3rd Gen Rear axle is offset more on the passenger side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LabDogJack, Mar 11, 2018.
  1. Apr 16, 2021 at 6:06 AM
    #41
    TacomaBologna
    TacomaBologna Member
    Daytona Beach
    2018 Tacoma sr5
    No. I never installed the 1/2” spacer. Didn’t trust it. Stock Studs were Definitely to short.
  2. Apr 16, 2021 at 7:30 AM
    #42
    Steveko
    Steveko Member
    2021 TRD sport DCLB
    i've never run spacers, but a longer shank lug nut seems to be a fix, vs longer studs...
  3. Apr 16, 2021 at 7:44 AM
    #43
    TacomaBologna
    Daytona Beach
    2018 Tacoma sr5
    I had extended lug nuts. Still didn’t feel right. Also with the 1/2 spacer you will be loosing your 106mm hub centric then you are depending on possibly lug centric. Vibration. This is just my experience, you might have better luck. If it fails, it could be a real bad situation.
  4. Apr 16, 2021 at 10:32 AM
    #44
    Steveko
    Steveko Member
    2021 TRD sport DCLB
    Thanks for all the replies. I'm going to leave it, might scooch the bed over a little just to cover up the aesthetics.
  5. Apr 18, 2021 at 10:33 AM
    #45
    Rik808
    Rik808 Well-Known Member
    maybe a stupid question but you are 100% sure all new rims are the same offset? i have gotten a set before for an older s2000 and 1 of the 4 rims was sent with the wrong offset.
  6. Apr 18, 2021 at 10:46 AM
    #46
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    What is/are Torx?
  7. Apr 19, 2021 at 12:38 PM
    #47
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Dammit. <heads outside to look at new truck>
    Chunk likes this.
  8. May 8, 2021 at 6:58 PM
    #48
    TacomaBologna
    Daytona Beach
    2018 Tacoma sr5
    Update. So with my aftermarket wheels and tires. I ended up with bolt on hub-centric wheel spacers. Being that mine was 3/4 to passenger side. I installed a 1 1/2 spacer to drivers rear and 3/4” spacers to others. (FYI 3/4 spacer smallest stud spacer you can get) Bora makes a great spacer. Trustworthy. Finally my truck look balanced.
    Good luck.
  9. May 8, 2021 at 7:26 PM
    #49
    Rik808
    this is a torx bit it is used to remove a bolt with a star in the center not a +(Philips) or a l (flat).
