3rd Gen Recovery Gear Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Z50king, Jan 12, 2016.
  1. Jun 3, 2017 at 4:12 PM
    #121
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's in another thread I was in the other week. Give me a few minutes.
    EDIT: Just found it. 80 ft/lbs
    DrKevinMWard[QUOTED] likes this.
  2. Jun 3, 2017 at 6:25 PM
    #122
    DrKevinMWard
    DrKevinMWard Active Member
    Kevin
    2017 Toyota Tacoma TRD Off Road Barcelona Red Manual Transmission
    Thanks a bunch!
    EatSleepTacos[QUOTED] likes this.
  3. Jan 13, 2019 at 8:34 PM
    #123
    PacoDaTaco
    PacoDaTaco Well-Known Member
    B
    ‘19 TRD OffRoad Magnetic
  4. Jan 14, 2019 at 6:49 AM
    #124
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    bnv likes this.
  5. Jan 14, 2019 at 8:38 AM
    #125
    PacoDaTaco
    B
    That may be the case in certain situations yes. But in the situation where someone doesn’t have a winch, or a snatch strap, this tow strap can help get you out of a sticky situation. It’s a good purchase for $16 and for someone who knows what they’re doing and uses common sense, it can get a truck out of a hole easy.
  6. Feb 23, 2019 at 5:53 PM
    #126
    eddyizm
    eddyizm Well-Known Member
    2018 TRD OR DCSB 4x4 Cement
    Does anyone know if you can use a soft shackle on this BP hook? I'd assume not because of the sharp edges but i'm not familiar enough with soft shackles. I'm looking at picking one up and thought it'd be nice to try out soft shackles as the advantages with safety and weight seem to be worth it.
  7. Feb 23, 2019 at 5:59 PM
    #127
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Personally I wouldn’t be comfortable using a soft shackle on it, unless it had an abrasion guard around it.
  8. Feb 23, 2019 at 6:00 PM
    #128
    eddyizm
    That's kind of where i'm leaning towards as well. Do you have any opinion or working knowledge of a soft shackle with that feature?
  9. Feb 23, 2019 at 6:09 PM
    #129
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There’s this one but it’s pretty thick. Should still fit in the shackle hole though, albeit tightly.
    Ucreative Synthetic Soft Shackle 7/16'' X 19'' (36,400lbs Breaking Strength) Green https://www.amazon.com/dp/B07CV5SZH8/ref=cm_sw_r_cp_api_i_BYFCCbQ6TFCZ5
    eddyizm[QUOTED] likes this.
  10. Feb 23, 2019 at 6:09 PM
    #130
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Why not just use a d ring for that? I wouldn't be super worried about it separating and becoming dangerous
  11. Feb 23, 2019 at 6:18 PM
    #131
    eddyizm
  12. Sep 23, 2019 at 9:46 PM
    #132
    4sky
    4sky Well-Known Member
    Kevin Levu
    2018 White Tacoma PRO
    I’ve been recovered through the rear chain holes lol
  13. Oct 5, 2019 at 11:12 AM
    #133
    eddyizm
    Does anyone know where I can pick up some bolts for the BP Recovery hook? I checked out my local HD and didn't find the right size. I'm assuming I need 3 to replace the stock bolts.
    M12x1.25x40mm
  14. Feb 14, 2020 at 7:04 AM
    #134
    joshjuniorr
    joshjuniorr Well-Known Member
    Josh
    Mississippi
    What kinetic rope would y'all recommend?
  15. Feb 14, 2020 at 8:14 AM
    #135
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
  16. Feb 14, 2020 at 10:44 PM
    #136
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
  17. Feb 15, 2020 at 5:23 AM
    #137
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    Checkout 4 Wheel Parts. They've got some quality products at competitive prices. Search around for coupon codes and have it shipped directly to you. It's weird how in-store pickup always ends up being more expensive. :annoyed:
    On another note, just picked up this Smittybilt 5.65 CFM Air Compressor - 2781 and it's probably about the largest I could've gotten that still fits nicely behind the rear passenger seats.
    joshjuniorr[QUOTED] likes this.
  18. Feb 15, 2020 at 8:47 AM
    #138
    joshjuniorr
    Josh
    Mississippi
    i've got a viair unit thats a tad smaller..basically waiting on it to kick the bucket to upgrade lol. i'm a diesel tech so ive been kickin around the idea of plumbing some hose up to air one side of the truck up (2 tires at a time). Saw a product on some overlander video and was like not a bad idea bc...lets face it i'm lazy lol
  19. Feb 15, 2020 at 10:29 AM
    #139
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    This is the one to buy for an oh shit plan. If you really use it a lot, might as well get the best and buy a bubba rope. I didn't think the difference was much until I got pulled out of a mud pit once and those ropes are soooooo much smoother with all that stretch. I still have the ARB in my truck but the rope is on my to buy list at some point.
  20. Feb 17, 2020 at 8:03 AM
    #140
    savethewheels
    Nashville, TN
    truck
    Made these axe + shovel brackets over the weekend. If you're comfortable with bending and cutting aluminum, it was fairly easy.
    Aside from some various screws, washers, lock nuts, and a strip of 1.5" wide aluminum from Home Depot, my purchased supplies included the following:
    - 2 of END OF ROAD Original Quick Fist Clamp for mounting tools & equipment 1" - 2-1/4" diameter (Pack of 2) - 10010 (two boxes, so four total Quick Fists)
    - MISSION AUTOMOTIVE 5-Pack of T-Slot Nuts
    - The Hillman Group 44018 3/8-16 x 1-Inch Button Socket Cap Screw, Stainless Steel, 5-Pack
    You'll notice the bent portion of the bracket rests against the bedside and on top of a flat contour. Combined with the T-Slot nuts in the bedrail, the mounts are extremely solid. There's no play to them whatsoever.
