3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Jan 11, 2017 at 7:23 PM
    #1721
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Cool. Thanks for the feedback
  2. Jan 12, 2017 at 4:43 PM
    #1722
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I measured mine with two different analyzers.
    One reported 431Hz and the other 430Hz.
    These were collected at 52-54mpg.
  3. Jan 12, 2017 at 7:03 PM
    #1723
    bradwhitenikki
    Brad
    Stock gears, stock tires right?
  4. Jan 18, 2017 at 7:57 AM
    #1724
    Failed_1
    Failed_1 Well-Known Member
    2017 TRD Off-Road 4x4
    Dropped my 17 OR with the dealer this morning for this. It also makes a popping noise from the rear at times when I stop. Doesn't seem like anything will be resolved after reading through this thread, but at least it will be documented. I want to put a lift and tires soon, don't want them saying the lift/tires are the cause of this, if anything does break.
  5. Jan 18, 2017 at 8:17 AM
    #1725
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Is it an Automatic or Stick?
  6. Jan 18, 2017 at 9:23 AM
    #1726
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    The service dept manager at my dealer told me to hold off on Tires and Lift until these suspension and differential issues are resolved and/or adjudicated officially. He said if I go adding stuff on the truck now it will likely force their hand to declining service for the issues. Automatic attribution to the aftermarket mods. I have a good relationship with him and so I have no reason to believe he would lie to me.
  7. Jan 18, 2017 at 9:33 AM
    #1727
    BeaverNation
    BeaverNation Well-Known Member
    If it's documented and you have a video of the sound, I would not be worried at all about lifting. Especially you smitty. All the times your truck has been in there for the howl, they won't tell you it didn't exist before the lift.. you're just worried the truck will be slower and shift even worse ;)
    smitty99[OP] likes this.
  8. Jan 18, 2017 at 9:40 AM
    #1728
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Thats hard to believe.
  9. Jan 18, 2017 at 9:59 AM
    #1729
    smitty99
    Scottsdale
    Well that's true as well.
  10. Jan 18, 2017 at 10:08 AM
    #1730
    Failed_1
    It's an automatic.
    That's what I was worried about. I just received a call back from the dealership, they said the howl was the tires and exhaust right at those 50-65 speeds. They also said I was the first person they know of that has reported this issue and they also drove another 17 to compare to mine, both made the "tire/exhaust" howl (I'm sure....). Rear diff fluid was fine and no issues with it. They did the update to the transmission at least. Could not duplicate the popping noise when braking.
    I really want to lift this thing, but with my luck and dealership I'm positive they will associate a lift and tires to the howl in the case it does break down the line.
  11. Jan 18, 2017 at 11:50 AM
    #1731
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Anyone with the howling changed tires and noted no difference? I'm seeing feathering in the stock tires at the front, outer blocks and hearing a very subtle howl coming from the front that's speed dependent and cannot be easily heard when you give it any gas. Feathering notoriously produces a howl.
    Quickly searching this thread, seen a few others note changing tires and not hearing the howl though it's unclear if that's because the new tires were louder than stock.
    Failed_1 likes this.
  12. Jan 18, 2017 at 12:07 PM
    #1732
    Mace587
    Mace587 Well-Known Member
    North Carolina
    2016 DCSB TRD OR 4x4
    I swapped to Falken Wildpeaks 265/75/16 and still have it. Noise is well documented with Toyota with stock tires so I'm not too worried about them turning me away if a solution is released. No lift for me though, yet!
  13. Jan 18, 2017 at 12:16 PM
    #1733
    Bassfever71
    Bassfever71 Well-Known Member
    New Jersey
    2019 Cement Tacoma TRD DCSport
    Come on it's definitely not tires,it would be doing it at all speeds then.Mine starts at 50-58 and that's it.I tried several times to do it at 47,48,49 and so forth and I can't get it to make noise.Only when I'm in between those speeds
    shakerhood likes this.
  14. Jan 18, 2017 at 12:27 PM
    #1734
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Not everyone may be experiencing the same symptoms but similar enough to lump it in, so there may be multiple causes.
    Wheel bearings may be a contributor as well and may be resonating with the differential enough to throw off the source of the noise.
  15. Jan 24, 2017 at 12:17 PM
    #1735
    fredtowne
    fredtowne Member
    2016 TRD Sport
    I have noticed recently that the noise in my truck is a bit intermittent and generally quieter than it was. Have no idea why. I have almost 11,000 miles on it. Have had nothing done to the stock truck except the plugs in lower control arms.
  16. Jan 24, 2017 at 12:19 PM
    #1736
    shakerhood
    Southern Ohio
    I am hoping the Manual Transmission Trucks do not suffer this same issue since they have 4:30 Gears.
  17. Jan 24, 2017 at 12:20 PM
    #1737
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I can tell you from experience that they do have the issue. Mine is loud as hell and I'm on differential number two.
    AdventureKid likes this.
  18. Jan 24, 2017 at 12:21 PM
    #1738
    shakerhood
    Southern Ohio
    Oh well, so much for that thought.
  19. Jan 24, 2017 at 12:23 PM
    #1739
    fredtowne
    fredtowne Member
    2016 TRD Sport
    Have you had the lower control arm plugs put in? That may be the noise from the front end There is a TSB on it.
  20. Jan 24, 2017 at 12:35 PM
    #1740
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Not yet, but it's different than the howl I heard with cross winds. It's a consistent speed noise that increases and decreases with speed. 99% sure it's the tire wear.
