3rd gen Pro comp series 69 wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Puinsai, Apr 3, 2018.
  1. Sep 13, 2022 at 1:21 PM
    #61
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    just a heads up these are lug centric vs hub centric.
  2. Sep 13, 2022 at 1:49 PM
    #62
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    I have hub-centric wheel spacers, but own 7069 Pro Comp wheels - which you state are lug centric above. This isn't an issue right? Appears most aftermarket wheels are lug-centric:
    https://www.discounttire.com/learn/hub-centric-vs-lug-centric
  3. Sep 13, 2022 at 3:56 PM
    #63
    Josh-L
    Josh-L Well-Known Member
    2021 Silver SR DCSB V6 4x4
    I don’t know what that means. But from this thread looks like people are running them?
  4. Sep 13, 2022 at 5:35 PM
    #64
    auskip07
    Skip
    Atlanta, Ga
    i purchased hub centric because i wanted a smoother ride. i couldnt get a good balance with my 7069 hopefully you all have better luck than i did.
  5. Mar 31, 2023 at 7:55 PM
    #65
    nglescobar1992
    nglescobar1992 Well-Known Member
    boogers
    2019 tacoma
    oem
    Which tpms are running, the alloy or steel
  6. Jul 20, 2023 at 9:57 AM
    #66
    deav
    deav Active Member
    2018 DCSB OR Manual
    Adding to this thread to report that the 16x8 wheels with -12 offset fit for my 2018 OR. Calipers are close but they fit without any spacers or modifications. I have no lift and 265/75/16 KO2s. Used my stock TPMS and black Gorilla lugs.
    Guy at 4wheelparts said they wouldn’t work but they’re fine.
  7. Aug 2, 2023 at 1:20 PM
    #67
    deav
    deav Active Member
    2018 DCSB OR Manual
    Well, they still fit but I’ve experienced some rub and contact when braking while turning and going over bumpy curb cuts/driveways. Has anyone else experienced this because of this -12 offset? If so, any experience with a small lift helping or remedying it?
