3rd gen rear suspension question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Westy70, Jan 23, 2022.
  1. Jan 23, 2022 at 6:37 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    How would a block make the leafs "stiffer"? I would imagine it would be the same as stock. It's not like the mounting surface changed its area?
    Stocklocker likes this.
  2. Jan 23, 2022 at 6:43 PM
    Sleddog0311
    Sleddog0311 Active Member
    Black 2020 DCSB TRD OR
    Barricade HD rear bumper, Cali-raised smoked rear LED lights, Black Rhino (Chamber) black 17x8.5, 0 offset, 4.75 backspace wheels, Toyo Open County AT III 275x70R17
    +1 on recommendations for leafs, either full packs or AAL. I have been leaning towards HS AAL.
    AmateurTaco1313 likes this.
  3. Jan 23, 2022 at 6:52 PM
    Toco62
    Toco62 Well-Known Member
    A buddy owns a shop and told me the lift block put the springs in a bind , I picked up the icon
    3 leaf AAL in the rear with 5100s all around to me it rides better than stock .
    Jp260z and 908tacoma like this.
  4. Jan 23, 2022 at 7:07 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    It won’t, as long as the axle plate and shock travel wasn’t altered. And if the overload leaf was left in that can make a difference in stiffness. Bump stop too. Lots of factors
    Jp260z likes this.
  5. Jan 23, 2022 at 8:18 PM
    Westy70
    Westy70 [OP] Member
    Scott
    Fort Worth
    '19 Tacoma TRD Off Road Cement
    Eibach Stage 1, 33" Nitto's, K&N CAI, custom Magnaflow exhaust, all LED lighting interior and exterior.
    Which option would you recommend and how much is “a little weight”?
  6. Jan 24, 2022 at 12:11 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    A lift block is used when you want to lift the rear end, but don’t want to change the performance or dynamics. The only think it alters is the driveline angle. All other quantities remain the same.
    If you don’t like the ride with the lift block, you won’t like it without the lift block.
    Toyota leaf springs have little or no arch from the factory. This is intentional as it gives the best ride possible with an empty truckbed as the spring compression and droop are mostly equal. Toyota anticipates most people will never load the bed so opts on the side of a flattish soft spring for unloaded performance.
    Tire pressure and possibly shocks would be the place to start. Hard to find a softer leaf spring than the OEM Toyota springs, so it’ll only get harsher with something rated for more weight.
    Speedfreak, 908tacoma and Jp260z like this.
  7. Jan 24, 2022 at 3:33 AM
    Btcomcast
    Btcomcast Well-Known Member
    Boston
    2024 Trail hunter
    Far to much money spent.
    I used option 1 got close to 2 inches of lift after settle. Weight only for winter is 2 40 pound gravel bags and whatever is in my swing cases.
  8. Jan 27, 2022 at 5:35 PM
    Westy70
    Westy70 [OP] Member
    Scott
    Fort Worth
    So just been researching. Anyone have experience with hammer hangers? Website says it eliminates the jittery rear end.
  9. Jan 27, 2022 at 5:36 PM
    Westy70
    Westy70 [OP] Member
    Scott
    Fort Worth
    Thanks!
