3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 5, 2017 at 10:14 AM
    #1681
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    I think you're spot on. My last truck was an 05 Z-71 which had 4:10 gears. They made the exact same noise as the new Tacoma for 190K miles with no problems from the rear end at all, besides the sound. Loved that truck. Love this one too.
    Since Toyota doesn't have a current fix, I went ahead and addressed the rear end noise with 1000 watt 5-channel amp, new speakers, and a 10" sub. :)
  2. Jan 5, 2017 at 10:17 AM
    #1682
    hookembevo
    Austin, TX
    I'm going to use Audacity and see what the frequency of the 4.30:1 is.
  3. Jan 5, 2017 at 10:19 AM
    #1683
    chuck1986
    chuck1986 Two in the Taco one in the Prius
    Tulsa, OK
    2017 TRD-OR Blue
    in all sincerity, thank you for actually contributing to the issue. I applaud you my friend.
  4. Jan 5, 2017 at 10:20 AM
    #1684
    ((a.v.))mk-1
    ((a.v.))mk-1 Well-Known Member
    2017 SR5 MGM DCLB
    How was this calculated. Could always offset your phase and add the signals... See if it cancels.
    Might be a fun project to pipe in the noise @ around 55. Small speaker under the bench or something.
    Could really be onto something here...
  5. Jan 5, 2017 at 10:23 AM
    #1685
    chuck1986
    Tulsa, OK
    2017 TRD-OR Blue
    Toyota isnt very quick to recall or fix issues. It took many lawsuits and lots/years of legal red tape to get them to do something about the frames. Then it took people dying for them to fix the air bag and sticky throttle issues they had. People see that toyota doesnt recall many things or have as many TSB, and think that means they are "reliable" and Toyota stands behind their product. But really its just stubbornness from Toyota.
    GM has lots of recalls/TSBs, but they are proactive in fixing their mistakes. THAT is standing behind your product.
    shakerhood and ((a.v.))mk-1 like this.
  6. Jan 5, 2017 at 10:29 AM
    #1686
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I wasn't sure that's why I fought tooth and nail for corporate to give me the Platinum 8year/125k coverage once I was close to meeting lemon law criteria and had several issues requiring visits on top of the "major drivetrain component" replacement (carrier assembly)
  7. Jan 5, 2017 at 10:35 AM
    #1687
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    Can you share your analysis?
    smitty99[OP] likes this.
  8. Jan 5, 2017 at 10:38 AM
    #1688
    smitty99
    Scottsdale
    On the humidity or the audio profile? :laugh:
    Riding Dirty likes this.
  9. Jan 5, 2017 at 11:07 AM
    #1689
    scornwel
    Fort Worth
    None
    Ha....I'm from Florida so I've had my fair share of humidity.
    I'd like to see how Brad determined this though.
  10. Jan 5, 2017 at 12:28 PM
    #1690
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Hi Scornwell. Its rough, but here goes. First I want to determine my wheel's revolutions/second at 45 mph (the speed where the noise appears to be the loudest on my truck). [45 miles/hour] * [5280 feet/mile] * [12 inches/foot] = 2,851,200 inches/hour. Convert to inches per second: [2,851,200 inches/hour] * [1hour/3600 seconds] = 792 inches/second. My tire is 28 inches in diameter, so the circumference of the tire is 28 * pi = 88.96 (rounded to 2 sig figs). My rear wheel's revs/second = [792 inches/second] / [88.96] = 8.9 revs/second. I am unsure, but I believe the ring gear has 39 teeth, causing 39 gear tooth meshes per revolution. Thus gear tooth meshes/second = [8.9 revs/second] * [39] = 347 gear tooth meshes/second. If each gear tooth mesh event makes a similar sounding noise, then there are 347 of these noises per second. Thus the frequency of the howl is 347 Hz.
  11. Jan 5, 2017 at 1:36 PM
    #1691
    bradwhitenikki
    Brad
    Please see my response to Scornwell for the calculation. Cheers
  12. Jan 5, 2017 at 1:39 PM
    #1692
    bradwhitenikki
    Brad
    Hi. See my response to Scornwell for the calculation. As far as the phasing, I wonder if that will be one of big T's approaches... Why waste valuable resources fixing the problem?
  13. Jan 5, 2017 at 2:48 PM
    #1693
    ((a.v.))mk-1
    2017 SR5 MGM DCLB
  14. Jan 5, 2017 at 3:00 PM
    #1694
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
  15. Jan 6, 2017 at 4:43 PM
    #1695
    Dogg23
    Dogg23 I like big tires
    Nate
    Rochester, NY
    16 DC OR MT 10 Sport MT & 16 4R Trail
    Big tires
    dYL0n[QUOTED] likes this.
  16. Jan 6, 2017 at 5:06 PM
    #1696
    scornwel
    Fort Worth
    None
    Pretty straightforward Brad. I like it. I was guessing about 400Hz by ear, but was too busy to do the math. You Are the man!
  17. Jan 6, 2017 at 5:09 PM
    #1697
    smitty99
    Scottsdale
    Wow! 30lb cranium.
  18. Jan 6, 2017 at 5:59 PM
    #1698
    bradwhitenikki
    Brad
    Seems pretty darn close. Maybe 400Hz at about 51mph with stock tires. I would like to record the sound and compare it to the speeds as an exercise.
  19. Jan 6, 2017 at 7:07 PM
    #1699
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It's a 3.909 gear, so I'm thinking 43-11 toothcount.
    Correct me if I'm wrong; for a 3.909 gear, anything under 40 on the ring would compromise thickness at the root of the tooth.
  20. Jan 6, 2017 at 7:28 PM
    #1700
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
