thinks something isn't quite right but his hands are tied with Toyota saying it's "normal". Hopefully a TSB comes out for this.
    At least I already got the 8 yr/125k platinum warranty from corporate for the low ATF issue.
  6. Oct 24, 2016 at 5:31 PM
    #1366
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    So with all these reported vehicles impacted, has anyone actually got a video clip of what the noise sounds like? I'm kind of curious to know how bad this sound is that's causing so many folks to go through warranty replacements that just do the same.
  7. Oct 24, 2016 at 5:34 PM
    #1367
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Yep there's a few in here. Look some pages back.
  8. Oct 24, 2016 at 6:39 PM
    #1368
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    @smitty99
  9. Oct 24, 2016 at 7:01 PM
    #1369
    Scooby24
    Greg
    2017 DCSB OR 4X4
  10. Oct 24, 2016 at 7:53 PM
    #1370
    ZachMX
  11. Oct 25, 2016 at 3:24 AM
    #1371
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm waiting on a replacement transfer case as we speak. The tech told me that my rear diff was quiet, and that the noise was coming from the T-Case output shaft bearing. Time will tell.
    Frank
  12. Oct 25, 2016 at 6:28 AM
    #1372
    2017TacoMan
    2017TacoMan New Member
    I'm getting close to buying a 17 Taco DCOR Auto, but I'm hearing and reading all these threads about water leaks, diff noise, etc and it's kinda concerning. It will be my first Toyota and I don't want a bad experience right out the door.
    Now I know Tacomas hold value and are a good brand but maybe I should hold off for a few months so the initial issues get locked down......:/
  13. Oct 25, 2016 at 6:47 AM
    #1373
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Find any truck forum that doesn't have complaints.
    0 issues here.
    slamson00 and Mace587 like this.
  14. Oct 25, 2016 at 6:55 AM
    #1374
    Mace587
    North Carolina
    Buy it, it comes with a warranty if you have any problems.
  15. Oct 25, 2016 at 7:16 AM
    #1375
    Ed Crankshaft
    Ed Crankshaft Well-Known Member
    2016 Black Tacoma TRD 4X4 DCSB
    This is the second new 4x4 I've owned that has quirks. My Tacoma has a slight noise coming from the rear differential or somewhere underneath the truck when I am driving between 55 and 65 miles per hour. It's not terribly loud and hasn't gotten any noisier, but I only have 4500 miles on the odometer. There is a noise coming from the LCA on a windy day, but I do not find it annoying.
    I moved from a 2011 Wrangler 4 door to the Tacoma and the Wrangler was not without it's quirks. If you ran OEM recommended weight motor oil, it consumed oil. I had to run 10w30 to stop the consumption. The steering was not as precise as the Tacoma and it did not have the power my Tacoma does. The brakes were not very good from the first day I drove it off the lot.
    I looked at GM trucks, both Chevy and GMC, before buying my Tacoma. They were less expensive, but they had bigger issues, so I steered clear of them.
    With all the complaints I see on the internet, I expect to see a Tacoma completely engulfed in flames every time I leave the house and drive into town. That is not the case in my area.
    I really enjoy driving my Tacoma, and the fact that it is peppier, handles better, has more cargo room and get's better gas mileage than my Wrangler. Find a good dealership you can trust and test drive a Tacoma before counting it out.
  16. Oct 25, 2016 at 9:07 AM
    #1376
    2017TacoMan
    Also a good point
    Mace587[QUOTED] likes this.
  17. Oct 25, 2016 at 9:19 AM
    #1377
    Mace587
    North Carolina
    I've started to consider the diff howl a non-issue. I don't think we've seen any fail as a result of this noise, and supposedly most of the diffs that were replaced were in spec, so I really wouldn't let this keep you from buying a Tacoma. If there are problems with them, I'm sure they will start to show up before most people hit their 60k powertrain warranty limit. Sure its annoying, but put some more aggressive tires on there and you hardly notice it. Really the only thing I have seen that concerns me is the CPS failures, but its my understanding that those were sorted out by late 2016, so the 2017s should be good to go.
    I say go for it!
  18. Oct 25, 2016 at 12:13 PM
    #1378
    MOC221_
    Frank
    You may very well be right, but I plan to keep my rig for the long haul. If my issue turns out to be a bearing in the T-Case as the tech suspects, I would not want to be paying for the repair out of pocket should it decide to grenade down the road. Labour alone is 8hrs to get the unit swapped. I just can't ignore that noise, it signals trouble to me (and it's too obvious to miss in my truck, I didn't read a thread and then go looking for it).
    Frank
    fdbyrne and Mace587[QUOTED] like this.
  19. Oct 25, 2016 at 1:11 PM
    #1379
    Mace587
    North Carolina
    Seems like you have a separate issue altogether. I know in my case, as well as others in this thread, the noise was isolated to the rear diff by running the truck on a lift - and was again verified after it was replaced. I would be just as concerned as you if they had told me the noise was coming from the transfer case.
    I definitely think folks with the diff noise should have it documented in case problems do arise in the future, as suggested numerous times throughout this thread, but until we start seeing some failures or other issues arise due to the noise, I just don't think this is a reason to keep people from buying this truck. It seems like the couple of failures we have seen gave people some warning with grinding and/or leaking/sweating seals prior to failure - none of which I have experienced. I also expressed my concern about issues arising after the warranty period, and my case manager at Corporate told me that Toyota is typically good about standing behind documented issues that end up causing failures after the warranty period. He was probably just trying to get me off the phone, but hopefully we don't have to find out if its true!
    Inferno500 likes this.
  20. Oct 28, 2016 at 10:36 AM
    #1380
    breckfj
    breckfj Well-Known Member
    CO
    '16 MT
    I have just discovered this. I have a DCSB OR manual, assembled 2/16 w/ 10k miles.
