3rd Gen - Quad LED Projector Retrofit
Discussion in 'Lighting' started by MESO, Jul 6, 2017.
  1. Jul 6, 2017 at 11:47 AM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Here is another Headlight project I am working on. It's a little over the top, but whatever.
    It will have the following features;
    -4ea Bi-Led Projectors(2 per headlight) Since they are both high+low beam, there will be 4 low beam and 4 high beams
    -Custom Side marker
    -Swap White LED DRL's for AMBER (using factory Board/optics)
    -Quad Angry Halos
    -Black out all chrome
    -Custom molded Amber tinted turn signal lens
    -Some more stuff I'm probably forgetting
    Updated Pic:
    The Start:
    The projectors:
    First thing was to test the output/cutoff. Not bad for 1. Wait until there are 4:)
    next was take apart the OEM DRL board. De-solder the white LED's
    And replace them with AMBER LEDs(left) VS OEM (right)
    Props to Paul @diodedynamics for the chips!
    BRIGHT!
    Next, the projectors were disassembled to paint the inside black. This will give a passive blacked out look when the projectors are off.
    Before:
    After:
    Here is a size comparison to the OEM projector
    Side reflector:
    I milled out some Amber acrylic which will be backlit for parking lights
    Tinted
    Turn signal bucket:
    I wanted to keep the performance of the chrome reflector bucket..but I hate chrome.
    So I blacked out the sides, and created an Amber acrylic that kind of hides the chrome, but still lets all the light though;
    VS stock
    NEXT UP: MOUNTING
    I attempted to cut up the OEM projector mounting bracket... that did not work to say the least. So I took matters into my own hands and designed drop in brackets to hold bolt projectors;
    Pefect fit! Snaps right into the Factory alignment cups, and will be able to level/adjust them just like factory
    I wanted the 2nd Projector to sit as far back as possible so it doesn't look out of place
    Mock Up:
    Next up will be the angry Halos, they will be partially blacked out giving this look:
    That's it for now!
    Stay tuned for more updates:)
  2. Jul 6, 2017 at 11:47 AM
    MESO
    State of Jefferson
    Finished up both side projector mounts. Now I just need to pop them in the buckets and do some final tweaking. I aligned them on the bench.. and I gotta say getting 4 cutoffs to line up perfect is kinda tricky.
    All nylon lock nuts..this thing isn't moving
    This is alot of light....
    My JDM goodies arrived; Amber tint spray and Phillips Ultinons(not available in US) They give the Trittons a run for their money.
    Lightly smoked(top) VS Amber tinted(bottom). Which do you guys think?
    After testing both...the smoke cuts down the light a tiny bit, where as the amber lets 100% through..
    Both done. I like the amber look, and don't loose any performance.
    Test fit, ready for alignment(dark)
    MAD MAX YO
    OMG SO BRIGHT:bananadead:
    Perfect!!!(that's 4 Cutoff lines BTW:D)
    ERG80, RANGER13, Caboose117 and 13 others like this.
  3. Jul 6, 2017 at 11:49 AM
    MESO
    State of Jefferson
    Did up a fresh pair of Turn signal housings and amber lens's today.
    You can notice the right side had to be trimmed a little for the Halo clearance. But it's not seen anyway..so all good.
    I'm pretty stoked about how these turned out. Having a passive Amber Lens will allow for a darker "blacked out look", but maintain all the benefits with a chrome reflector bucket. Form and Function:thumbsup:..well a balance at least.
    Heated up, formed, and trimmed.
    Heads of the Ultinon's were painted black to darken up the bucket a little. Performance is unaffected because the emitters face down anyway.
    It's the little details...
    Front View. You see orange instead of chrome. Which is.. better I guess
    Obviously, Toyota's bowl design isn't the best for light spread..but it's what I got to work with. I may tap the Amber outside DRL bar to use as a secondary turn signal...
    Speaking of,
    Here's a quick super unscientific test of my LED swapped + tinted lens.
    Not horrible. I tested the OEM white and it was around ~450 at the hot spot.
    Now the Ugly....
    In order for the 2nd projector to sit back where I wanted it, the rear of the housing has to be modified. No way around it..
    3D printed rear covers
    Lookin' good
  4. Jul 6, 2017 at 11:49 AM
    MESO
    State of Jefferson
    I am calling them DRAGON EYES.
    All Sealed up and tested. WOW these are dark (but still bright)
    Installed pics:
  5. Jul 6, 2017 at 11:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh shit, subbed
  6. Jul 6, 2017 at 12:18 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Damn thats fresh!
    Lucifer1 and ChadsPride like this.
  7. Jul 6, 2017 at 12:21 PM
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    helloooooooooooo
    ChadsPride likes this.
  8. Jul 6, 2017 at 1:06 PM
    MagneticTaco4x4
    MagneticTaco4x4 Well-Known Member
    2017 Tacoma
    WHHHYY!!!!!???!? WHY MUST YOU TEASE US AND NOT SELL TO US??!??? I would gladly buy these for my MGM. #1st to ask.
  9. Jul 6, 2017 at 1:50 PM
    MESO
    State of Jefferson
    It's me
    Most people would think I'm crazy spending over $1000 just in parts for headlights.
    Caboose117, Fortunt1, ScottyR and 3 others like this.
  10. Jul 6, 2017 at 4:00 PM
    WhiteBeltBatman
    WhiteBeltBatman Well-Known Member
    Bay Area, CA
    2017 Super White TRD Pro
    I can't wait to see this!!
    ChadsPride and MESO[OP] like this.
  11. Jul 6, 2017 at 4:03 PM
    Porter707
    Porter707 Well-Known Member
    James
    Ohio
    2020 F-250 Powerstroke
  12. Jul 7, 2017 at 10:01 AM
    DUBENZ
    DUBENZ Active Member
    Ruben
    2017 Black Taco TRD Off Road 4x4 LB
    wow, might have to reserve mine. Can't wait to see how they come out.
  13. Jul 7, 2017 at 10:15 AM
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    subbbbb'd. killin it again.
    MESO[OP] and ChadsPride like this.
  14. Jul 7, 2017 at 10:19 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    hell yea. sub'd.. cant wait to see !:laser:
  15. Jul 7, 2017 at 10:20 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    sub
    EDIT: I wonder if its possible to do a 3rd gen front end conversion on my 2nd gen
    I totally would just to rock these​
  16. Jul 7, 2017 at 10:25 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Woooooah sub'd!
    tcjacado and ChadsPride like this.
  17. Jul 7, 2017 at 11:18 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Holy shit your still here? I haven't seen you on the site in quite some time!
    ChadsPride and AsianAnts[QUOTED] like this.
  18. Jul 7, 2017 at 12:03 PM
    AsianAnts
    AnT
    I'm back! and I can't wait to see @mesojdm work. I saw his taillights i am amazed!
  19. Jul 7, 2017 at 12:16 PM
    MagneticTaco4x4
    2017 Tacoma
    The price is justifiable when the product = form and function with quality materials. Those are the same people that add spacer lifts to their trucks that see it that way.
    EDIT: NEED MORE PICS!
    stevotivo12 and ChadsPride like this.
  20. Jul 7, 2017 at 1:27 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    :thumbsup:
    Nunya Bizness and ChadsPride like this.
