3rd Gen - Rear Drum Brakes???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beancooker, Jul 12, 2019.
  1. Jul 12, 2019 at 1:48 PM
    #141
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    What do you mean by controlable?
    Even if I’m going 1mph, and i touch my E-brake, they’ll instantly lock up until the truck stops moving.
  2. Jul 12, 2019 at 2:00 PM
    #142
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    OP if you have any other questions feel free to ask away...
    TD90S, Malvolio and stun gun like this.
  3. Jul 12, 2019 at 2:04 PM
    #143
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    https://youtu.be/UcbXCMvpmWo
    Malvolio and .jake like this.
  4. Jul 12, 2019 at 2:10 PM
    #144
    GT_Charlie
    GT_Charlie Well-Known Member
    I knew going in that my Taco(s) had rear drums, and that's one of the things I don't like about them. My FJ (all disc) requires a lot less pedal pressure to do the same braking job.
    The '60s panel van parking brake on the dash is another thing that irks me, but I see Toyota finally got rid of that.
    Charlie
  5. Jul 12, 2019 at 2:11 PM
    #145
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    :rofl:
  6. Jul 12, 2019 at 2:11 PM
    #146
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I actually did laugh out loud when I read that!
  7. Jul 12, 2019 at 2:31 PM
    #147
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Lemon Law is the best option for you.
    Dryfly24 likes this.
  8. Jul 12, 2019 at 2:37 PM
    #148
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    The whole not moving dealie is the true essence of a parking brake, simply put it's parking brake perfection :proposetoast:
  9. Jul 12, 2019 at 3:09 PM
    #149
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Alright stun gun, I know that's you. The timing is just too perfect. "Beancooker", really?
    On the off chance <10% that you are a new noob, sorry about that.
    Running Board Man, TD90S and Malvolio like this.
  10. Jul 12, 2019 at 3:11 PM
    #150
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Not true about ratcheting rear disc ebrakes. Been plenty of designs over the years that have rear discs and a ratcheting ebrake. 4Runner has it.
    The big deal IMO with a rear disc ebrake is: Does the ebrake use the disc pads, or does it have a drum for the ebrake?
    4Runner has a drum ebrake along with the stopping brakes which are discs. There are vehicles that use the stopping disc brake pads as the ebrake, no drum added in. The '05 Tundra, I was looking at a rear disc conversion, the kit used mid-90's Ford Thunderbird rear discs which use the disc pads as the ebrake, no drums.
    I have a VW Eurovan with rear discs, has a hand lever ratcheting ebrake, no drum for the ebrake, there's a pin attached to the cable that draws the disc pads together onto the rotor.
    That's the best design IMO, you have a ratcheting ebrake with a hand lever and it uses the disc pads.
    Toyota could do the same, but if Seatbelt Mike says all is good that's fine with me. :) :thumbsup:
  11. Jul 12, 2019 at 3:28 PM
    #151
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Nah....Stun gun would troll a lot better than this.
    Running Board Man and Dryfly24 like this.
  12. Jul 12, 2019 at 4:44 PM
    #152
    Stocklocker
    17TRDORDCSBAT
    Get outta town. 4Runner has a pedal actuated parking brake, which is not equivalent to the hand operated parking brake on a Taco.
    The beauty and advantage of the Tacoma system is it is operated by hand, leaving both feet free, and if you hold in the button, does not ratchet, so you can modulate it.
    The 4Runner parking brake is identical to what’s on my wife’s Camry, and is total garbage for use in the situations I describe, especially if you are driving a manual transmission.
    When Toyota gets rid of drums, it’ll probably mean the end of the MTs.
    02Duck and monkeyface[QUOTED] like this.
  13. Jul 12, 2019 at 4:54 PM
    #153
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    But but but.. there was a Toyota PU in that movie
  14. Jul 12, 2019 at 5:36 PM
    #154
    monkeyface
    Colorado
    Well yeah, the Runner has the leftfoot ebrake, but still it's a manual ebrake on rear discs.
    I understand your point about a hand ratcheting ebrake with a release button like the Taco has, 1st gen had the same.
    Still, IMO, the ideal setup is rear discs with an ebrake that uses the stopping pads. It ain't all that difficult, but Toyota sells plenty without doing so.
    Pretty much like the ridiculous front diff 10mm Allen drain/fill plugs. Unanimous opinion is they suck, but Toyota has churned out the same since about 1964. Doesn't hurt sales apparently. Every 4WD Toyota I've owned be it Taco, Tundra, 4Runner the same ridiculous 10mm Allens on the front diff drain/fill plugs.
    Stocklocker[QUOTED] likes this.
  15. Jul 12, 2019 at 5:42 PM
    #155
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Tacoma's would suck with out the rear drum brake slap.
    Stocklocker likes this.
  16. Jul 12, 2019 at 6:03 PM
    #156
    Beancooker
    Beancooker [OP] Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    Hate to bust your bubble O’Connor, but I’m a n00b to the Tacoma formus. Google my username. It’s my online moniker for the last 15 years. “Beancooker” is because 15 years ago I was a coffee roaster. It was the best I could come up with when I registered at NICO.
    oconnor[QUOTED] and Dryfly24 like this.
  17. Jul 12, 2019 at 6:07 PM
    #157
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Also, You’re too young to smoke...
    Tullie D likes this.
  18. Jul 12, 2019 at 6:15 PM
    #158
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    On my 1999 in 125,000 miles I changed the front pads 3 or 4 times but I never needed to change the rear shoes. I'm okay with rear drums on the 2016.
