3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Feb 13, 2017 at 7:13 AM
    #1781
    Taco16LB
    Taco16LB Well-Known Member
    Are talking about the chrome accessory tip that can be bought and installed ?
  2. Feb 13, 2017 at 7:20 AM
    #1782
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    No. The "tip" I'm referring to is the expanded end of the tailpipe.
  3. Feb 13, 2017 at 7:24 AM
    #1783
    Taco16LB
    Then this would indicate that the pipe is vibrating and added weight stabilizes it , rather than wind catching in the inside of the pipe and howling ?
  4. Feb 13, 2017 at 7:31 AM
    #1784
    splitbolt
    NW Arkansas
    That's what I think...since hitting the outside with a pressure washer made the sound.
    Wind is what's vibrating it; that's how I could get it to feather in and out.
    Taco16LB[QUOTED] likes this.
  5. Feb 13, 2017 at 7:32 AM
    #1785
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Was that the Factory Stainless Steel Tip or one you added on your own?
  6. Feb 13, 2017 at 7:36 AM
    #1786
    Taco16LB
    Good find !! I wonder if those that have cutoff the tailpipe end for offroading etc. still have a howling sound .
  7. Feb 13, 2017 at 8:01 AM
    #1787
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My diff howl can be isolated by putting the truck on a lift and using a stethoscope, it is definitely the rear differential. Had the Regional FTS fly out from Denver and confirmed the rear differentials are causing this issue. Sounds like your issue is different.
    AdventureKid, shakerhood and M80 taco like this.
  8. Feb 13, 2017 at 8:23 AM
    #1788
    M80 taco
    M80 taco Toyota tank
    NEW MEXICO
    2017 inferno or short bed
    None
    FTS is the only way I have been able to get my truck fixed. The FTS I interacted with was Roney, Great individual that is aware of these issues. Dealership acts different when this guy is town. However, every time I leave the dealership, I have a new problem. Last visit was Saturday, power steering is squealing like it's everybody's business. I brought it up right away, but said they can't help me to call FTS first with any of my problems. This dealership is making Toyota look bad. Did the FTS have any answers to the rear differential?
    shakerhood likes this.
  9. Feb 13, 2017 at 11:33 AM
    #1789
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    My new diff howls, from what I can tell, the same. Toyota says it is quieter than my last one but still acknowledges the noise (I can hear it with a CD on over volume set at 20). They analyzed sound clips they took of my truck is what I was told.
    The official word is that it is normal, not a safety concern, but to of course call them if something breaks.
    So for now I hit that 60 mph decline on the way home from work, lean back and let it woooooooo wooooooooooo
  10. Feb 13, 2017 at 1:16 PM
    #1790
    Honda2Toyota
    Honda2Toyota Your Local Long Bed Enthusiast
    Spotsylvania, Virginia
    2016 Tacoma DCLB TRDSport
    -Leer Camper Shell -Bilstein 5100 in the front and Bilstein 5100 in the rear with Icon AAL -TRDPro Front Grille -FJ Cruiser Steel Wheels with BFG AT KO2 Tires -MESOCustoms PTS Button -Prinsu Roof Rack with 40" LED Bar -ARB Awning -ARB Summit Front Bumper -ProComp front Spotlights and Cree Dual Beam combo bar -ARB skid plates -OVTune Trans Reflash
    My truck was bone-stock and started the howling noise at about 10k, and got worse up until I took it in at around 15k. It was most noticeable when letting off the throttle at under 60 mph, and coasting down to 55. I took it to the dealer; unfortunately the only solution was to replace the whole rear. About 3500-4000 miles into the new rear now; no noise to report yet.
    Amazing.
    NOTE: The dealer's way of diagnosing this issue is what honestly scared me the most; they dropped the driveshaft and drove the truck with it in 4WD, with the front tires doing the work(like a FWD car). With the pinion unloaded, she screamed her ass off.
    EB Group, M80 taco and shakerhood like this.
  11. Feb 13, 2017 at 1:31 PM
    #1791
    M80 taco
    NEW MEXICO
    None
    This is unexpected for 2017 model. Since they replaced my transfer case the rear differential howl has got worse. I noticed it more when they removed the drive shaft. FTS said it was normal, but I compared it with the 2017 model they lent me that had 20 miles on it. And that's not normal. IDK what happen at Toyota but they f$$ked this Tacoma up.
  12. Feb 18, 2017 at 1:42 PM
    #1792
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    I have confirm with my RTA that it is between 400-500HZ.
  13. Feb 21, 2017 at 9:16 AM
    #1793
    stevenwhite1989
    stevenwhite1989 Well-Known Member
    Update: got a call from the dealer today, apparently there's a TSB now. They're ordering the parts, I will have it done some time next week. Apparently it's some sort of damper for the transmission. I will update with more info when I get it.
  14. Feb 21, 2017 at 9:17 AM
    #1794
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    When you have tsb number please post
  15. Feb 21, 2017 at 9:18 AM
    #1795
    shakerhood
    Southern Ohio
    That is great news if it cures the howling rear!
    EB Group, jg16 and Taco16LB like this.
  16. Feb 21, 2017 at 11:02 AM
    #1796
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    What the....
    Ok, I hope there's a version of this fix for ALL drivetrain configurations.
    If you wouldn't mind, please post a pic of your service invoice with the details..
    Frank
  17. Feb 21, 2017 at 11:05 AM
    #1797
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I agree. I'd bet money that if the fix is transmission related then they will only fix the automatics and leave us with the manuals hanging and pissed.
    AdventureKid, shakerhood and EB Group like this.
  18. Feb 21, 2017 at 11:15 AM
    #1798
    stevenwhite1989
    I'm manual transmission.
    TSB-0186-17 per the dealer.
    shakerhood, EB Group and BeaverNation like this.
  19. Feb 21, 2017 at 11:20 AM
    #1799
    BeaverNation
    BeaverNation Well-Known Member
    Hahaha what if they can eliminate the howl in manuals but not autos
  20. Feb 21, 2017 at 11:20 AM
    #1800
    PROseur
    Pussy
    Auto drivers howling ?
