3rd Gen Problems Poll
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBuffet, Mar 11, 2024.
Have you experienced any of these "common" 3rd gen issues
  1. Rear differential Issue(s)
    7.2%
  2. CPS failure
    0.9%
  3. Low transmission fluid / transmission issue
    8.8%
  4. 3rd Brake Light leak
    9.4%
  5. Coolant Bypass issue
    3.1%
  6. Timing cover leak
    6.0%
  7. Other issue impacting driveability
    5.3%
  8. No issues or none of the above
    66.8%
  9. Cylinder head / valve issue
    1.6%
  10. ACIS flap failure
    0.3%
  11. Rear main seal leak
    1.3%
  12. AC issues
    0.9%
  13. Paint Issues (SW, Blazing Blue, etc.)
    4.7%
  14. Clutch issues
    1.3%
  15. Wind Noise
    1.6%
  16. Driveline Vibrations
    2.5%
Multiple votes are allowed.
  1. Mar 13, 2024 at 5:20 AM
    #41
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    S5 club for life!
  2. Mar 13, 2024 at 5:28 AM
    #42
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Bought the '23 Toyota TRD-OR in May of 2023. That's the end of a seven year old platform. I haven't had any of the issues above but I am on my third recall now. This last one says something about your drive axle may break in two and they don't have a fix for it. How is this just now coming to light on a 7 year old platform? How do they not have a fix for that?
    One of the Primo Reasons to get the last years of a platform is because all of the bugs and kinks have been worked out.
    Phlogiston and Lt. Dangle like this.
  3. Mar 13, 2024 at 5:35 AM
    #43
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    2022 sport super white. No actual problems, just some QC/QA issues like the orange peel door paint (at bottom) not lining up between front and back doors.
  4. Mar 13, 2024 at 7:03 AM
    #44
    Lt. Dangle
    Ohio
    I'm convinced it is just luck of the draw on which model you selected. My '17 bought in '16 has not had a single recall. It has had 2 "service campaigns" (blower wheel might crack and rear brake light might leak, my truck had neither issue, but got fixed anyways) and some warranty work done (3 TSB things?), but no recalls.
    Hopefully it's smooth sailing for you going forward.
    jayuu and Topanga Taco like this.
  5. Mar 13, 2024 at 7:35 AM
    #45
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    It’s because of many reasons. Machines becoming out of tolerance, laziness from the workers not checking things. It might be where they have to inspect and remove the MFG debris or reject them but that “check box” is getting skipped over. If Toyota cares so much about “kaizen” then they should invest in making it better instead of redesigning with issues like ford.
  6. Mar 13, 2024 at 8:57 AM
    #46
    ironhead181
    ironhead181 Well-Known Member
    2021 Tacoma DBL Cab
    none
    2021 with the creaky clutch. It also has the timing cover leak and is in the shop being fixed.
  7. Mar 13, 2024 at 9:10 AM
    #47
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    My biggest issue is not enough places to go off-roading in Northern NJ... other than that, fill the tank, change the oil every 5k, and drive! So far she's the most low maintenance vehicle I've had. My Ranger was a fix it every other week vehicle but that was 20 years old so to be expected.
  8. Mar 13, 2024 at 9:19 AM
    #48
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    I checked both Rear differential and 3d brake light leak, both were covered under recalls, differential was leaking but not the 3d brake light, had it fixed anyway!! My 2016 has been awesome!!!
  9. Mar 13, 2024 at 9:19 AM
    #49
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Wow!! Hoping to get that many miles out of my ‘18. Well about to give it to my son, so hoping he gets that many miles out of it and more.
  10. Mar 13, 2024 at 9:23 AM
    #50
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    right now vibration issues fit into other.
    the discussions are significant enough to warrant their own categories.
    "deceleration vibration 30-10mph"
    "other vibration issues when driving"
    clearly non-scientific but a good way to see what people (not sheeple) find wrong with this truck.
    could easily aid a potential buyer doing due diligence, rather than fishing thru zillions of posts.
    i will wait for vibration categories before adding my vote. late categories already screwing up results.
    edit: another significant issues is "loose spark plugs from factory" though i bet most that have it don't know it yet.
  11. Mar 13, 2024 at 9:25 AM
    #51
    TacomaAddict23
    TacomaAddict23 There's no cure for dumb
    2023 Lunar Rock DCSB
    Ditch Lights 4wp Sliders Bed side molle panels Taco garage DMM mount More to come
    I love my third gen, but one thing that drives me nuts is the headunit can be kind of laggy. If I plug my phone in right after I start the truck it will pair to carplay ok but it wont play music. I wish it was a little more responsive upon starting the truck up
  12. Mar 13, 2024 at 10:07 AM
    #52
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
  13. Mar 13, 2024 at 10:14 AM
    #53
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I had that too, along with TSS sensor and fuel pump recall. Had nothing fail in my truck so far though.
  14. Mar 13, 2024 at 10:53 AM
    #54
    jspirate
    jspirate Well-Known Member
    Virginia
    2023 Barcalona Red SR5 - Suicide Doors
    Same problem with my 2nd gen. Keep saying I am going to do the mod covered here at TW, but I never do.
    oconnor likes this.
  15. Mar 13, 2024 at 2:11 PM
    #55
    protocol7
    protocol7 Active Member
    stinky
    I think it is just that the welders got a little crazy and purportedly some welding debris could cause some of the retaining nuts to loosen, and *that* is when your axle could go kaboom.
    I've not found anecdotally anyone who has reported any issues out of this recall yet (i.e., nut torque out of spec, or worse, axle actually broke) and Toyota doesn't say 'do not drive' so I'm not really worried about it.
    Personally I'm only at 1.3k miles on my 3rd gen so by the time I'm gonna be at my 5k oil change I may as well take it to the dealership and they should have the "remedy" available by then.
  16. Mar 13, 2024 at 2:56 PM
    #56
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Trucks been flawless besides feeling like I get rear ended at every stop from the downshift clunk, and bogging/wont downshift out of turns. Really wish Toyota would have at least tried to help. Half a dozen visits to the dealer didn't do it…
  17. Mar 13, 2024 at 3:28 PM
    #57
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    then there are the 10's of thousands of people that do not know about this forum. be nice to pol them'.
    i have asked the parts dept about the number of repairs done to the coolant baypass 'not that many" then about the timing chain issue "too many to count"
  18. Mar 13, 2024 at 6:36 PM
    #58
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    half a dozen , if i worked there i would of told you to get a tune
  19. Mar 13, 2024 at 7:11 PM
    #59
    nds0000
    nds0000 Well-Known Member
    You may add wind whistle from driver side mirror at speed and vibration deceleration from 50+mph. Folks did complain about that on the 2023 Taco.
  20. Mar 13, 2024 at 7:23 PM
    #60
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    You can add the categories:
    -Goes too fast
    - Too powerful
    Junkhead and turbosnail like this.
