3rd Gen Problems Poll
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBuffet, Mar 11, 2024.
Have you experienced any of these "common" 3rd gen issues
  1. Rear differential Issue(s)
    7.2%
  2. CPS failure
    0.9%
  3. Low transmission fluid / transmission issue
    8.8%
  4. 3rd Brake Light leak
    9.4%
  5. Coolant Bypass issue
    3.1%
  6. Timing cover leak
    6.0%
  7. Other issue impacting driveability
    5.3%
  8. No issues or none of the above
    66.8%
  9. Cylinder head / valve issue
    1.6%
  10. ACIS flap failure
    0.3%
  11. Rear main seal leak
    1.3%
  12. AC issues
    0.9%
  13. Paint Issues (SW, Blazing Blue, etc.)
    4.7%
  14. Clutch issues
    1.3%
  15. Wind Noise
    1.6%
  16. Driveline Vibrations
    2.5%
Multiple votes are allowed.
  1. Mar 11, 2024 at 10:31 AM
    TacoBuffet
    TacoBuffet [OP] Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Since we have people claiming mass issues that plagued the 3rd gen and is being deemed "the worst generation" figured some objective data may help dismiss or support those claims.
    I can add more issues too to the list, just did the ones off the top of my head.
    kahanabob, 4x4spiegel, 6MTPro and 2 others like this.
  2. Mar 11, 2024 at 10:54 AM
    Big Cole
    Big Cole Well-Known Member
    How about an option for none of the above
    tarbal255, Blockhead, 6MTPro and 10 others like this.
  3. Mar 11, 2024 at 10:59 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Yes, this -^^
    Junkhead likes this.
  4. Mar 11, 2024 at 11:01 AM
    CT Yankee
    CT
    Subjective?
    or Objective?
    Might want to check your Webster's.
    Blak Shinobi and BabyBilly like this.
  5. Mar 11, 2024 at 11:03 AM
    TacoBuffet
    AL
    Fixed, wasn't really doing my college best when typing out a poll. But you are correct.
    Soft Taco and Junkhead like this.
  6. Mar 11, 2024 at 11:06 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Might add the P11EX cylinder head/valve issue and the ACIS flap failure to the list of options.
  7. Mar 11, 2024 at 11:07 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    People who choose to take the survey, and those on TW to begin with, are in some way self-selecting. This in itself may skew the 'objective' data you're attempting to gather. Truly objective data you're looking for would come from a large, random survey of 3rd gen owners evenly distributed across model years and accounting for mileage.
    That said, 2020 with zero problems.
  8. Mar 11, 2024 at 11:08 AM
    Bishop84
    Bishop84 Well-Known Member
    You forgot the biggest one, cylinder head imbalance.
    We had a timing cover leak this morning, was a 2017 so aged a bit.
  9. Mar 11, 2024 at 11:08 AM
    TacoBuffet
    AL
    Agreed, but limited here at least this gives some reference for those interested or the people who like to spout nonsense about other gens overall reliability / issues.
    Junkhead and BabyBilly[QUOTED] like this.
  10. Mar 11, 2024 at 11:11 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    I checked off Rear Diff Issue... as in low fluid level.... by like a full quart. Assume this can fall in that line, or do you want to do another?
    Thx
    Junkhead and TacoBuffet[OP] like this.
  11. Mar 11, 2024 at 11:59 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Throw rear main seal leak into the list
  12. Mar 11, 2024 at 12:29 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    you forgot to add 5k oil or 10k oil change:deadhorse:
    mwb, ace_10, andthen and 6 others like this.
  13. Mar 11, 2024 at 12:30 PM
    Blak Shinobi
    taco
    n/a
    same zero problems just make sounds like tik tik and vroom vroom
  14. Mar 11, 2024 at 12:36 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Before I came to TW, I had none of these. After I came to TW, I think I have all of these, but refuse to actually check; therefore, I have none of these.
    In all seriousness, I have a leaky 3rd brake light. I got the recall a year or two after I globbed clear silicone all around it, and the dealer wouldn't touch it with a camper shell so I never got it "fixed." I also got a recall for fuel pump, but have no symptoms and have heard horror stories of those who had it "fixed", so not planning to touch that either. I have all the symptoms of low trans fluid, but it was never changed in the first 127k miles, so probably not gonna start now.
    Captqc, JoshC, Junkhead and 5 others like this.
  15. Mar 11, 2024 at 2:29 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    No issues with the 2018, 2020 or 2023 Sport, but the first month of production 2016 was a nightmare of multiple issues that resulted in a buyback.
  16. Mar 11, 2024 at 3:49 PM
    Load_Elevation_Fail
    Load_Elevation_Fail Active Member
    Rob
    Oklahoma
    2021 Tacoma TRD OR
    5.29 Gears 3” RC Vetrex Coilovers RC Speedo Calibrator Borla Exhaust OTT Tune 33” KO2s TRD Rims K&N 1.5” Spacers Clazzios Ultra White Interior LEDs Garmin Mini 2 Wide Cup Holders Cali Raised Blue Tint Wide View Mirrors Cat Shields Tailgate Lock Bed Mat Lexus Front Diff Drain Plug RAV4 Stereo Knobs Toyota Metal Oil Filter Housing
    Feel like this is going to jinx it for me. No issues other than being painted white.
  17. Mar 11, 2024 at 11:14 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Add AC problems please. That cost me $2k alone.
  18. Mar 12, 2024 at 4:38 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I’ve had zero issues.
    I did select low transmission fluid level. As I checked it early on and found it to be 1/2 quart low
  19. Mar 12, 2024 at 4:19 PM
    TacoBuffet
    AL
    Updated
  20. Mar 12, 2024 at 4:34 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I've heard people complaining about their passenger seats being defiled by Applebee's wait staff.
    ace_10, Phlogiston, Junkhead and 4 others like this.
