3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Dec 16, 2016 at 12:02 PM
    #1601
    harryk
    harryk Well-Known Member
    Maryland, near Chesapeake Bay
    2016 Tacoma V6, MT, 4WD, Blue
    The problem is that Toyota has not identified the exact source of the whine in the diff, and why it makes that noise. It shouldn't. Bad design? Parts manufactured out of tolerance?
  2. Dec 16, 2016 at 12:06 PM
    #1602
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    It functions though. 2nd gens have pretty much the same axle. The 3.90g axles with the Locker have 8.75 inch axles. Only thing different I can think of? Someone call me out please, I may be wrong.
    Mush Mouse likes this.
  3. Dec 16, 2016 at 12:08 PM
    #1603
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    @smitty99 did you get your diff fixed/resolved? Haven't been on TW in awhile.
  4. Dec 16, 2016 at 12:21 PM
    #1604
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I have a manual with the 4.30 with the whine. I have no worries on reliability, but it isn't right for a brand new truck. The above observation (More complaints with the TRD OR) got me thinking....from reading other posts, the new 4.30 manual and the 3.90 in the TRD OR are supposedly the new 8.75" rear end. If that is true, it means that its an unproven rear end, and could indeed have a design flaw.
    I will be letting my dealer know about this at the 5K service, as I want the complaint in my service records and hopefully they report it to Toyota (more complaints = more likely to address). I'm not going to worry too much until they come up with a fix. My larger complaint is the cyclic vibration at 55-65 mph. I thought it might be the common front drivers side needle bearing at the differential, but engaging 4wd does not cure it totally.
  5. Dec 16, 2016 at 12:24 PM
    #1605
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    8.75- I stand corrected. It wont cure it, but my friend got the ECGS bushing and had it swapped out. Drives with no driver's vibration-zero!
    Dogg23 likes this.
  6. Dec 16, 2016 at 12:56 PM
    #1606
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    They probably don't care. This is complete speculation but if the differentials going back are being found to have no issues or excess wear then they aren't going to spend a bunch of money trying to make the differential quiet. This especially won't happen if the differential is a part that is contracted out (I could have sworn at one point I saw GKN as the contracted company).
    It takes a lot of money to R&D a new differential, especially if the sole purpose is to just make it quieter. More than likely they will spend their efforts elsewhere making the cab quieter as that will be seen as an improvement by people that don't have or hear this issue as well.
    We will see, but either way my new differential howls and hasn't gotten any louder or changed in any way since the day it was installed. Have about 5k miles on the new diff.
    Inferno500 likes this.
  7. Dec 16, 2016 at 3:37 PM
    #1607
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    This is exactly what they are doing.....sound abatement is in work, not fixing the whine.
  8. Dec 16, 2016 at 9:35 PM
    #1608
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    No still waiting for TSB
  9. Dec 20, 2016 at 10:26 AM
    #1609
    ((a.v.))mk-1
    ((a.v.))mk-1 Well-Known Member
    2017 SR5 MGM DCLB
    Went for the drive today, master tech heard the noise. They took the truck for the rest of the day to put the chassisEARS on it.
    Ill let the tech no I just wanted it documented, he was a nice guy. I will let you know what I find, I doubt it will be any thing that hasn't been discussed in 90 pages.
    In all honesty, as long as the dealership documents it - I really don't care. Just don't want Toyota coming back and telling me the shell, lift, tires i plan on adding caused the noise. I don't know if the vehicle industry uses dMFEA for design, but if they do I would assume the differential is a severity 3 or so issue. So all tests likely included a 95/95 interval- good enough for me.
    shakerhood and smitty99[OP] like this.
  10. Dec 20, 2016 at 12:30 PM
    #1610
    DontPanic
    DontPanic Well-Known Member
    VA
    I'm sure they have their version just like I'm sure they have sixsigma black belts that make every meeting longer than it needs to be.. but rear diff issue would not be an SII not SIII.. so it would be a (p)C(s)II(d)4... that is assuming it is a "fault" to begin with - your application of FMEA equates detectable sound with a failure. Sounds like Toyota engineering has taken apart symptomatic examples and subsequently kicked the issue over to the Noise/Vibration/Harshness NVH or equivalent team to address.
  11. Dec 20, 2016 at 1:09 PM
    #1611
    ((a.v.))mk-1
    2017 SR5 MGM DCLB
    They need to waste our time so they can save us some later. Job Security really.
    Makes sense, design failure mode likely poor tolerance stack or equivalent or process failure mode poor backlash setting. could even be S1 "User inconvenience" or however they word it.
    ... they seem to be doing an excellent job, I bet they are all black belts.
    shakerhood likes this.
  12. Dec 20, 2016 at 1:23 PM
    #1612
    ((a.v.))mk-1
    2017 SR5 MGM DCLB
    Just heard back, they could not track it to the diff. Suggested it was a tire noise. Oh well, its documented.
  13. Dec 20, 2016 at 1:32 PM
    #1613
    Taco16LB
    Taco16LB Well-Known Member
    Are they still using six sigma ? My gawd ,I thought that went out with Neutron Jack Welch from GE in 2001 .
    One piece flow and continuous improvement from Toyota were the rage in the US in what , 2003 till ?
    The classes on the latter two were fun !
    shakerhood and ((a.v.))mk-1 like this.
  14. Dec 20, 2016 at 1:36 PM
    #1614
    ((a.v.))mk-1
    2017 SR5 MGM DCLB
    ...Currently. Believe it or not people are still poke yokeing around with like chickens with their heads cut off.
    Sigh.
  15. Dec 20, 2016 at 3:21 PM
    #1615
    smitty99
    Scottsdale
    Did you put aftermarket tires on?
  16. Dec 20, 2016 at 3:34 PM
    #1616
    ((a.v.))mk-1
    2017 SR5 MGM DCLB
    No everything is bone stock. I asked to schedule an appointment for next week to pull the tires and balance them. He stated that this was not necessary as the problem would need to get worse before we can fix it.
    I had them correct the tech description saying noise is still present after listening.
    I guess I succeeded in getting it documented. ..
  17. Dec 20, 2016 at 6:24 PM
    #1617
    smitty99
    Scottsdale
    Good I'm glad you didn't do any aftermarket mods, because once you do this it will always be their first excuse.
    barney7 and jg16 like this.
  18. Dec 21, 2016 at 2:32 PM
    #1618
    smitty99
    Scottsdale
  19. Dec 21, 2016 at 5:42 PM
    #1619
    1stTacoGen3
    1stTacoGen3 New Member
    Hello All:
    My first post, my first Tacoma. 2016 MT Inferno Sport AC w/Tow Pkg bought 08/16. I'll get to the intro stuff later... Hi.
    I have 35+ years in the VW camp, mostly Diesels. I am well versed with pain. I still love them despite all the bloody knuckles.
    Thanks to this forum, I performed "maintenance" at 512 miles with full approval from "Service Manager". His blessing? "If you do in right, NO warranty issues". Easy vehicle to work on thus far.
    Engine: TGMO 0W/20 and filter - OEM
    F/R Diffs: Red Line 75W/85 GL-5 - New washers - OEM - Torqued to Spec via TIS
    MT/Xfer case: Redline MT-90 GL-4- New Washers - OEM - Torqued to Spec via TIS
    All Drive Shaft Zerks: Spicer Ultra Premium Synthetic Grease® - Grease needle is key on the front shaft points!
    Prior to all this damned BS "maintenance" on a NEW vehicle, I could hear the slight rear diff "howl" on slight deceleration at around 55-60. It is gone now.
    The RPM "hang" during shifting is gone as well. Damn, it actually behaves as a manual transmission should!
    The Zerks took several pumps (Lincoln 1134) to fill/purge the cross/voids of whatever lube was present. Looked like Moly paste... Especially the rears post transfer case. Fronts oozed "reddish".
    I took an albeit tardy "preemptive strike" to do what I can... Still SAD that I had to finish the process to hope to have a fine and long lasting vehicle.
    If I heard the "whine" heard on smitty99's vid, I'd be rather unhappy. That is CRAZY. Good Luck to smitty99.
    mict450 likes this.
  20. Dec 21, 2016 at 6:03 PM
    #1620
    BeaverNation
    BeaverNation Well-Known Member
    looks like someone has a case of tacomaworld paranoia. Want to send me all those new fluids you discarded?
