3rd gen Rancho Loaded quickLIFT RS999915 on 285 70 17
Discussion in 'Suspension' started by roskinc, Sep 18, 2019.
  1. Sep 18, 2019 at 9:29 PM
    roskinc
    roskinc [OP] Well-Known Member
    i installed some Rancho Loaded quickLIFT RS999915 on my 19 double cab short bed trd sport this past weekend. now why did i go with Ranchos? well i got these super cheap and they come ready to install. they have a adjustable valve and lifetime warranty..replace them anytime, return them anytime depending where you buy them from (these are available most major parts stores). these were perfect to get a quick cheap lift to fit the tires i wanted...and NOT use spacers.
    before i got these i searched around and couldn't really find anyone running these, at least not a 3rd gen so i thought i would post this review for others. now i can only compare to stock which is what most people will be caring for anyways if their searching for these.
    install was straight forward they literally came ready to slap on, took about 45 minutes for each side to install, using standard hand tools and a jack (i did it at my works parking lot, so no excuses!) they actually surprisingly ride amazing, better than stock to me, and i have not messed with the valving. soon after i installed, i installed the 4runner sema trd pro wheels, and 285-70-17 BFG A/T k02 tires, i was worried about rubbing, but with the sema wheels offset, these tires fit perfect with this lift, i get absolutely zero rubbing, ive pulled out of driveways with a decent incline and in full lock reverse and nothing. no trimming or anything besides removing the bottom of my bumpers valance (it might have rubbed on that) overall i gained about 2.5" of lift.
    took it to get an alignment the next day and the alignment shop only charged me 20 bucks for an alignment check, i thought they misheard me as i told them when i dropped it off that i lifted the truck and got new wheel/tires...but nope they said the alignment was perfect, and they saw the notes about the lift and tires...now this is a reputable alignment shop around town so if they were after money, they would have charged the amount for an alignment and i would have paid and not known, being it was perfect they only charged for the check.
    here few photos, hope this helps others who found these struts and were curious. ive only had them on since Sunday, drove about 3hrs hwy today and drove super smooth. i will update as time goes by, like i mentioned i only got these as temps until i get the icon/king setup, but they ride so well, im not in a rush.
    Da Boogie Man, Rankin and GLOCKAMOLE like this.
  2. Sep 19, 2019 at 4:48 AM
    dwest76
    dwest76 Member
    This is the first I've seen of these, thanks for posting! Any plans for the rear?
  3. Sep 21, 2019 at 3:53 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I have these on my 1st gen and have been on for a year now with no problems. I just swapped out the rs5000 in the rear for the rs9000 and the truck rides so smooth! Any one in the market for some Rs5000's? I should have gotten the RS9000 for the rear to begin with.
  4. Oct 2, 2019 at 12:46 PM
    GLOCKAMOLE
    GLOCKAMOLE Well-Known Member
    Sean
    North GA
    2021 Cement TRD Off-Road DCSB
    Eibach Stage 2R Coilovers, TRD 4Runner wheels, 265/75/17 BF Goodrich A/T, Pro grill, tint, ditch and fogs.
    Looks great. Did you do anything to the rear?
  5. Oct 5, 2019 at 7:07 AM
    awynne56
    awynne56 Well-Known Member
    Andy
    2019 Taco trd sport
    front grill pro
    Op any major issues? I’m thinking about this , so no adjustment of the strut? What were blistens for? Did you add a block or a leaf? Was the install for lifting or leveling out Thank for any input. I’m new to the taco. Been just playing with my fj40 leafs all around
  6. Oct 5, 2019 at 9:17 PM
    roskinc
    i used these for a lift to fit the tires. was not trying to level but when i finished it looked leveled so i didn't finish the rear. but now i do see the front higher than the rear so next weekend i have off i will install the bilsteins and the AAL you see pictured. so far the truck is still riding super smooth, and i am actually very happy with the ride. im in no hurry to get a new setup (icon or king) which my original intent was to get these on for now, and in a few months get a new setup, but i like the ride so much i might wait for some time before i do that now.
    waldo87 likes this.
  7. Oct 5, 2019 at 10:59 PM
    awynne56
    Andy
    2019 Taco trd sport
    front grill pro
    Thanks for the reply. Are the fronts selectable? What number did you select if they are ?
  8. Oct 20, 2019 at 1:38 PM
    roskinc
    I actually left them at the first setting, not sure if it’s soft or hard, doesn’t say anywhere which direction is what, I’ll have to try it out and report back but so far these struts have been rising very very, very impressed.
  9. Feb 7, 2020 at 9:58 PM
    jetfishn
    jetfishn Well-Known Member
    Number 1 is softest ride setting and 9 is hardest ride setting, I have Rancho Quicklift 2.5" rs9000's on my truck at about 80K and I am now at 179K and love em, rear same RS9000's I have em all set to 7 since I prefer a firm ride and no porpoising with towing travel trailer, its just right when I am pulling my 17 ft travel trailer. As for rear lift I have super-springs on the highest heaviest setting, the truck is leveled out fine, with added capability of taking the trailers 450 lb tongue weight without much sag. Overall huge stability gain for the truck as well, cornering is much better. I personally consider the RS9000's a huge upgrade over the oem yellow bilsteins. Rancho shocks have been used and liked by Jeep crowd for many yrs.
  10. Jan 3, 2021 at 11:13 PM
    Offroadr
    Offroadr Well-Known Member
    How did you get the coilovers in? Did you drop the sway bar and LCA? Or is there enough space by disconnecting the sway bar to fit the coilover?
  11. Jan 22, 2021 at 3:30 PM
    neergtaco
    neergtaco Member
    Stuart
    2018 TRD sport
    After riding with them for a while how much actual front lift did you achieve?
  12. Jan 22, 2021 at 5:20 PM
    idriveabox
    idriveabox Well-Known Member
    Calgary, AB
    2015 BRM SR5
    Had these on my first gen tundra. The ride was terrible and they blew with under 5k miles. Hope they work better for you on the third gen. Truck looks good!
  13. Oct 3, 2021 at 7:05 AM
    Rollo67
    Rollo67 Well-Known Member
    So any update on your 9ks? Holding up ok? Looking at these as well for my 2018
  14. Dec 27, 2021 at 7:57 AM
    Jinx3Mt
    Jinx3Mt Member
    2017 Tacoma TRD Off Road
    I just got a set of these to try on my double cab 2017 TRD Off-road.
  15. Jan 7, 2022 at 9:36 AM
    Jinx3Mt
    Jinx3Mt Member
    So I have a week on the Rancho RS9000 shocks and Quick lift struts. So far they are great. The main reason I upgraded was because my rear factory shocks were completely blown and after installing my 2.5" front/2" rear spacer lift the suspension was so tight it felt like every bump I hit you could almost feel in your teeth.
    Before upgrading to the RS9000's I did a short base line test drive on a rough dirt road to remind me how bad the current suspension was.
    So I installed struts and shocks, set them on #1 and wow. It floated over bumps like an old Cadillac. Next I set them to #5 and It felt better than factory but a lot tighter and less roll, and it does great on pavement as well. I didn't have time to turn them up to #9. That will probably be later.
    Double cab 2017 TRD Off-road
    - 285/75r-16 tires
    - .75" piloted wheel spacers
    - 2.5" rancho RS9000 quick lift in the front # RS999915
    - 2" spring spacer lift in the rear
    - Rancho RS900 rear shocks # RS999319
    - Diff drop
    - Sway bar relocation blocks
    - And a topper
  16. Sep 24, 2024 at 10:00 AM
    Spartan_01
    Spartan_01 Member
    Deep South
    18 Tacoma Double Cab TRD Off Road - Quicksand
    How is this set up running. Looking at it as well.
  17. Sep 24, 2024 at 10:10 AM
    hayjohn
    hayjohn Well-Known Member
    SoCal
    2019 Toyota Tacoma TRD Off Road 4x4, Magnetic Gray Metallic
    Looks like the Esplanade in Redondo Beach
