3rd Gen Rear Pinion seal Guard and Seal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gomez6, Aug 24, 2020.
  1. Aug 24, 2020 at 11:30 AM
    Gomez6
    Gomez6 [OP] New Member
    2019 taco off road
    None completed yet.
    Hey guys,
    I have noticed there is a lot of information and videos on replacing the rear pinion seal, however recently while wheeling my oopsie included smashing the rear seal guard as well. I have a 2019 TRD Off-Road MT with only 25k on it, I have not contacted a dealership to see if they will cover it under the new vehicle warranty since I'm not sure what their definition of "Abuse and Negligence" is. With that said is replacing the rear seal guard as simple as separating if from the Companion Flange and replacing it or are the Companion flange and seal guard one whole piece? I have included some photos of not only my rig but of the damaged area. Thank you for any assistance and I apologize is this has been posted some place else on here but I couldn't find it if it were.
    20200706_142932.jpg 20200706_143025.jpg 20200824_095249.jpg 20200824_095322.jpg 20200824_095519.jpg 20200824_095527.jpg
    TacoPandaTRD likes this.
  2. Aug 24, 2020 at 11:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don't know about replacing the seal, but I would bet the use your last pic as an example of abuse
  3. Aug 24, 2020 at 11:43 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    1st, check wheels so that vehicle don't roll on ya.
    2. Unbolt the drive shaft from diff, those 4 bolts are specd at 65ft#'s(14mm)
    3. Very important, mark the pinion nut to the the pinion so you can get it at the same exact tightness, again, very important.
    4. Unbolt the pinion nut(30mm) no torque spec here because you marked the nut to the pinion.
    5. Using a 2 or 3 jaw puller, remove the flange from the pinion.
    6. That cover you boogerd up is called a dust shield. Not sure if its replaceable as a single part, or if the dealer will make you buy a whole new flange. And no, it won't be covered under warranty.
    7. While you're there, replace the pinion seal.
    8. Tap the flange back on, make sure you apply a thin film of gear oil or grease to anything that touches the punion or the seal.
    9. Here's the important part, get that pinion nut exactly where it was, only acceptable difference is maybe a 1000th an inch further(tighter)than the original spot.
    10. Ding the pinion nut to lock it in place
    11. Reattach drive shaft with 4 bolts at 65ft#'s
  4. Aug 24, 2020 at 11:52 AM
    Gomez6
    2019 taco off road
    None completed yet.
    Awesome that's easy enough. Thank you. last question that edge that is in direct contact with the outer lip of the differential case itself, is that apart of the Seal? all seals i have seen slide inside of the differential casing without a lip.
  5. Aug 24, 2020 at 1:37 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    When you see the new seal, it'll make sense. Yes, that edge is part of the seal. To drive the small if more smoothly, lightly coat the edges with black rtv.
  6. Apr 25, 2021 at 5:45 PM
    @natestaco
    @natestaco Member
    Nathan
    British Columbia
    2020 Tacoma TRD Off Road
    Did you end up replacing your companion flange and oil seal both? If so do you have the part numbers any chance?
    In a similar problem right now as mine is squeaking a lot when driving. Would love to know how you got around to fixing it.
    Thank you for your time!
  7. Jul 28, 2021 at 11:21 AM
    2wdto4wd
    2wdto4wd Member
    Any luck with theses fixes? I have the same type of damage.
  8. Aug 14, 2021 at 7:22 PM
    LRockPro
    LRockPro Well-Known Member
    LRock
    BUMP anyone got part number for the guard dust flange?
  9. Aug 14, 2021 at 8:44 PM
    2wdto4wd
    2wdto4wd Member
    it is important to note this is for a v6 trd off road 2017 automatic 4wd. Best way to confirm is to call any Toyota dealers parts department.
    Jseda845 and LRockPro[QUOTED] like this.
  10. Aug 16, 2021 at 1:08 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Google toyota 8.75 elocker, then maybe add Parts list to that if you still have trouble
    LRockPro[QUOTED] likes this.
  11. Aug 22, 2021 at 5:10 PM
    LRockPro
    LRock
    Thank you!
  12. May 8, 2024 at 7:49 PM
    Puga10
    Puga10 Active Member
    oscar
    2019 Toyota Tacoma
    Why does pinion seal part number change from 2015 and on? I see other used 90311 seal
  13. Jun 3, 2024 at 8:37 PM
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    Something similar happened to me. I hit a rock pretty hard. It bent my skid plate bracket forcing the upper bolt into my dust shield making it separate from the yoke. It was making an awful grinding sound until I hammered it around the axle housing. Just wondering if this is an easy fix. Can I replace just the dust shield or is it all one piece with the yoke? My seal is okay thankfully :amen:
