3rd Gen Remote Start Using OEM Remote
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nickj718, Dec 7, 2016.
  1. Dec 29, 2016 at 3:33 PM
    #661
    Jim=2015 TRD PRO
    Jim=2015 TRD PRO Well-Known Member
    Jim
    MD
    2015 TRD PRO
    Mine is doing the same
  2. Dec 29, 2016 at 3:37 PM
    #662
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Yes- I'm confident in my connections. I just went and reseated all the connectors. Still doing it.
  3. Dec 29, 2016 at 3:38 PM
    #663
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    gpb likes this.
  4. Dec 29, 2016 at 3:45 PM
    #664
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I did not, I tend to not follow directions(well I'd need to read em first to follow them)
    Happy it worked out, I knew my work was good, and figured it needed to be "initialized" cycling ignition did the trick
  5. Dec 29, 2016 at 3:48 PM
    #665
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    I guess I better pain attention to this too when I do mine lol
  6. Dec 29, 2016 at 3:58 PM
    #666
    Hank Heel
    WA
    In hindsight, I should have left auto light feature out, all it does is draws unwanted attention imo. I might go back and pull the wires like I did on wives Lexus
  7. Dec 29, 2016 at 4:01 PM
    #667
    BadRobot62
    BadRobot62 Well-Known Member
    David
    2017 Tacoma Sport 4x4
    Level kit,
    What happens if you don't connect the Auto Light wire's, even if you have the Auto Light feature. Will it cause it not to work.
    Thanks
    David
  8. Dec 29, 2016 at 4:06 PM
    #668
    ratcityrain
    Seattle, WA
    I'm with you, I don't want the lights to come on when it's running. Parking lights are fine, but I don't want headlights so do I not connect those wires?
  9. Dec 29, 2016 at 4:12 PM
    #669
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    I wired up the auto lights and my headlights don't come on. DRL and parking lights come on. I don't have a problem with that but can understand it may not be what everyone wants.
  10. Dec 29, 2016 at 4:12 PM
    #670
    Hank Heel
    WA
    My guess if you don't connect those 2 wires, it'll simply won't cycle light on, it shouldn't affect the operation of remote start itself
  11. Dec 29, 2016 at 4:12 PM
    #671
    ratcityrain
    Seattle, WA
    Then I bet the headlight switch has to be set to auto.
    opentang and Hank Heel like this.
  12. Dec 29, 2016 at 4:19 PM
    #672
    bdaniel
    bdaniel Member
    2017 TRD Offroad Quicksand
    I'm positive about the colors. Red to green to orange. I can unplug, plug back in and the thing will not go to solid red. I can manually start, shut off and retry and the same problem.
    No reply from Voodoo?
  13. Dec 29, 2016 at 4:20 PM
    #673
    bdaniel
    bdaniel Member
    Even tried the soft reset.
  14. Dec 29, 2016 at 4:25 PM
    #674
    Kennedyusmc
    Christopher
    2017 Cement Pro
    This sucks. I've disconnected the unit for the moment. Don't know what else to do...
  15. Dec 29, 2016 at 4:25 PM
    #675
    gpb
    Atlanta
    If I'm remembering correctly, the DBALL2 interrupts the auto light wire when running on remote start. That suggests the function is to prevent the headlights from coming on but I've not tested to verify.
  16. Dec 29, 2016 at 4:53 PM
    #676
    Jim=2015 TRD PRO
    Jim
    MD
    2015 TRD PRO
    I took mine out. Got very frustrated now my damn headlights won't come on. Shit I should of paid someone to do this shit
  17. Dec 29, 2016 at 4:56 PM
    #677
    nickj718
    nickj718 [OP] Well-Known Member
    Nick
    2016 Tacoma TRD Sport
    Did you try a reset and reprogram?
  18. Dec 29, 2016 at 4:58 PM
    #678
    nickj718
    Nick
    Auto head lights don't need tinge hooked up. However if you don't hook them up make sure your turn the switch to off. The auto feature pulses the headlights to tell them to turn off when the truck is shut down.
  19. Dec 29, 2016 at 5:00 PM
    #679
    gpb
    Atlanta
    Cool, thanks for the clarification.
  20. Dec 29, 2016 at 5:00 PM
    #680
    nickj718
    Nick
    This can happen for two reasons
    blue plug was installed before the red or at the same time clearing the unit or damaging it
    Wires are hooked up wrong or not a good connection
