3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jul 31, 2016 at 9:14 AM
    #141
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I hate to say it, but the dealer may not always offer you a solution for various reasons. I would still try what Aussiek2000 said for myself, all it can hurt is a little time of which has already been spent in the effort.
    Hope that helps
    Cheers!
    Aussiek2000 likes this.
  2. Jul 31, 2016 at 9:17 AM
    #142
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    It is 100% not tire related.
  3. Jul 31, 2016 at 9:31 AM
    #143
    The hammer
    That may be true in some cases of course, but it ought not to be dismissed for all possible scenarios when no other solution seems to be working.
    Hope that helps
    Cheers!
  4. Jul 31, 2016 at 9:40 AM
    #144
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    If it were tire related it would be speed sensitive, not throttle sensitive.
    It may be the fluid, who knows? I think 75w-90 or whatever they put in there for gas mileage these days is too thin for a truck differential but that's only my opinion of course.
  5. Jul 31, 2016 at 9:43 AM
    #145
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Has anyone checked their driveshaft slip joint for looseness?
    I know this is 3rd gen, but my '06 RC 4x4 has had a howl between 45-60 mph with neutral load on the drivetrain since I bought it 5 yrs ago. I finally diagnosed it as a slightly loose slip joint. It actually disappears with a heavy load in the bed. There have been a few other early 2nd gen RC owners who have experienced the same thing and "fixed" it by flipping the driveshaft (actually just moves the noise away from the cab).
    Just a suggestion, and it is free to check it yourself.
    smitty99[OP] likes this.
  6. Jul 31, 2016 at 10:18 AM
    #146
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Good thought! I'll have the dealer look into this.
    Blueboy likes this.
  7. Jul 31, 2016 at 10:34 AM
    #147
    smitty99
    Scottsdale
    Thinking about this some more. Dealer did put my truck on a lift and used a stethoscope to listen to the diff assembly and this is where they isolated the noise. So I'm thinking in that case it isn't likely a slip joint?
    Blueboy likes this.
  8. Jul 31, 2016 at 12:21 PM
    #148
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
  9. Jul 31, 2016 at 12:22 PM
    #149
    smitty99
    Scottsdale
    Blueboy likes this.
  10. Jul 31, 2016 at 12:37 PM
    #150
    The hammer
    But aren't all 4X4 stock trims the same angle, or is the TRDOR different, as not all appear to have the same issue?
  11. Jul 31, 2016 at 12:45 PM
    #151
    The hammer
    The other point I'm wondering is the locker. What with all that's going on back there, ATRAC, LSD, locker, I know that electronically it's supposed to cancel any conflict between them, but is it? I would hope the engineers can find a solution soon
    Hope that helps
    Cheers!
  12. Jul 31, 2016 at 1:05 PM
    #152
    The hammer
    My though is, that if the electronics are somehow failing on some, not all, like the trans was, it might be an area the engineers maybe working on, IDK, But I honestly hope it can be all sorted out soon.
    Hope that helps
    Cheers!
  13. Jul 31, 2016 at 1:18 PM
    #153
    Truggin
    Don
    Excellent question. And I think the answer is "no". The Off Roads have a different suspension, and this would likely shift the angle to some extent.
  14. Jul 31, 2016 at 1:24 PM
    #154
    smitty99
    Scottsdale
    But the problem is this issue is prevalent on all models not just the TRD OR. That's already been ruled out.
    Chris1261 likes this.
  15. Jul 31, 2016 at 1:34 PM
    #155
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    MY rear end doesn't howl at 65, (I'm driving)..but my son mooned a nice old couple on the freeway the other day...out the rear window at about 65MPH, and I'm sure I did hear the howl you are talking about..... It sort of sounded like "The Hammer"....:bananadance:
  16. Jul 31, 2016 at 3:58 PM
    #156
    The hammer
    Well if there' a difference in the angle it still doesn't explain why not all trdor are affected some ppl off road heavy with stock no issues.
    But I won't be a bit surprised if it turns out to be something small or mundane such as a bad run on crush washer or bearing or seat.
    But all replaced parts go back to Toyota for them to examine and if they find something it takes time to trace the part and find out which ones maybe affected.
    I would have gotten the trd if they would've had it in white l/b so i hope they get to the bottom soon.
    Cheers!
  17. Jul 31, 2016 at 4:42 PM
    #157
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    That is what I am kinda leaning toward. Something small that they just haven't 100% pinned down yet. I am sure that Toyota will take care of me! The only question is how long will it take?
    Inferno500 likes this.
  18. Jul 31, 2016 at 5:52 PM
    #158
    MasterPenguins
    Indiana
    Yeah, I am already on my second one. Hopefully the field engineer will be able to look at my second one in a little over a week. Thankfully no one at my dealership has told me "well that is normal" or "you're just gonna have to live with it." It has actually been the opposite! Things like "Thanks for being patient with us." And "We'll get this sorted out for you."
    Mace587, The hammer and smitty99[OP] like this.
  19. Jul 31, 2016 at 6:09 PM
    #159
    smitty99
    Scottsdale
    All eyes are on you my man. We are awaiting to hear the outcome. I'll be close behind you too with my 2nd repair order.
  20. Jul 31, 2016 at 6:21 PM
    #160
    jg16
    jg16 Well-Known Member
    Tennessee
    2016 White Off Road
    Been watching this thread for a while. My truck has this problem. TRD ORDC. Waiting till they find a fix before I take it in. Hope they find it soon. Really like the truck. The howling diff is the only problem it has. 1200 miles
    Mace587 likes this.
