3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 6, 2017 at 7:31 PM
    #1701
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    backtrack2015 likes this.
  2. Jan 6, 2017 at 7:36 PM
    #1702
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    400 Hz sounds like mine too.
  3. Jan 6, 2017 at 8:01 PM
    #1703
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
  4. Jan 6, 2017 at 8:01 PM
    #1704
    bradwhitenikki
    Brad
  5. Jan 6, 2017 at 8:03 PM
    #1705
    bradwhitenikki
    Brad
    I think we are getting somewhere. Next, someone needs to get a clean recording of the rear end noise.
  6. Jan 7, 2017 at 5:08 AM
    #1706
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    This is my first time coming back to this thread in a while and I'm just like:
    smitty99[OP] and Dogg23 like this.
  7. Jan 7, 2017 at 5:22 AM
    #1707
    DontPanic
    DontPanic Well-Known Member
    VA
    Incidence of Absolute Pitch is about 1 in 10000 in the general population... long odds that we have one with that gift among us. The frequency puts the note around a G4 or G4#. If someone knows someone with that gift it'd be settled right quick.
  8. Jan 7, 2017 at 6:01 AM
    #1708
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Neat little app
  9. Jan 10, 2017 at 6:45 PM
    #1709
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    The biomechanist in me says "bravo" sir
  10. Jan 11, 2017 at 5:38 PM
    #1710
    O2VW18T
    O2VW18T Member
    So put in new Redline Synthetic 75W85 Gear Oil and no change maybe a hair quieter but i doubt it. When i drained the stock fluid it looked great very fine metal on drain plug but its normal. I guess im just going to live with it or have the radio up a little bit more if i drive in the 50's.. So dont waste your money replacing the diff fluid.
    jg16 and smitty99[OP] like this.
  11. Jan 11, 2017 at 5:43 PM
    #1711
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I was hoping you were gonna say it made a big difference...
  12. Jan 11, 2017 at 5:45 PM
    #1712
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Thank you for trying for us.
    MasterPenguins and shakerhood like this.
  13. Jan 11, 2017 at 5:50 PM
    #1713
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I changed mine a few months ago and had no change either.
    shakerhood likes this.
  14. Jan 11, 2017 at 6:05 PM
    #1714
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Did a similar calculation. Mine is a 4.30 ratio and happens at 55 thru 65. I believe mine was the 2nd order of the gear mesh...which makes sense I suppose. I made the assumption that the 4.30 has 10 tooth pinion. I assume the 3.91 is an 11 tooth.
  15. Jan 11, 2017 at 6:11 PM
    #1715
    pjensen641
    Boone, IA
    Nah, this is engineering. Pure science results in no useful product....engineering is the practical application of said sience to some useful end :rofl:.
    smitty99[OP] likes this.
  16. Jan 11, 2017 at 6:13 PM
    #1716
    shakerhood
    Southern Ohio
    I was hoping the Manual Rears would not be having the same issue.
  17. Jan 11, 2017 at 6:20 PM
    #1717
    pjensen641
    Boone, IA
    Dunno If its a Problem or a slight annoyance. I am doing a ride along with a service tech Friday for a rumbling driveline vibration. I will demonstrate the diff noise and get it documented. At this point, Im not gonna push for any sort of component replacement or in depth work. The driveline vibration is my bigger gripe. only happens between 60 and 65 and when fairly cold. Im guessing they wont have a clue on how to fix it....but I will ask for the steering wheel vibration damper at least.
    shakerhood[QUOTED] likes this.
  18. Jan 11, 2017 at 6:43 PM
    #1718
    smitty99
    Scottsdale
    There's a tsb for the "driveline vibe when stopping" I'm sure you're aware.
  19. Jan 11, 2017 at 7:03 PM
    #1719
    bradwhitenikki
    Brad
    Curious... what frequency did you calculate, and what frequency are you hearing?
  20. Jan 11, 2017 at 7:21 PM
    #1720
    pjensen641
    Boone, IA
    Well...I forgot to write it down. Did the calcs when I was in my truck. I thought mine was about 850 hz, which is why I was thinking 2nd order of the gear mesh. To me, that makes sense because likley the tooth coming in to mesh and the tooth leaving could be happening at two different times....ie 2x the speed of the pinion.
    I need to do it again and see if I can measure the frequency. I use an app called frequensee which is a real time FFT
