3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Mar 21, 2017 at 4:34 AM
    #1901
    stevenwhite1989
    stevenwhite1989 Well-Known Member
    Mine does it in 5th as well
  2. Mar 21, 2017 at 4:45 AM
    #1902
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    To be clear that TSB specifically addresses a howl caused by the transmission heat shield. Not the rear diff.
    OA
  3. Mar 21, 2017 at 4:50 AM
    #1903
    stevenwhite1989
    I was told that the harmonic was coming through the rear diff up the drive line and into the cab through the transmissions heat shield. I knew this wouldnt work but had it performed anyways. Sound will follow the path of least resistance into the cab.
    I agree with you that this doesnt address the actual harmonic coming from the diff, but it is a TSB that addresses the howl coming from the diff.
    shakerhood likes this.
  4. Mar 21, 2017 at 4:56 AM
    #1904
    Omar RVA
    Omar
    OR
    I see what you're saying, but again the bulletin doesn't say anything about the diff itself. Also, this condition affects more than just MT trucks; Toyota is addressing it just for us? It's possible your dealer is being legit and Toyota won't put the reasoning in writing as well.
    Here's a photo of the first page FWIW. The rest is just instructions. BTW I do NOT work for Toyota just have a 2 day TIS subscription that I'm trying to get the most out of lol.
    OA
  5. Mar 21, 2017 at 5:07 AM
    #1905
    stevenwhite1989
    I wish I knew more, and I could answer who the good guy is here. Everybody knows that the sound is coming from the diff at the dealer, and there's this awkward "we cant do anything until Toyota says so" attitude. Couple that with Toyota Corporate's "nothing else we can do" attitude, it leaves us stranded. I have been talking with lawyers, and may have a fairly strong case for Lemon.
    Also my understanding is that "only manual transmissions have the howl" -Dealership
    Omar RVA[QUOTED] likes this.
  6. Mar 21, 2017 at 5:10 AM
    #1906
    Omar RVA
    Omar
    OR
    Best of luck with all of that. It's not a fun road to go down. It's definitely irritating but I could live with the howl if it means no early wear or lack of reliability. But typically these sounds mean parts are doing something they shouldn't
    OA
  7. Mar 21, 2017 at 5:15 AM
    #1907
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    The harmonic noise coming from the transmission heat shield is a different noise than the one coming from the differential. I have both noises and they are distinctly different although they do happen in roughly the same speed range.
    The heat shield noise has a higher pitch and seems to come from everywhere. The differential noise has a lower pitch and clearly comes from the rear.
    I'll have to get the heat shield TSB done soon, but I just haven't had time.
  8. Mar 21, 2017 at 5:23 AM
    #1908
    stevenwhite1989
    Thats the thing, this didnt start until about the 1000 mile mark for me, and I know for certain I wouldnt have bought this truck had I heard the sound. Its a very irritating sound. I said it before, $40K is entirely too much money to pay for something that isnt perfect.
  9. Mar 21, 2017 at 5:24 AM
    #1909
    stevenwhite1989
    Mine is little less high pitched for sure now, but the diff still drowns out the radio. Good luck with yours.
  10. Mar 21, 2017 at 6:37 AM
    #1910
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Mine does it in 4th, 5th or 6th gear. Prob any gear but I haven't hit 55 in 1st, 2nd or 3rd.
  11. Mar 21, 2017 at 9:12 AM
    #1911
    WOTaco
    After which, you will be part of the "It's normal" club.:mad:
    shakerhood and NL130[QUOTED] like this.
  12. Mar 21, 2017 at 10:30 AM
    #1912
    TRDinOhio
    TRDinOhio Well-Known Member
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    glad atleast something is being done. Many people have reported no change even with a new diff installed. plz keep us posted
    shakerhood and NL130 like this.
  13. Mar 21, 2017 at 10:33 AM
    #1913
    CLT_Rick
    CLT_Rick Well-Known Member
    Nevada
    2021 TRDOR / 2016 TRDOR
    Auto or Manual?
  14. Mar 21, 2017 at 11:00 PM
    #1914
    podonne2
    podonne2 Member
    2016 blazing blue TRD OR DCSB
    Won't make a difference. had my diff replaced and no change in howling/whining at 55. For your sake, I hope I'm wrong
    EB Group and shakerhood like this.
  15. Mar 22, 2017 at 4:02 AM
    #1915
    DontPanic
    DontPanic Well-Known Member
    VA
    Unless there has been a running change in the diffs...
    MOC221_ likes this.
  16. Mar 22, 2017 at 11:47 AM
    #1916
    Honda2Toyota
    Honda2Toyota Your Local Long Bed Enthusiast
    Spotsylvania, Virginia
    2016 Tacoma DCLB TRDSport
    -Leer Camper Shell -Bilstein 5100 in the front and Bilstein 5100 in the rear with Icon AAL -TRDPro Front Grille -FJ Cruiser Steel Wheels with BFG AT KO2 Tires -MESOCustoms PTS Button -Prinsu Roof Rack with 40" LED Bar -ARB Awning -ARB Summit Front Bumper -ProComp front Spotlights and Cree Dual Beam combo bar -ARB skid plates -OVTune Trans Reflash
    I was at a similar mileage when mine was replaced. Hopefully, you will have an updated part installed....however, I'm fearful you will have the same results I did. Mine was replaced, and about 5k later I was back in with the same issue.
    It is at THAT point, sir, that you become a part of the 'it's normal' club.....having the diff replaced once will likely, at some point, become a right of passage. lol
  17. Mar 22, 2017 at 5:36 PM
    #1917
    89hatcher
    89hatcher Well-Known Member
    anyone got a video of the howl noise?
  18. Mar 22, 2017 at 10:13 PM
    #1918
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  19. Mar 23, 2017 at 12:29 AM
    #1919
    podonne2
    podonne2 Member
    Audio quality stinks, but listen closely at 4-5 seconds and 13 seconds and you'll hear the "coke bottle" howl.
    EB Group and nDub like this.
  20. Mar 23, 2017 at 2:30 PM
    #1920
    89hatcher
    looks like mostly the Off road Tacoma has the rear diff howl?
    16tacoma1972 and Storman like this.
