3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Nov 17, 2016 at 1:45 PM
    #1421
    trdgentaco
    trdgentaco Well-Known Member
    Atlanta, Ga
    2016 tacoma DC OR MT, 89 sassed 4runner
    I just got my truck back from the dealer. They told me that it is exhaust noise and they all do it. Im going to have a ride along tomorrow to make sure we are listening to the same noise.
  2. Nov 17, 2016 at 2:24 PM
    #1422
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Bahahaha, definitely not an exhaust noise.
    shakerhood likes this.
  3. Nov 17, 2016 at 6:15 PM
    #1423
    Fguiza27
    Fguiza27 Active Member
    Fredy
    03 Trd Offroad
    My only recommendation guys is.... wait until toyota came with a real solution. Why? Because after my truck got 3 rear differentials replaced still howling.
    1st howling
    2st leak
    3 howling then grinding
    And still howling 60mph
    A new diff will not fix the issue
    16 Trd sport manual transmission 9000 miles
  4. Nov 17, 2016 at 6:19 PM
    #1424
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    While it's very true that a new differential won't help, I would personally still like to see each and every person with a howling differential go in and get replacement differentials even if the new ones howl too. It'll bleed Toyota's pockets and force them to solve the problem faster.
    I'm a very patient person by nature but if we all sit around and patiently wait then they have no real motivation to act.
  5. Nov 17, 2016 at 6:23 PM
    #1425
    Fguiza27
    Fredy
    03 Trd Offroad
    My 2nd diff got replaced just because was leaking not because was howling. My 3rd diff was replaced just because was grinding at lower speed not because was howling... they said in 3 different dealers i went. "Normal characteristics of the truck"
  6. Nov 17, 2016 at 6:27 PM
    #1426
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Just like with trannys, the mechs wont tear down a diff anymore. It sucks that the second diff might have just need a $5 seal replaced, but setting preload can be difficult if you dont do it often, so I guess it makes sense that they would rather swap it out and get you down the road.
  7. Nov 17, 2016 at 6:30 PM
    #1427
    fdbyrne
    Missouri
    I understand and I've followed your other posts so I'm familiar with your situation. I know that it was a lot of time and leg work for you and that sucks but look at the numbers. What do you think Toyota Corporate's actually profit was from your original purchase? $5k? $10k? I honestly don't know.
    They have since spent much more than that dicking around with your differentials. In the end, they lost money on you. They would have been better off not building your truck at all.
    Losing money gives a strong incentive to solve the problem and since I have this problem on my second differential I'd appreciate it if many more people waste their time and Toyota's money chasing a solution that doesn't yet exist.
  8. Nov 18, 2016 at 8:05 AM
    #1428
    zac2944
    zac2944 Well-Known Member
    Rochester NY
    2016 TRD OR DCLB
    I just got back from an appointment with a Toyota field technician. Referred to himself as a "factory" technician, so I asked him which Toyota factory he's from. He chuckled. :)
    The Field Tech did acknowledge the issue and said that Toyota is aware of it and "is working on it". He said that they don't have a solution yet but they know this is an issue for many and although he doesn't know when he expects a TSB or solution in the future.
    As a shot from the hip he tried adding Ford Fluid XL-3 Friction Modifier Additive to the diff fluid. He agreed that it was a mechaninc-in-a-bottle band-aid solution, but that it may reduce the noise until a real fix is determined. It did nothing.
    His final recommendation was to try replacing my diff with a "champion" diff. I asked, "is champion a brand"? He said, "champion" means a diff that gets built by hand to tighter specs. Makes sense to me. We agreed that if Toyota doesn't come up with a fix or TSB by my 10k service we will schedule the diff replacement for that visit.
    Doesn't seem like there are any better solutions at the moment. I expect to need 10k service around April/May of 2017. Until then I can enjoy
    shakerhood and Taco16LB like this.
  9. Nov 18, 2016 at 8:28 AM
    #1429
    viking15
    viking15 Well-Known Member
    Joe
    Agreed
  10. Nov 18, 2016 at 12:29 PM
    #1430
    trdgentaco
    Atlanta, Ga
    Just got my truck back after ride along. The tech and service writer originally was listening to the wrong noise. But they said they can not tell where it is coming from and for that they would make note and wait for it to get worse
  11. Nov 28, 2016 at 12:14 PM
    #1431
    DontPanic
    DontPanic Well-Known Member
    VA
    Has anyone had the pinon bearing preload checked for this "off power" gear whine?
  12. Nov 28, 2016 at 12:15 PM
    #1432
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    That is a great question..!!..
  13. Nov 28, 2016 at 12:43 PM
    #1433
    Mace587
    Mace587 Well-Known Member
    North Carolina
    2016 DCSB TRD OR 4x4
    I'm not going to pay to have anyone do this and risk voiding the warranty, and I think most people with this issue feel the same way. While it's under warranty it's Toyota's problem, and per Corporate, it's "normal" for now.
    Now if Toyota decides they want to go this route then I'm all for it.
  14. Nov 28, 2016 at 12:47 PM
    #1434
    fdbyrne
    Missouri
    Eventually someone will pay to have it done, it'll fix the problem, and then they'll take Toyota to small claims court to recover their expenses since Toyota is refusing to fix the problem.
    shakerhood, Inferno500 and ZachMX like this.
  15. Nov 28, 2016 at 2:06 PM
    #1435
    fdbyrne
    Missouri
    I'm off the week after Christmas. Maybe I'll get bored and give it a shot. The sound is embarrassing and getting louder. I've been secretly hoping that someone that's retired does it first so there was precedent but I'm getting tired of the sound drowning out my radio.
    16tacoma1972 and bradwhitenikki like this.
  16. Nov 28, 2016 at 3:03 PM
    #1436
    bradwhitenikki
    Brad
    Many here look forward to your findings!
  17. Nov 28, 2016 at 5:02 PM
    #1437
    viking15
    Joe
    Well that is bad if it is drowning out your radio
  18. Nov 28, 2016 at 5:21 PM
    #1438
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    So has anyone sued Toyota and seen sweet gains?
  19. Nov 28, 2016 at 6:25 PM
    #1439
    fdbyrne
    Missouri
    I doubt anyone would gain, nor should they really aim to in my opinion. Recouping the cost of a 3rd party fix plus court costs would prove a point in the court of public opinion, make me whole, and maybe expedite a more widespread fix. I don't feel that they owe me more than that.
  20. Nov 28, 2016 at 8:50 PM
    #1440
    Z50king
    Eric
    Southern California
    Stock and loving it
    it was a joke about swole gains, bro
