3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Dec 22, 2016 at 6:56 PM
    #1621
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Excellent Scornwel! I am glad to hear it.
  2. Dec 22, 2016 at 7:13 PM
    #1622
    bradwhitenikki
    Brad
  3. Jan 1, 2017 at 8:44 AM
    #1623
    O2VW18T
    O2VW18T Member
    Toyota Dealer Master tech with a 3rd gen 2017 build 12/16 TRD OR mine makes the noise it started around 150 miles maybe earlier but when i drove with no radio at 53mph to 66mph after 67mph i cant hear anything. Now id problem not give a damn but my whole commute to work is from 52-60mph its annoying as crap I might change the fluid and see what happens i really dont want to touch my new truck. We'll see I could make a case with toyota and see what they say.
    Taco16LB likes this.
  4. Jan 1, 2017 at 8:53 AM
    #1624
    ((a.v.))mk-1
    ((a.v.))mk-1 Well-Known Member
    2017 SR5 MGM DCLB
    I had to chuckle.. My coworker has the same truck as me. When I told him aboit the issue he responded with "So, I never drive 55".
    Goes to show it isnt annoying until it is. Let us know how the fluid change goes..
  5. Jan 1, 2017 at 9:05 AM
    #1625
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Agreed, that shit was horrible.
    Taco16LB[QUOTED] likes this.
  6. Jan 1, 2017 at 9:20 AM
    #1626
    O2VW18T
    O2VW18T Member
    Yeah if i drove slower or faster id honestly not even care, If its slow at work i'll check the fluid.
    WOTaco likes this.
  7. Jan 3, 2017 at 6:23 AM
    #1627
    bradwhitenikki
    Brad
    Just an FYI: anyone that is having a noisy diff issue should report it with Toyota Customer service: opening up a case. This will help put pressure on the supplier to fix the issue, and this could also push a hardware correction in the future that rectifies the issue. As it is now, it seems there is no issue; which we all know is not true.
    shakerhood and smitty99[OP] like this.
  8. Jan 3, 2017 at 6:25 AM
    #1628
    bradwhitenikki
    Brad
    It is nice to be back. I got banned a few times for slapping a queef around.
    Taco16LB and smitty99[OP] like this.
  9. Jan 3, 2017 at 6:25 AM
    #1629
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Just spit my coffee out
  10. Jan 3, 2017 at 6:29 AM
    #1630
    DontPanic
    DontPanic Well-Known Member
    VA
    You'll probably still only get noise abatement tops, at least those that follow will get a quieter gearset.
  11. Jan 3, 2017 at 6:30 AM
    #1631
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I snorted my coffee as well.. thanks! :D
  12. Jan 3, 2017 at 6:33 AM
    #1632
    MOC221_
    Frank
    Welp, on Thursday my rig is going in for round two... transmission replacement. With my luck, I'll end up with the shitty detent ball thingy and have to strong arm it outa sixth.
    Frank
  13. Jan 3, 2017 at 6:37 AM
    #1633
    smitty99
    Scottsdale
    What has been going wrong with the transmission (other than the usual shitty shifting)? EDIT: Nevermind I just read some of your previous posts about it. Looks like Toyota throwing parts at problems again with no RCA.
  14. Jan 3, 2017 at 6:40 AM
    #1634
    MOC221_
    Frank
    Nothing. The techs think that is where MY driveline noise is coming from. They've already replaced my T-case.
    Yup, no joke. Thankfully the new T-case has been flawless, and believe me I've been "testing" it frequently this winter!
    Oh, and I have the M/T.
    Frank
  15. Jan 3, 2017 at 7:29 AM
    #1635
    bradwhitenikki
    Brad
    Hi Frank, can you describe the drive line noise, at what speed, load, what provokes it, etc...?
  16. Jan 3, 2017 at 8:28 AM
    #1636
    MOC221_
    Frank
    Brad;
    Apologies for any confusion, it's the same whine under identical conditions to most others in this thread:
    90-100 km/h, only when feathering throttle. If you let off or take up on the gas just a small amount, the noise goes away. Right from the start of this process, the techs said my rear diff was quiet as a church. I know they had the truck on a hoist and were running it at the aforementioned speeds to diagnose. As Smitty stated earlier, they seem to be throwing parts/time at the problem without any idea of the root cause. I'm willing to play along for now, but I can't help but think corporate will put a stop to the waste sometime very soon. To the dealership's credit though, when I told them the noise was still present after the first repair, they didn't even blink - on with the next swap! :notsure:
    Frank
    smitty99[OP] likes this.
  17. Jan 3, 2017 at 8:58 AM
    #1637
    bradwhitenikki
    Brad
    Thanks for the great description. I am researching ring and pinion machining methods and crush sleeve "over-crushing" over time. I had a crush sleeve "over-crush" before; leading to a noisy ring and pinion... followed by a catastrophic failure. Crush washers are not that durable.
  18. Jan 3, 2017 at 9:02 AM
    #1638
    MOC221_
    Frank
    Forgive my ignorance, but would an "over crush" condition mean that the preload would go to shit, the pinion depth would be off, or both?
    Frank
  19. Jan 3, 2017 at 9:36 AM
    #1639
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    LOL.
    Add me the list.
  20. Jan 3, 2017 at 9:37 AM
    #1640
    bradwhitenikki
    Brad
    Definitely preload going to a loose state (which would affect gear mesh clearances and would likely howl) and potentially ending up with the pinion contacting the differential.
    MOC221_[QUOTED] likes this.
