3rd Gen Remote Start Using OEM Remote
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nickj718, Dec 7, 2016.
  1. Dec 14, 2016 at 1:41 PM
    #461
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    Still curious why they just didn't make it where you had to push the start button again with the fob present. That's essentially how regular keyed remote starts are where you put the key in and turn it. Otherwise, it'd cut off when you hit the brake.
  2. Dec 14, 2016 at 1:43 PM
    #462
    nickj718
    nickj718 [OP] Well-Known Member
    Nick
    2016 Tacoma TRD Sport
    What happens if the vehicle is running and you hit the button now?
    .....Car Dies......
    Guys I'm sorry but this isn't gonna change were beating a dead horse. You can warm it up and restart when you get in or freeze your balls off for the first 10 min of your drive.
    Vol17TacoTRD and opentang like this.
  3. Dec 14, 2016 at 1:44 PM
    #463
    BrokenLimits
    BrokenLimits Well-Known Member
    Brandon
    Lincoln, NE
    2016 TRD Off Road
    If I understand it correctly, the bypass is bypassing the system that looks for that key and starting the vehicle. You would need a much more complicated system that would be more expensive that would be coded to switch off the bypass that would then allow the system to look for the key again.
    You will be spending a lot more than $130 on that.
  4. Dec 14, 2016 at 1:46 PM
    #464
    nickj718
    Nick
    Yes and no. The issue is that the truck thinks the key is in the vehicle and that you physically pushed the brake and hit the button. So because of this it could be stolen. Think of it this way. You start the car and one minute later a dude gets in and drives away. He has 19 min of that 20 min run timer remaining to get as far away as possible.
  5. Dec 14, 2016 at 1:46 PM
    #465
    PJnc284
    Garner, NC
    Good point. As it stands that wouldn't work. Toyota should program it to where you have to hold it down to shut off similar to if you're moving. Don't ask how I found that out. :rolleyes: Granted someone would complain that they had to hold the button down.
  6. Dec 14, 2016 at 1:47 PM
    #466
    nickj718
    Nick
    Truth is even if it was possible i wouldn't do it. Its a liability for myself and KB Voodoo. If you can sue McDonalds for hot coffee anything can be done
    TyONEon and KB Voodoo like this.
  7. Dec 14, 2016 at 1:48 PM
    #467
    BrokenLimits
    Brandon
    Lincoln, NE
    2016 TRD Off Road
    That is what I meant exactly.
  8. Dec 14, 2016 at 1:49 PM
    #468
    nickj718
    Nick
    Oh sorry. Your correctomondo
  9. Dec 14, 2016 at 1:49 PM
    #469
    BrokenLimits
    Brandon
    Lincoln, NE
    2016 TRD Off Road
    The way that it would have to be programmed to do it and keep it safe is that when someone gets in the truck and presses the brake the system would then have to "look" for the key again. So its not impossible, it could be done, it is just a product that to my knowledge does not exist.
    Remote Start = True
    If Brake = True, Then disable bypass, check for key
    If Key = False, shut down system,
    If Key = True, drive as normal
  10. Dec 14, 2016 at 1:51 PM
    #470
    nickj718
    Nick
    It would have to find the key extremely fast to do that.
    Other vehicles such as Nissan you just hit the button again and drive away. No toyota or lexus vehicle is capable of key take over
    I did bypass the system to utilize the door locks while running so it could be worse
  11. Dec 14, 2016 at 1:52 PM
    #471
    winston50
    winston50 Well-Known Member
    People are never happy....... Its all or nothing
  12. Dec 14, 2016 at 1:53 PM
    #472
    BrokenLimits
    Brandon
    Lincoln, NE
    2016 TRD Off Road
    It could even have a 3 second delay upon brake press.
  13. Dec 14, 2016 at 1:54 PM
    #473
    winston50
    Why are we still talking about this!?!?!?!?! It was covered in the first page it wasn't possible
    Give it up people
  14. Dec 14, 2016 at 1:54 PM
    #474
    BrokenLimits
    Brandon
    Lincoln, NE
    2016 TRD Off Road
    lol I was just trying to tell people WHY it is not possible so they stop thinking no one has ever thought of it.
  15. Dec 14, 2016 at 1:57 PM
    #475
    nickj718
    Nick
    All covered the first couple pages.... then couple pages after that..... thens again... and now
    I appreciate you telling them its impossible though
  16. Dec 14, 2016 at 2:03 PM
    #476
    nickj718
    Nick
  17. Dec 14, 2016 at 2:13 PM
    #477
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Or go out and start your truck, turn defrost on high, and go back in the house for 10 to 15 minutes. This is how us poor folks do it.
  18. Dec 14, 2016 at 2:17 PM
    #478
    SkolChipz
    SkolChipz Well-Known Member
    Jared
    Anchorage, Alaska
    '16 DCLBOR BBP
    LEDs, Snow, Dirt, Dogbed
    That was me (with my dealership's quoted price), but the problem is when I work inside all day while it's some stupid "my entire body hurts" temperature outside. I don't want to run through 5 security doors, outside to the parking lot, then run back inside, and just assume my UNLOCKED truck is going to be fine right next to the homeless guys bumming cigarettes off the trash can. You can do what you suggest at home, but not once you leave your own driveway.
    It's not just laziness.
    CusterFan[QUOTED] likes this.
  19. Dec 14, 2016 at 2:36 PM
    #479
    B4 2 L8
    B4 2 L8 New Member
    Dr. Nick
    2017 TRD Off-Road, Double Cab, Long Bed, Premium & Technology Package with JBL
    Amp Research Power Step, (lift to come, have yet decided on height)
    Thanks, guess I didn't read all 456 other posts on this thread. I guess someone will make a lot of money when they figure out a way to fix this problem.
  20. Dec 14, 2016 at 2:39 PM
    #480
    PJnc284
    Garner, NC
    Seems like they'd send them from the factory with remote start. More money for them and more secure. As it stands, if you do it the old fashioned way of going out and starting it, someone can get in and drive til they run out of gas or turn it off. hmm...wonder if the insurance company will give me a discount for installing one. o_O
